The Ruffstuff NOT Universal 4 Link Kit!
Discussion in 'RuffStuff Specialties' started by Dan Fredrickson, Oct 23, 2012.
  1. Oct 23, 2012 at 8:25 AM
    Dan Fredrickson
    Dan Fredrickson [OP] Steel Hauler Vendor
    Dan
    Sacramento/Flagstaff
    '66 FJ45
    First off I should explain my thoughts so this dosen't sound too strange to you guys.
    A few years ago I started seeing brackets that completely disregarded all the rules about Link Suspensinons as we knew them to be. The changes that have come to be accepted as the way to do it no longer care about seperation, not vertical or linear. Did those rules change overnight? No, they didn't. What changed was a few companies saw a way to make things easier, for them and the many people that bought into the idea. Now every company making anything for link suspensions has these. Why don't we?
    We do not make a combination upper/lower link bracket with 4" (or less) of vertical seperation and no inches of linear seperation. I simply do not agree with it. It certainly makes installations easier but it also limits you to only what you can do using that type of bracket.
    Our Link Brackets are not holding you to any pre-determined limits. Our Link Brackets ALLOW you to make your rig work as well as you can design it. Not limiting you in any way.
    I know I am going to get some flack for this but I believe everyone is entitled to an opinion and this is mine. Anyway here they are, our new 4 Link Kits!
    For Framed Rigs
    This is it, everything in one package for a great price, and not low end stuff just to be cheap either! The kit is wrapped around 8 of our 1.25" Heat & Cryo Treated 78,000lb+ RSL Chromoly Heims with Stainless High Misalignment, Zink Plated Jam nuts, and 1.5" Tube ID Weld Bungs. Not a cartridge type joint in sight.
    The Upper Frame brackets are our 25 degree 5 way Adjustable link brackets. The Lower Frame brackets are our venerable Chassis Link brackets, time tested and proven for optimum performance.
    For the axle end we have our Axle Mount Link brackets and our New Truss that we have refined for additional strength while shedding uneeded pounds. On the Truss we keep it simple with 4 of our 3/8" thick Flat Bottomed Link Tabs.
    For Tube Chassis Rigs
    Everything on the axle is the same as the other but the tube side is different.
    The Upper Chassis brackets are our 10-35 Degree 5 Way Adjustable Tube Mount Link brackets. The Lower Chassis brackets are 10-35 Degree 3 way Adjustable Tube Mount Link brackets for optimum performance.
    The only choice you need to make is if the Truss needs to span a Large third member (D60, D70, 14 Bolt, Sterling, Eaton, Dodge 9.75, etc...) or a Medium sized third member (Ford 8.8, D44, Ford 9", Toyota, etc...). If you want to make more changes give us a call and we can see what we can do!
    These are on Special @ $722.50 for the framed and $663 for the tubed as you see them, about 15% less Than normal prices...
    http://www.ruffstuffspecialties.com/catalog/34LINK.html
  2. Nov 4, 2012 at 6:52 PM
    Dan Fredrickson
    Dan
    '66 FJ45
    Ditch the leaf springs!
  3. Dec 10, 2012 at 8:16 AM
    Dan Fredrickson
    Dan
    '66 FJ45
    Thank you for all of the orders guys!
  4. Jan 2, 2013 at 10:56 AM
    Dan Fredrickson
    Dan
    '66 FJ45
    Upgrade to the RUFF STUFF!
  5. Feb 13, 2013 at 10:03 AM
    Dan Fredrickson
    Dan
    '66 FJ45
    The right way to link any rear end!
  6. Apr 27, 2013 at 9:55 AM
    Dan Fredrickson
    Dan
    '66 FJ45
    A link kit helps bring your rigs true potential out!
  7. May 10, 2013 at 9:03 AM
    Dan Fredrickson
    Dan
    '66 FJ45
    When swapping out that axle, swap in a 4 link kit to add articulation!
  8. Jun 7, 2013 at 7:48 AM
    Dan Fredrickson
    Dan
    '66 FJ45
    Time for an upgrade!
  9. Jun 19, 2013 at 10:22 AM
    Dan Fredrickson
    Dan
    '66 FJ45
    Nothing better than a linked suspension!
  10. Jul 20, 2013 at 6:44 AM
    Dan Fredrickson
    Dan
    '66 FJ45
    Don't leave home with a link kit under your rig ;)
  11. Aug 9, 2013 at 9:29 AM
    Dan Fredrickson
    Dan
    '66 FJ45
    You just can't go wrong with a 4 link!
  12. Aug 21, 2013 at 6:57 AM
    Dan Fredrickson
    Dan
    '66 FJ45
    Ready to give your offroad experience an upgrade?
  13. Sep 5, 2013 at 8:16 AM
    Dan Fredrickson
    Dan
    '66 FJ45
    The kit you don't want to skip on!
  14. Sep 12, 2013 at 11:01 AM
    Dan Fredrickson
    Dan
    '66 FJ45
    Thanks for keeping us so busy!
  15. Oct 2, 2013 at 10:44 AM
    Dan Fredrickson
    Dan
    '66 FJ45
    Build season is coming, get ready!
  16. Oct 15, 2013 at 9:46 AM
    Dan Fredrickson
    Dan
    '66 FJ45
    Trust me, this is good to have when you need it!
  17. Oct 28, 2013 at 7:59 AM
    Dan Fredrickson
    Dan
    '66 FJ45
    Thanks for another busy weekend guys!
  18. May 1, 2015 at 11:16 AM
    Dan Fredrickson
    Dan
    '66 FJ45
    Let's get this weekend started!
  19. Apr 1, 2016 at 9:57 AM
    Dan Fredrickson
    Dan
    '66 FJ45
    Friday at last!
