The Rubicon in September
Discussion in 'Off-Roading & Trails' started by Mikelax20, Jan 2, 2018.
  1. Jan 24, 2018 at 6:18 AM
    la0d0g
    running for the hills
    For crawling not hauling
    I've hit my passenger quarter panel on two different occasions. And both my doors one time but that was a stupid, I wasn't paying attention, avoidable moment :anonymous: :D
  2. Jan 24, 2018 at 7:55 AM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    I haven’t driven the Rubicon but have gone a long as a passenger twice. You can definitely make it through without body damage but I’ve seen a lot of bangs, dents and scrapes of doors, fenders, quarter panels. It is easy for the vehicle to slide into a boulder or scrape a quarter panel against a rock or boulder or a hundred other things. It’s definite challenging.
    TacoTRD78 likes this.
  3. Feb 4, 2018 at 4:37 PM
    dman100
    dman100 Well-Known Member
    Central Coast, California
    2016 TRD OR DCSB
    I’m not an expert. I’ve done 1.5 Rubicons and the last time was 20 years ago. The 0.5 was going in from Tahoe to Rubicon Springs, and out, the same day in a stock FJ80. Double locked, but stock ride height, 32” tires, and no armor. A few scratches, nothing bad, but that’s the easy part of the trail. The following year I did the entire TLCA Rubithon, with a 2” lift and some armor, and definitely picked up some dings and scrapes. The 80 is quite a bit smaller than a DCSB Taco. With your lift and tires it should be able to make it, but don’t expect totally damage free. My experience was that some narrow stretches and lines are optimized for Jeeps, and the side to side lean tip a wider, or less armored, vehicle into granite outcroppings that can scrape at vehicle belt line or higher. I cracked a flare and my buddy broke a tail light lens. I also creased my rocker panels when my ARB “sliders” bent up. 20 years later, and lots of 80’s run the trail all the time. At the time, folks thought it was huge.
    malburg114 likes this.
  4. Feb 4, 2018 at 7:39 PM
    Mikelax20
    Mikelax20 [OP] Well-Known Member
    Michael
    Salida, CO
    2014 Supercharged Sport
    Supercharger, trd exhaust, short shifter, OME Lift, RCI Skids, 33's, trd sport rims, CB, are topper.
    Well I guess if your gonna build them up you should let find out what there limits are.
  5. Feb 9, 2018 at 9:09 AM
    little squirt
    little squirt 808 ALLDAY!!
    808 ALLDAY!!
    As in what is nice to squirrel away? cv's, tie rods, ujoints?
  6. Feb 9, 2018 at 10:18 AM
    la0d0g
    CVs and inner and outer TRs. Toyota ujoints are strong so I don't take those but now I'm sure I've just jinxed myself. Some peeps take a spare driveshaft too.
    little squirt[QUOTED] likes this.
