The SAE J581 Aux High Beam Thread
Discussion in 'Lighting' started by crashnburn80, Nov 28, 2020.
  1. Feb 12, 2021 at 3:22 PM
    #161
    Gettin Lost
    Gettin Lost Backwoods Rated
    Florida
    2021 TRDOR
    KDMax tune, eibach stage 2, ceramic tint, DD SS3 PRO fogs. Toyo AT3 285s
    Everything is stock so far. 2021, just got it a couple days ago.
    I've put in brighter fog lights on past Tacomas and the 4runner and it has helped. Even with the stock fogs and low beams the difference is very noticeable with the fogs on and off. With the fogs on I can actually see the ditch, with them off, I can only see straight LOL
    What recommendation would you suggest?
  2. Feb 12, 2021 at 3:32 PM
    #162
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Here’s what my gut is telling me... SS3 Pro kit for the Tacoma in a driving pattern in replacement of your fogs. White in color. And then either wire them up separate or do the fog light anytime mod so they can be run in conjunction with your high beams. You’ll get a significant improvement in down-road visibility. It’s more money than a set of bulbs for sure (you should have the LEDs now so not even possible anymore), but you’ll see a significant improvement in your scenario.
    And if you find that you get them and that beam pattern sucks you can always reach out to me directly and point me to this post... I’ll do you right on a different set of lenses should you need to swap.
    Gettin Lost[QUOTED] and daveeasa like this.
  3. Feb 12, 2021 at 3:41 PM
    #163
    Gettin Lost
    Florida
    2021 TRDOR
    I don't think I have LED lights in my fogs... They look like regular bulbs to me LOL
  4. Feb 12, 2021 at 3:44 PM
    #164
    mynameistory
    mynameistory My member is well known
    Tory
    Redondo Beach, CA
    4Runner
    Sounds like some driving lamps would be right up your alley. Here's my SS3 SAE pro driving lights.
    Fogs don't really help with animal strikes. If you're going fast enough to strike an animal, by the time you see it in your fogs it'll already be too late.
  5. Feb 12, 2021 at 3:49 PM
    #165
    memario1214
    Colton
    Missoula, MT
    100%. I had myself under the impression that all of the 21s had the LED fog lamps now. Learn something new every day! Same kit though for your application.
    Gettin Lost[QUOTED] likes this.
  6. Feb 12, 2021 at 3:56 PM
    #166
    indoomitable
    indoomitable Baby-steppin' down the stairs
    Texas
    2018 OR 4x4 DCSB
    I will never get tired of seeing your 4runner. So badass!
    And thanks for the previous writeup of how you wired your driving lights. Very ingenious, I'll be using that to guide my install which Im hoping to get done soon
  7. Feb 12, 2021 at 4:20 PM
    #167
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    LED headlights and fogs are optional on most of the upper spec trim levels. (Everything but SR, SR5) It's only a $500 option, but well worth it. Then again, the halogen headlights will melt snow. I'd suggest adding a set of SS3 Pro fogs plus a 30" Stage driving pattern bar. That would make a huge difference.
    Gettin Lost likes this.
  8. Feb 12, 2021 at 5:21 PM
    #168
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    For your case, I'd look at adding DD SS3 Pros with the combo lens or Baja Squadrons with a combo lens, knowing that you will not be able to turn on the fogs with other vehicles on the road as they are not fogs and will be blinding. The combos will also be ineffective in fog. I recommend the combo specifically for the flood/spread optic to illuminate further to the sides for the close range kamikaze deer.
    If you haven't already look at doing the Philips H9 low beam swap to double your headlight output.
  9. Feb 12, 2021 at 7:41 PM
    #169
    Gettin Lost
    Florida
    2021 TRDOR
    I'm not seeing the combo beam pattern for the Tacoma fog lights, only driving or fog... Am I missing something?
    Also, are the DD fog light kits just plug and play?
    Last question... for now, LOL, Are these the correct low beams? Part number 12361 / H9 ?
    https://www.amazon.com/dp/B003YMPN3...abc_F07ZPG7F40JFV5T3E8A0?_encoding=UTF8&psc=1
    I'm ready to order. Just trying to make sure I get the correct stuff the first time.
    Thanks again, and thank you to everyone else that's helping as well.
  10. Feb 12, 2021 at 7:45 PM
    #170
    Gettin Lost
    Florida
    2021 TRDOR
    Are your fog light kits in stock? I see on the DD site it says 6-8 weeks backordered, so figured I'd double check.
  11. Feb 12, 2021 at 7:49 PM
    #171
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    The combo lenses are available separately. I think just the SAE optics are sold for the fog mount kit (Driving/Fog).
    https://www.diodedynamics.com/clear-lens-for-ss3-pods-one.html
    Yes the fog kit is plug and play.
    Those Philips H9s are the ones! You will need to trim a plastic tab for them to plug into the H11 connector, only takes a minute with a small knife.
    daveeasa and Gettin Lost[QUOTED] like this.
  12. Feb 12, 2021 at 7:53 PM
    #172
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Yes those are good for the H9 mod for low beams. Some buy from rock auto which may come out a little cheaper when purchasing 2 pair:
    https://www.rockauto.com/en/parts/philips,H9,headlamp+bulb,11701
    Yes DD Tacoma kit is PnP as it comes with a pigtail adaptor from OEM connector to the DD pod which I believe uses deutsch?
    I think the combo optic is super new so not overly surprising there isn't a ton of doc on it yet:
  13. Feb 12, 2021 at 8:02 PM
    #173
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Combo optic review here in post #3793.
    Gettin Lost and daveeasa[QUOTED] like this.
  14. Feb 12, 2021 at 8:06 PM
    #174
    daveeasa
    David
    PNW
    Ah, I remember skimming that and promptly forgetting most of it in the hype of the MAX which you just casually dropped right when I was buying some pros...
  15. Feb 12, 2021 at 8:12 PM
    #175
    Spike Spiegel
    Spike Spiegel Well-Known Member
    2019 Super White Toyota 4Runner TRD Off-road Premium
    Eibach Pro Truck Lift, JBA High Caster UCA’s, Falken Wildpeak 275/70/17, Spidertrax Spacers
    I'll have to slap the spot lenses on the MAX pods for science.
    When I'm not 4 beers deep...:cheers:
  16. Feb 12, 2021 at 8:18 PM
    #176
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Covered in post #3770. DD Sport spots beat Bajas lasers in peak intensity due to the highly efficient TIR optics. The Max spots are far higher and just absurd.
  17. Feb 12, 2021 at 8:18 PM
    #177
    memario1214
    Colton
    Missoula, MT
    In. Stock. :thumbsup:
  18. Feb 12, 2021 at 8:29 PM
    #178
    Gettin Lost
    Florida
    2021 TRDOR
    I'm guessing you don't have those combo optic lenses?
  19. Feb 12, 2021 at 8:35 PM
    #179
    Gettin Lost
    Florida
    2021 TRDOR
    Sweet T4R. This was mine... A 2019... I missed having a truck too much and I'm back with another Tacoma. Though the T4R was an awesome vehicle. Suspension lift, welded on sliders, steel skids, 285s, full audio upgrade and other little things... I'll miss it.
  20. Feb 12, 2021 at 9:09 PM
    #180
    memario1214
    Colton
    Missoula, MT
    Of course I do. To be specific 16 clear combo lenses showed up today. :D
