*THE RTT Owners Thread (With BS)*
Discussion in 'Outdoors' started by ChamYota, Jan 23, 2014.
  1. Mar 23, 2020 at 7:55 AM
    BattlecryTaco
    BattlecryTaco Well-Known Member
    So Cal
    3rd Gen TRD Off Road DCSB
    :fistbump::thumbsup::thumbsup:
    This guy and his buddy’s rtt setups were my inspirations for setting up the tent to open out the back. It can be done with bigger tents than mine and doesn’t necessarily need to be mounted as far back toward the tailgate like I did with mine. However, you’d need to consider what else you’d be mounting/hauling behind the tailgate and how high it would be; higher is better when mounting the rtt to open out the back so that you can have better access to the bed from the tailgate and have better space for using the rtt as a type of awning/shelter when deployed. If you mount it on a camper shell type setup, then that should be good and may look more aesthetically pleasing than my setup, even if it’s mounted further back on the cab. Just take precaution to see that the cab can handle the weight distribution in that way, both static and dynamic (hard braking, acceleration, cornering, twisting when going off road).
    I did mine that far back so that I could still open the cab side panel of the Diamondback HD cover. It just happened to work out that the bedrack setup on top of the added height of the DB cover, the Yakima bike rack system, the size of the Tepui Ayer II, the size of the mtb, and the Tacoma’s tailgate system allow for me to get them all working together in a fairly tight operational system. I thank the Holy Spirit for guiding me in this little build. It ain’t a Noah’s Arc, but it’s a BattlecryTaco arc... the cheese is oozing and stretchy on this one. :taco:
    Edit: Note: Consider your height as a person and potentially needing to haul around a small step ladder or stepping stool. Having the rtt mounted further back and as high as it is on the bed on my setup(mid height for most rack systems of like kind) along with my height of 5’7”, I don’t have to climb up and down as much as the guy in the video does. I can zip and unzip the rtt cover from the ground all the way around. The main time(s) I’d need to get on the bed cover is when I gotta unbuckle the ladder strap to deploy the ladder that’s bolted on the Ayer 2 or when putting that thing away and buckling it back down. (I also deal with removing/applying the rtt cover at that time.) Sometimes, I’ll go up again to put on the poles for the awning for that side of the tent, but I could do those while on a step ladder or just not put up the awning on that side. However, I prefer to put it up in case the ladder side entry is not good for egress and I/we can use that opposite side as a secondary egress/ingress.
    Good luck and may God bless you and your build.
    Sincerely,
    Guy from page 1000
    Bonus footage from that same YouTuber guy:
    It’s cool that they’re both Tacoma owners. :fistbump::thumbsup::D
  2. Mar 23, 2020 at 8:59 AM
    HilltopperTaco
    HilltopperTaco HilltopperTaco
    2019 MGM DoubleCab Sport
    Awesome info. Thanks for sharing. That pretty much convinces me I am going to try mounting that way. My RTT is scheduled to arrive next week--but who knows with what's going on right now. I need to see about the mounting setup to see how much it takes to mount with it opening to the rear. I really liked that he talked about only taking 1 space--not needing 2 spaces and the level ground aspect of that. Plus, I plan to do mainly remote stuff instead of campground so that means I don't have to be as worried about finding a place that doesn't have trees next to the parking area. Let's see some pics when you get yours done. Stay safe and enjoy social distancing!
    BattlecryTaco likes this.
  3. Mar 23, 2020 at 9:07 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    ready6delta and LamzTaco like this.
  4. Mar 23, 2020 at 9:20 AM
    Subway4X4
    Subway4X4 Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    Dibs on your current one
  5. Mar 23, 2020 at 9:29 AM
    MountainManGuy
    MountainManGuy Well-Known Member
    Colorado
    2019 Toyota Tacoma TRD Off-Road DCSB
    My thoughts are it's pricey. If you have infinite money to throw away, it's probably super nice and a great option, but I certainly wouldn't go for that one if I was on a budget.
  6. Mar 23, 2020 at 9:45 AM
    fatfurious2
    David
    Ashburn, VA
    Its $3k. Definitely not a budget tent.
    I still like my automatic opening one. Just trying to keep things for more than a year :rofl:
  7. Mar 23, 2020 at 9:45 AM
    fatfurious2
    David
    Ashburn, VA
    Psh you have one already
  8. Mar 23, 2020 at 2:32 PM
    Subway4X4
    Lloyd
    NY/NJ
    Need one for the Prius
    fatfurious2[QUOTED] likes this.
