The SAE J581 Aux High Beam Thread
Discussion in 'Lighting' started by crashnburn80, Nov 28, 2020.
  1. Aug 16, 2021 at 1:44 PM
    #321
    Toy_Runner
    Toy_Runner Well-Known Member
    99 4Runner SR5
    3" OME lift, heavy coils f/r 3/16" steel skids Modified Coastal Offroad diy bumper 5spd swap ('98 donor)
    The max uses an expensive chip. I think Osram only produces limited quantities of the CULPM1.tg (boost HX 4040 footprint chip) as compared to their cslmp1 and cnlpm1 chips (the same 2mm^2 as the boost hx and 1mm^2 die, respectively). The cUlpm1 is a rather expensive LED, in comparison to the luxeon Z-ES (Sport) and Cree XPL-HI (Pro). So going from 4 leds, to 9 per lamp would be a pretty significant increase in price. The performance increase in a smaller form factor, going from the larger die of the XPL-HI to the smaller die of the culpm1 is worth it, as it focuses better, meaning you get the benefit of higher output and increased focus for their primary street legal lamp, as a Fog lamp.
    I could see them eventually switching to the osram cslpm1 LED, the boost just has better thermal characteristics. But that also means yet *another* pcb design, retooling and setting up for a 3x3mm footprint LED. If anything, they may be looking at Cree's new XP-P led, which should offer "similar" performance to the 1mm^2 cnlpm1 osram LED, but in the same 3.5x3.5mm PCB arrangement as the XPL-HI, meaning they would have potentially one board design with a few component changes, to provide the lower output/higher focus+intensity of the Luxeon z-es and the higher output of the XPL-HI. However the xp-p is new to the market and cree does not appear to have plans to offer it in much below 5000k color temps.
    What would solve this is if Cree were to offer the XP-G LED in a domeless "HI" format, as the higher efficiency bins of the XP-G2 offered similar surface intensity as the CULPM1 led when driven similarly (and de-domed, which a manufacturer like DD is not going to do, due to decreasing the lifespan of the chip, as well as potential for lots of damaged chips that must get tossed), it has a nominally 2mm^2 die (that is actually square, as opposed to slightly rectangular with the cUlpm and the cSlpm1). Given that they've just introduced the XP-P, I don't see them trying to market such an emitter yet though.
    mynameistory, Aws123 and Too Stroked like this.
  2. Aug 16, 2021 at 8:44 PM
    #322
    mynameistory
    mynameistory My member is well known
    Tory
    Redondo Beach, CA
    4Runner
    I'm hoping for an SS7. Current optic sizes will put this in about a 5 inch circle.
  3. Aug 16, 2021 at 9:07 PM
    #323
    Toy_Runner
    99 4Runner SR5
    Either arrangement, 3x3 or 7 will be about the same overall size. Both will be tricky, from a drive circuit, having to either boost to 21v/27v, or buck to multiple parallel strings of 9v (if 3x3 arrangement) from whatever input range. The 2x2 arrangement of the SS3 pods made for a nice buck only arrangement.
    mynameistory likes this.
  4. Sep 7, 2021 at 10:23 AM
    #324
    toledoupsguy
    toledoupsguy Well-Known Member
    Haskins OH
    2020 Ford F-150 platinum
    @memario1214
    SS3 max driving ordered. Haven't figured out how I'm going to mount them yet but might as well save a few pennies while trying to figure it out.
  5. Sep 7, 2021 at 10:26 AM
    #325
    toledoupsguy
    Haskins OH
    This harness does have to right connector for the SS3 pods doesn' it? No reason to pay DD $50 for theirs when this one is $21
  6. Sep 7, 2021 at 10:31 AM
    #326
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Well TECHNICALLY it's $42 during the sale here :p
    But yes that harness will work fine.
    crashnburn80[OP] likes this.
  7. Sep 7, 2021 at 10:54 AM
    #327
    toledoupsguy
    Haskins OH
    Since DD confirmed the price increase doesn't come with massage afterwards I'll save a few bucks.
    Thinking out loud, since I want to trigger them off the high beams anyway should I just get the BD hi beam tap harness and switch (or get adapters) out the WP plugs?
    https://hotshotoffroad.com/collecti...adron-s2-hi-beam-harness-2-lights-or-150w-max
  8. Sep 7, 2021 at 11:06 AM
    #328
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Yuk on that switch though.
