The search for the engine squeal continues...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Schultz0462, Mar 20, 2024.
  1. Mar 20, 2024 at 3:59 AM
    Schultz0462
    Schultz0462 [OP] Well-Known Member
    Memphis, TN
    2017 Tacoma 4x4
    2017 Tacoma SR 4x4 with 121,xxx miles. I noticed a squeal from the motor, once it was warm, and brought it to the dealership to utilize my extended warranty. Under warranty the idler pulley and serpentine belt were replaced. The squeal continues.
    I'm posting a video in an attempt to capture it for diagnosis. If you have time I'd appreciate a listen. There's driveline noise which I'm not concerned with, it's the high pitched squeaking I'm trying to locate. I was thinking it was another pulley, but could some type of vacuum leak cause this? Once again it only seems to happen when the motor is warm.
    https://youtube.com/shorts/Fq4zCEDkfQs?si=fG4SLpB-Pl56NWPk
    Capespencer68 likes this.
  2. Mar 20, 2024 at 4:08 AM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Sounds like the high pressure fuel pump.
    Hard to tell from the video, but is the chirping or peep sound more prominent on the passenger side?
    kahanabob and eurowner like this.
  3. Mar 20, 2024 at 5:31 AM
    Schultz0462
    Memphis, TN
    2017 Tacoma 4x4
    It does seem to be louder on the passenger side, yes.
    I would've never thought of the high pressure fuel pump.
    eurowner likes this.
  4. Mar 20, 2024 at 5:32 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    That’s almost guaranteed the HPFP.
  5. Mar 20, 2024 at 8:12 AM
    Schultz0462
    Memphis, TN
    2017 Tacoma 4x4
    Thank you guys. What’s replacement look like of the HPFP? I’m currently visiting Orange Beach, AL.
    plasticsnaks likes this.
  6. Mar 14, 2025 at 6:54 PM
    Capespencer68
    Capespencer68 Well-Known Member
    Scott
    Massachusetts
    2021 DCSB AG Trail edition
    Did you ever locate the issue?
  7. Mar 14, 2025 at 6:59 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
  8. Mar 14, 2025 at 7:15 PM
    Schultz0462
    Memphis, TN
    2017 Tacoma 4x4
    I sure did. It was the high pressure fuel pump.
  9. Mar 14, 2025 at 7:17 PM
    BLtheP
    Plano, TX
    Did you replace it or end up switching to ethanol free fuel or just living with it? Mine started to chirp bad and I fixed that with ethanol free.
  10. Mar 14, 2025 at 7:20 PM
    Schultz0462
    Memphis, TN
    2017 Tacoma 4x4
    I had it replaced under the extended warranty I purchased when I bought the vehicle.
    After they replaced ALL the pulleys I brought it back, with the same squeal, and let them know my stethoscope had told me it was coming from the HPFP. They utilized theirs and decided it was, in fact, the HPFP.