  9. Mar 23, 2020 at 5:18 PM
    Chip_311
    Chip_311 Well-Known Member
    Brian
    NJ
    2017 DCSB OR
    BFG KO2s Pro Grille Pro Skidplate Pro Fox Suspension DShackles F & R CaliRaised LED Bumper Baja designs S2pro / S1 CaliRasied Off-road Sliders Waterport R4T Arm Skids RCI Skids Weather tech Visor Front Camera SCS Wheels Rear Bumper Covers Maxtrax Recovery Meso Gas Hole/Turn Signals Pop n Lock Kit Extended Rear Breather Expedition Essentials TPAM Midland USA Comms Clazzio Leathers Victory 4x4 Mollie Garmin Tandem Mountain Hatch Bestop2 Thule Evo Rack
    Thule officially taken over tepui rebranded all gear with there name, sales were the left over inventory with tepui name
    Grindstone likes this.
  10. Mar 23, 2020 at 6:19 PM
    tundraconvert
    tundraconvert Well-Known Member
    Eric
    San Diego
    2017 White Tacoma DCLB TRD OR
    Im running the iKamper skycamp. It’s about a one minute setup and 2 minute breakdown.
  11. Mar 23, 2020 at 6:54 PM
    fatfurious2
    David
    Ashburn, VA
    Karlyrie likes this.
  12. Mar 23, 2020 at 6:57 PM
    fatfurious2
    David
    Ashburn, VA
    @TaKoToy has a CVT tent for sale
  13. Mar 24, 2020 at 4:17 AM
    littlefish
    littlefish Buzz, your girlfriend...
    Hudson Valley NY
    2016 TRD Off-Road DCSB
    The one who dies with the most stuff wins.
    Finally ordered a cap and a Prinsu to go along with it to match the rack on the cab of my truck. Plan to mount the tent on the cap and Prinsu. Are the mounting feet that Prinsu sells necessary? I didn't realize those existed until after I ordered the new rack. My plan was to put a carriage bolt up from the cross bars and through the tent, cut them close and put an acorn nut on from inside the tent? Not crazy about the mounting feet raising the tent even higher.
    disconnected likes this.
  14. Mar 24, 2020 at 6:39 AM
    Armyhater458
    Armyhater458 Well-Known Member
    Clarion, PA
    2012 TX Pro
    OME 887, LR UCA, Dakar 095 (medium duty), Dick Cepek Extreme Country 255/85/16
  15. Mar 24, 2020 at 6:53 AM
    disconnected
    disconnected LOST
    Greg
    Pittsburgh
    19 TRD Off-Road
    Icon 2,5'' coilovers and rear springs, RCI full skids, caliraised sliders, Warfab hitch skid, UpTop roof rack, kb voodo bed rack, Diode Dynamis Pro fogs, Seat Jackers with Molle, taco garage mounts..... and other stuff
    is it listed somewhere?
    thanks
  16. Mar 24, 2020 at 7:14 AM
    fatfurious2
    David
    Ashburn, VA
    I dont see it in a quick search. Ill text him
  17. Mar 24, 2020 at 8:11 AM
    SummitBound
    SummitBound Well-Known Member
    Greenville, SC
    2019 T4R OR
    For those with larger dogs who keep them in the truck when they are in the RTT, what do you do to make sure they have ventiliation in the Cab?
    I was thinking about getting some of those window screens to pull over the back windows, but I was worried about it raining at night and dripping in to the truck.
    Thanks!
  18. Mar 24, 2020 at 11:02 AM
    tundraconvert
    Eric
    San Diego
    i like that idea. Before going Prinsu style I experimented with building my own rack system because I wanted it lower as well. I would encourage you to do a lot of experimentation and mock ups. Most shells have an arc to them at the center so when you lay a cross bar right onto the tracks it will hit the top of the shell or damn close that in a jostling off road situation it might flex and hit the roof causing damage. You might need some sort of spacer to make it work.
    the other thing you want to consider is the more cross bars you have the more weight distribution there is causing less stress on two cross bars and less stress on the shell and less stress on the tracks themselves. You definitely don’t want to pop the track off the shell. That happened to me on my last rig, not RTT related though. hope this makes sense.
  19. Mar 24, 2020 at 11:05 AM
    fatfurious2
    David
    Ashburn, VA
    @Arcticelf has a custom way to mount his tent. Its not on a shell though
  20. Mar 24, 2020 at 11:07 AM
    tundraconvert
    Eric
    San Diego
    my dog sleeps in the bed of the truck in the shell. He hates it lol. I put his bed down, crack a window and out a couple of blankets on him. He’s fine he’s just used to sleeping in the wife/my room. The entire family goes up top and he hears us but he deals.
