The Ruffstuff NOT Universal 4 Link Kit!
Discussion in 'RuffStuff Specialties' started by Dan Fredrickson, Oct 15, 2012.
  1. Oct 15, 2012 at 9:05 AM
    Dan Fredrickson
    Dan Fredrickson [OP] Steel Hauler Vendor
    Dan
    Sacramento/Flagstaff
    '66 FJ45
    First off I should explain my thoughts so this dosen't sound too strange to you guys.
    A few years ago I started seeing brackets that completely disregarded all the rules about Link Suspensinons as we knew them to be. The changes that have come to be accepted as the way to do it no longer care about seperation, not vertical or linear. Did those rules change overnight? No, they didn't. What changed was a few companies saw a way to make things easier, for them and the many people that bought into the idea. Now every company making anything for link suspensions has these. Why don't we?
    We do not make a combination upper/lower link bracket with 4" (or less) of vertical seperation and no inches of linear seperation. I simply do not agree with it. It certainly makes installations easier but it also limits you to only what you can do using that type of bracket.
    Our Link Brackets are not holding you to any pre-determined limits. Our Link Brackets ALLOW you to make your rig work as well as you can design it. Not limiting you in any way.
    I know I am going to get some flack for this but I believe everyone is entitled to an opinion and this is mine. Anyway here they are, our new 4 Link Kits!
    For Framed Rigs
    This is it, everything in one package for a great price, and not low end stuff just to be cheap either! The kit is wrapped around 8 of our 1.25" Heat & Cryo Treated 78,000lb+ RSL Chromoly Heims with Stainless High Misalignment, Zink Plated Jam nuts, and 1.5" Tube ID Weld Bungs. Not a cartridge type joint in sight.
    The Upper Frame brackets are our 25 degree 5 way Adjustable link brackets. The Lower Frame brackets are our venerable Chassis Link brackets, time tested and proven for optimum performance.
    For the axle end we have our Axle Mount Link brackets and our New Truss that we have refined for additional strength while shedding uneeded pounds. On the Truss we keep it simple with 4 of our 3/8" thick Flat Bottomed Link Tabs.
    For Tube Chassis Rigs
    Everything on the axle is the same as the other but the tube side is different.
    The Upper Chassis brackets are our 10-35 Degree 5 Way Adjustable Tube Mount Link brackets. The Lower Chassis brackets are 10-35 Degree 3 way Adjustable Tube Mount Link brackets for optimum performance.
    The only choice you need to make is if the Truss needs to span a Large third member (D60, D70, 14 Bolt, Sterling, Eaton, Dodge 9.75, etc...) or a Medium sized third member (Ford 8.8, D44, Ford 9", Toyota, etc...). If you want to make more changes give us a call and we can see what we can do!
    http://www.ruffstuffspecialties.com/catalog/34LINK.html
  2. Oct 31, 2012 at 10:46 AM
    Dan Fredrickson
    Dan
    '66 FJ45
    A 4-link you want!
  3. Jan 14, 2013 at 9:15 AM
    Dan Fredrickson
    Dan
    '66 FJ45
    Finish your build with one of these!
  4. Feb 19, 2013 at 10:23 PM
    Dan Fredrickson
    Dan
    '66 FJ45
    Link it. You know your want to!:D
  5. Feb 19, 2013 at 10:34 PM
    Foihdzas
    Foihdzas VA7PTZ
    Danny
    B.C Canada
    2010 Dbl Cab 5' Box 6 Speed
    Extra fog lights behind grill, Pro Form rubberized undercoat, Fog lights on w/ high beams mod, Lighted 4wd switch, Husky Liners, 12v always on, Yellow wire mod, DEVIL HORNS BABY!! OME 886's Nitrochargers w/ 1.5" AAL with 1" lift block, Redline hood struts, front/rear winch wiring, Blue Sea systems Fuse Block, Spidertrax spacers, Wet Okle seat covers, ECGS front diff Bering Replacement Are LR UCA's right for me???
    Bump it
  6. Mar 5, 2013 at 9:38 AM
    Dan Fredrickson
    Dan
    '66 FJ45
    All in one kit at a price you can afford!
  7. Mar 5, 2013 at 9:43 AM
    Matic
    Matic Locked and Lifted "02" DC TRD.
    Rich
    Greenville,sc
    2002 TRD prerunner,SR5, doublecab
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate.
    Been a fan of "ruffstuff" for years from the NC4x4 page.
    Not ever buying from them......everything I have seen from them is top quality work.
    Bump for you Dan.
  8. Apr 8, 2013 at 9:46 AM
    Dan Fredrickson
    Dan
    '66 FJ45
    A 4 link is better than a no link!
  9. Apr 8, 2013 at 10:15 AM
    penguins_cc
    penguins_cc Well-Known Member
    Will
    Bellevue, WA
    Timberland Mica Limo!
    Perkins Performance Sliders, Warn 9000, Brute Force Fab front & rear bumper, OME/Dakar lift, full ATO skids and hi-lift mount, satoshi, Wet Okoles, illuminated 4x4 switch, Diff Breather.
    Coming from a total suspension newb who barely knows what a 4 link is, this looks cool as shit.
  10. May 14, 2013 at 9:39 AM
    Dan Fredrickson
    Dan
    '66 FJ45
    It just plain works!
  11. Jul 16, 2013 at 6:49 AM
    Dan Fredrickson
    Dan
    '66 FJ45
    A 4 link kit is just what you need!
  12. Jul 29, 2013 at 8:05 AM
    Dan Fredrickson
    Dan
    '66 FJ45
    Take your rig to a whole new level!
  13. Aug 19, 2013 at 7:23 AM
    Dan Fredrickson
    Dan
    '66 FJ45
    Ready to step your game up?
  14. Aug 24, 2013 at 10:54 AM
    Dan Fredrickson
    Dan
    '66 FJ45
    Hope everyone is having a great weekend!
  15. Sep 24, 2013 at 10:51 AM
    Dan Fredrickson
    Dan
    '66 FJ45
    A big deal when you need it!
  16. Oct 25, 2013 at 8:35 AM
    Dan Fredrickson
    Dan
    '66 FJ45
    It's Friday, so hopefully you guys have plans to hit the trails!
  17. Nov 12, 2013 at 6:44 AM
    Dan Fredrickson
    Dan
    '66 FJ45
    Build season is upon us, & a 4 link is just what you need!
  18. Jan 21, 2014 at 6:42 AM
    Dan Fredrickson
    Dan
    '66 FJ45
    When you think quality, you think RUFFSTUFF!
  19. Feb 3, 2014 at 7:40 AM
    Dan Fredrickson
    Dan
    '66 FJ45
    Get on this while our sale is going!
  20. Feb 22, 2014 at 11:33 AM
    Dan Fredrickson
    Dan
    '66 FJ45
    Hope you guys are having a great weekend so far!
