The Rub Blues
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TexaCaliTactical, Sep 11, 2022.
  1. Sep 23, 2022 at 4:19 PM
    WrecklessAbandon
    WrecklessAbandon They call me skippy
    Travis
    Olympia, WA
    Crocs with socks
    Your UCAs have roughly 2* of caster built in which moves the wheel rearward. Going back to the stock UCAs or adding caster with the LCAs are the easiest ways to move the wheel further forward to get them away from the pinch weld/cab mounts.
  2. Sep 24, 2022 at 11:09 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    You went up from 265/70/16 to 275/75/16 but the tire in your picture is 265/75/16? :confused:
  3. Sep 24, 2022 at 11:15 AM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    CMC, BFH to pinch weld, trim where needed.
    I am running 295s with no problems.
    Good luck with your truck.
  4. Sep 25, 2022 at 10:28 AM
    Color_Me_Taco
    Color_Me_Taco Well-Known Member
    Doug
    Utah
    2022 TRD OffRoad, 2019 TRD OffRoad, 2021 Subaru STI, 2021 Kawasaki ZX6R
    ADD, Rigid, ToyTech, DBcustomz, Methods, Nittos, Powertank, Morimoto
    500$ for an hour of work??
    My local shop charged 125$ for a cmc.
    Amazing....
    Maybe they interpreted it as a relocation? Those are spendy.
  5. Sep 26, 2022 at 10:36 AM
    TexaCaliTactical
    TexaCaliTactical [OP] Like your dad, but thicc
    LS
    Houston, TX
    2018 Tacoma Off Road
    RSI Truck Cap, Icon Stage 5. Body armor 4X4 bumper. Various Frontrunner products
    Whoops. That's suppose to say went up FROM a 265/70/16. Last pair was that. =/
    Glad I'm not the only one who thinks it's steep... I'll check around for additional quotes if I end up being lazy and not wanting to do it.
  6. Sep 26, 2022 at 10:50 AM
    Thunder Fist
    Thunder Fist Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    Did you regear with 295s? I'm on 285s, but I've been considering 295s. But I don't want to regear.
  7. Sep 26, 2022 at 11:08 AM
    Mully
    CA
    Not yet, but I am ordering 4.56 gears next week.
    It's not bad if you manually shift the trans and I can still use OD on the freeway.
    I wheel my truck and pull an expedition trailer, so a regear is a must for me.
  8. Sep 26, 2022 at 12:12 PM
    Thunder Fist
    David
    Birmingham, AL
    Like, so many.
    Thanks for the input.
    Mully[QUOTED] likes this.
