The SAE J581 Aux High Beam Thread
Discussion in 'Lighting' started by crashnburn80, Nov 28, 2020.
  1. Dec 1, 2022 at 4:59 AM
    #601
    DuffyBank
    DuffyBank Well-Known Member
    Big country Customs, Abbotsford, BC, I also have their front bumper and skid plates.
  2. Dec 1, 2022 at 4:02 PM
    #602
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    I'm getting some ideas for your old truck, @crashnburn80 :
    A pair of SSC2 Pro in selective yellow with clear driving pattern lenses. Flush mount into the grill as shown below. (This would avoid building a custom bracket to hold the non-flush version as well as having to have a meticulous cut in the grille to not look bad).
    If I actually go through with it, I would probably buy a knock off TRD Pro grill to cut up and leave the OEM one alone.
    They would match my SS3 selective yellow with clear lenses and headlights pretty dang well. Also, up here at headlight level, they should be placed well as opposed to running the hidden light bar in the lower grille.
    Too Stroked likes this.
  3. Dec 1, 2022 at 5:15 PM
    #603
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    Not that the 100w Osrams need a high beam boost, but could be nice to run with the low beam as supplemental highs rather than using the high beam. I'm fairly certain that plane on the grill is not vertical though vs being sloped back slightly, so if using a flush mount you'd have to shim out the top somehow so they are not pointing up at the trees, which could hamper the clean look and make proper aiming very difficult.
    I'd maybe try cutting the supports as pictured and mounting the lights in those locations. Mounting would certainly be a bit tricky, likely using a BAMF behind the grill mount with some flat metal stock extensions to get them up into the hole rather than sitting behind it. Just a thought.
    JasonLee[QUOTED] likes this.
  4. Dec 1, 2022 at 5:42 PM
    #604
    JasonLee
    15 TRD OffRoad
    Yeah, I left the shim part out but you're right that it probably won't look very clean, which would be the first thing on the truck making it start to look DIY and unpolished…
    That's an idea to supplement the low beams because sometimes the high beams make the retroreflective road signage on the side of the road too bright.
    I briefly thought about that but didn't want to cut up the OEM grille and then forgot about that when switching to the other idea with flush mount. That actually would work out fine and be less visually obtrusive than mounting the flush ones into the center "beam" of the TRD Pro grille. I'll do some more research on the BAMF light mount - I haven't looked at it in many years.
    I also thought about mounting the SSC2 Driving lights at the bottom of the A-pillar where most people put their ditch/flood lights, but I think it would light up and reflect off the hood and annoy me.
  5. Dec 1, 2022 at 6:00 PM
    #605
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    If you got the SSC1 Max Fogs, then swapped the optic for the driving, you'd have a tighter beam pattern with less potential for spill on the hood. Not a setup DD sells off the shelf, so there are no specs to judge what that would look like. In the fog optic, the SSC1 is supposed to be on par with the SS3 Sport.
    Another option is to go full behind the grill DD light bar. Don't need to cut the supports. Granted, the bar is an older design and optic than the SSC2 Pros, and it is a darker optic on a 6000k source, so it doesn't have the same efficiency advantages. I know there is posts somewhere I can dig up where we installed one on a friends 2015 Tacoma. Here is one post and another... and here it is. Not in in-depth review post though.
  6. Dec 1, 2022 at 6:17 PM
    #606
    DuffyBank
    I have 4k SSC3 with clear drying lens mounted to a BAMF behind the grill mount. I cut the grill easily with a hacksaw blades and a Dremel. Took about 20 minutes. The lights are headlight level and wired up as aux high beams
    Toy_Runner likes this.
  7. Dec 6, 2022 at 5:20 PM
    #607
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    antlab67, Toy_Runner and 907rx7 like this.
  8. Dec 6, 2022 at 5:23 PM
    #608
    Darthyota
    Darthyota Well-Known Member
    Alberta
    Blown BSP X-Runner
    TRD s/c @ 9lbs, Unobtanium Welding 321SS Full Race Exhaust, B&M s/s, TRD 1st Gen CAI, sittin sic track ready drop, TSW Tanka's with 275/40/18's all the way around, 4300k hid's in headlights and fogs, with more to come
  9. Dec 6, 2022 at 6:02 PM
    #609
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    not to be a total ass, but what of theirs' isn't
  10. Dec 6, 2022 at 6:52 PM
    #610
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
  11. Dec 8, 2022 at 4:01 PM
    #611
    Dtax
    Dtax Well-Known Member
    Massachusetts
    2017 Black Tacoma Sport
    Mods = N+1
    anyone know a good 30" light bar with amber or selective yellow on the outside and SAE driving beam in the middle and the ability to switch them independently?
    I found this Baja design one, but not sure if the center white light is SAE - i assume if it was it would jump off the page. (I emailed BD to confirm - waiting to hear)
    https://www.bajadesigns.com/products/onx6-straight-dual-control-led-light-bar/
    any insights are appreciated, thanks!
  12. Dec 8, 2022 at 4:45 PM
    #612
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    I do not. Yellow is only SAE compliant for J583 fog pattern, not J581 driving. It would seem unlikely that manufacturers going through the trouble for an SAE compliant bar would add a non-SAE compliant component, making it more challenging to sell as SAE. Bajas open bucket reflectors are definitely not SAE, even in white. I’d say the best bet is to use linkable lights, like that from Diode Dynamics or KC Pro6. You can then link the pods to build a bar, and for some use yellow driving lights in the case of DD, or use the amber covers in the case of KC. Morimoto and Baja also both offer linkable lights, but not an actual SAE style driving pattern if that is what you are looking for.