  9. Sep 7, 2021 at 11:10 AM
    #329
    toledoupsguy
    Haskins OH
    wasn't planning on using it. Either tapping the hi beam or putting on a wireless receiver and using one of the homelink buttons on my sun visor.
    But, what would you recommend?
  10. Sep 7, 2021 at 11:13 AM
    #330
    daveeasa
    David
    PNW
    I'm a fan of the OEM small size switch in a blank but many of us run out of those super fast. It might be nice to have independent control, though a rocker would really be ideal, on, off and auto (based on high beam). Anytime Backup Camera has such rocker switches which fit the Tacoma.
  11. Sep 7, 2021 at 11:24 AM
    #331
    toledoupsguy
    Haskins OH
    If I had any of the Japanese brands that have blanks in switch panels your idea would be perfect. For us F150 guys the most bestest solution is adding the 6 switch panel from the Raptor nut that is a very high dollar solution. Having 2 unused homelike buttons available tied to wireless switches seems???? like a good idea.
  12. Sep 7, 2021 at 11:43 AM
    #332
    memario1214
    Colton
    Missoula, MT
    I mean... That's probably the easiest path.
    OR I'll literally GIVE you one of the normal BD switched harnesses (loyal customer perk :)) and you would just need to cut off the plug and tap the high beam circuit with that lead and change over the end plugs to go into the SS3s. The harness itself has plenty of headroom for a couple of SS3 Maxes.
    What? You don't like the spongy circle switches?
    I only kid... They're gross. I quit OEMs would quit using them.
  13. Sep 7, 2021 at 11:48 AM
    #333
    toledoupsguy
    Haskins OH
    Thank you, you da MAN
  14. Sep 7, 2021 at 12:03 PM
    #334
    memario1214
    Colton
    Missoula, MT
    :burnrubber::humble::cheers:
  15. Sep 9, 2021 at 8:34 AM
    #335
    The Wolves
    The Wolves Well-Known Member
    Los Angeles
    2010 DCLB TRD Sport 4x4
  16. Sep 9, 2021 at 8:39 AM
    #336
    memario1214
    Colton
    Missoula, MT
  17. Sep 9, 2021 at 8:42 AM
    #337
    toledoupsguy
    Haskins OH
    They have a 22" with the ECE certification
  18. Sep 9, 2021 at 8:42 AM
    #338
    The Wolves
    Los Angeles
    I just stumbled upon it. Be super curious to know the specs on it. I’m a big fan of the Front Runner stuff.
  19. Sep 9, 2021 at 8:54 AM
    #339
    The Wolves
    Los Angeles
    Yeah it looks like they released a whole bunch of lights recently. They have all sizes on there.
  20. Sep 9, 2021 at 9:47 AM
    #340
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    I have not seen that specific bar, but it appears to use the same mini reflector technology with an up-firing LED that Osram uses in their ECE bars. I'm not sure what they mean by "Double ECE R112 compliant". That bar seems awfully large to be ECE R112 compliant.
    See Osram's explanation of ECE R112 here, underneath their driving light bars: https://www.osram.com/am/campaigns/ledriving-working-and-driving-lights/truck_ledriving.jsp
    The Front Runner bar has this line under the specs, which makes me think they are measuring 2 separate outputs on the bar as 50 + 50, implying it would be ECE R112 compliant if you didn't use your factory high beams maybe:
    • Individual installation is possible due to the FX1000-CB SM's double ECE certification (ECE-Reference: 50+50; R112).
    Regardless of compliance, it is an interesting looking product and the first I've seen in that large of a format. I haven't yet tried our Osram/Sylvania's reflector based light bars, but the design in principle provides far more control than forward facing emitter bars, meaning you can get higher output intensity with lower power due to better focus similar to the reasons why KC's Gravity and Diode Dynamics TIR optics work so efficiently. The same design idea is used in many OEM automotive LED headlights, including the 3rd Gen Tacoma, though typically automotive headlights will use larger LED reflectors which offer more control and efficiency than smaller ones.
    Edit: Also definitely the proper thread. :)