  13. Dec 8, 2022 at 4:58 PM
    #613
    Dtax
    Massachusetts
    Mods = N+1
    thank you = as always, very informative and appreciated. Was looking for aux high beams where the stealth light bar can go behind grill at the bottom.
    https://www.diodedynamics.com/2016-2023-toyota-tacoma-stealth-light-bar-kit.html
    Rigid makes one that is just the white light which i am curious about (which could be a way to go too since i have DD SS3 max yellow fogs already)
    https://www.rigidlightshop.com/p-27...ng-lights-sr-series-pro-rigid-industries.aspx
    would really appreciate your thoughts on Rigid in terms of quality, company, this product, etc.
    I was also thinking about making a bracket to mount some DD SS2s to go where the stealth light bar otherwise goes
    thank you
  14. Dec 8, 2022 at 5:59 PM
    #614
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    How important is actual compliance? Do you need to pass inspection? I ask because aux high beam is a pattern that should never be used with forward traffic, so other drivers should not be affected with proper use, unlike headlights or fogs that are left on with oncoming traffic. However, for street use, an SAE J581 style pattern is still important and beneficial, as it focuses the light on distance light to extend your visibility distance without flooding the near field in foreground light, which is limiting to your night distance vision and not something you want when driving on the street at night.
    Comparing a few options: Baja's open bucket reflector design is designed to give you that near field foreground light and the distance light, the foreground light is great for off road trails where you may want to see very close to the vehicle and can just leave it on for extended periods, but not something you'd want on the street. The Diode Dynamics 30" bar uses an SAE J581 aux high beam pattern, so it will focus on distance light while minimizing foreground light spill but the output intensity is actually too high for SAE compliance, as there is an output intensity limit for SAE J581. Their smaller 12" bar is SAE compliant. The Rigid 30" bar is actually SAE J581 compliant. SAE compliance is based on per lamp, so a 30" light bar is rated as one lamp even though it may occupy the space of 2 traditional lamps. Since the output compliance is by lamp, that means that having 2 lamps can have double the output and still be compliant vs a single lamp. So Rigid added a break in the center of the bar and claimed it as 2 individual lamps that are joined for compliance. Clever.
    Also note, be sure to look at Rigid products on the actual Rigid site for the most info. Rigidlightshop is not Rigid Industries.
    https://www.rigidindustries.com/sr-...auxilary-high-beam-driving-lights-930413.html
    If you look at the specs:
    Rigid SAE 30" bar, output intensity is 745 lux@10m.
    Diode Dynamics 12" SAE bar, output intensity is 1,110 lux@10m (Run 2 for proper SAE J581 compliance)
    https://www.diodedynamics.com/stage-series-12-sae-dot-white-light-bar-one.html
    Diode Dynamics 30" driving bar, output intensity is 2,750 lux@10m. SAE driving pattern, but not SAE compliant due to excess intensity
    https://www.diodedynamics.com/stage-series-30-white-light-bar.html
    If you want an SAE driving pattern, but strict compliance isn't needed, the DD 30" bar is the the most compelling, the output intensity is about 3.7x that of the Rigid bar. I haven't compared patterns, but the DD TIR optics are extremely efficient compared to the Rigid optics. You could also consider a DD 18" bar as well and look to mount it in the upper grill location with a behind the grill BAMF mount, which is more ideal than the lower valence in terms of position for a distance light, but depends on the void area in your grill.
    Lots of food for thought.
  15. Dec 8, 2022 at 6:07 PM
    #615
    Dtax
    Massachusetts
    Mods = N+1
    @crashnburn80 - wow - as usual! thank you very, very much. Great stuff to think about and really appreciate the time you take to reply.
    crashnburn80[OP] likes this.
  16. Dec 9, 2022 at 8:58 AM
    #616
    mynameistory
    mynameistory My member is well known
    Tory
    Redondo Beach, CA
    4Runner
    I always thought this implementation was cool- SS3s on an extruded slot bar (8020 style). Not quite as easy as the linkable SS5s, but a little more compact. You could wire a set of compliant driving pods symmetrically, then do what you want with the rest.
    You could also get two dual mounts, and on each one you could mount a compliant driving light and a yellow light. Then wire them up accordingly.
    Kovaci, TostadoNotATaco, Dtax and 2 others like this.
  17. Dec 9, 2022 at 9:32 AM
    #617
    Dtax
    Massachusetts
    Mods = N+1
    awesome ideas, appreciate the input. Gonna think on stuff. thank you.
  18. Dec 9, 2022 at 10:19 AM
    #618
    TostadoNotATaco
    TostadoNotATaco Active Member
    8Runner
    This was my plan if I ever do a light bar up top. SS5s are a bit too big. You can’t use the driving lights up top on road though can you?
  19. Dec 9, 2022 at 10:52 AM
    #619
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Nope. Wink, wink. I never use my SS5's on public roads. Wink, wink.
  20. Dec 9, 2022 at 1:07 PM
    #620
    TostadoNotATaco
    8Runner
    I was talking about the SS3s up top. I thought you couldn’t use driving lights mounted above your headlights?
