the shakes when braking
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JWSTLMN, Apr 28, 2010.
  1. Apr 28, 2010 at 11:37 AM
    JWSTLMN
    JWSTLMN [OP] Member
    Alabama
    DC LB SPORT 4X4
    brush guard KC HILITES BFG T/A KO
    Need some help. When i apply the brakes (running 60 to 80), the steering wheel shakes bad. could it be the rotors??
  2. Apr 28, 2010 at 11:38 AM
    MAXTacoma
    MAXTacoma Well-Known Member
    Lexus GS 350
    That would be my first guess!
  3. Apr 28, 2010 at 11:39 AM
    nad
    nad mmmm tacos!
    Jordan
    Canada
    2014 Sierra All Terrain
    most likely the rotors
  4. Apr 28, 2010 at 11:40 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
  5. Apr 28, 2010 at 11:42 AM
    JWSTLMN
    JWSTLMN [OP] Member
    Alabama
    DC LB SPORT 4X4
    thanks, i will have them turned.
  6. Apr 28, 2010 at 11:46 AM
    MHS2846bg8
    MHS2846bg8 Experienced Noob
    Nate
    South Coast of Oregon
    08 Tacoma TRD Dbl Cab 4x4 MT
    That's good to know...having same problem with my 01. Thought it might have been the abs system...just had an inspection done on my truck and no problems arose...guess ill check it myself
  7. Apr 28, 2010 at 12:10 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Turning them is a waste of money. They will warp shortly again. Replace with new rotors and if you had overheated brakes I would suggest looking for drilled rotors and ceramic pads.:)
  8. Apr 28, 2010 at 12:12 PM
    MHS2846bg8
    Nate
    Aww and we just missed out on the group buy on the slotted rotors!
  9. Apr 28, 2010 at 12:14 PM
    MGH-PA
    MGH-PA Well-Known Member
    Northcentral, PA
    05 Tacoma TRD AC 4x4
    265/75/16 Nitto Terra Grapplers, Bestop
    Yep, most likely rotors.
  10. Apr 28, 2010 at 12:22 PM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Just replace the rotors. I just replaced my front two because my brakes started squeaking after I replaced just the pads. I had to come back two weeks later and do the rotors. I think it was $89 for both front rotors from advance auto parts. Pretty easy job...took about 20 minutes to replace.
    obvious step number 0 : jack up the truck and use jack stands
    1.Remove wheel:
    2.Remove two caliper bracket bolts from hub (can't remember if they are 17mm or 19mm) (helps if you turn the steering wheel depending on what side, gives me room to use my impact gun)
    3.take a 12mm bolt and thread it into the small holes to pop the rotor loose from the hub. (I had to do this with one, the other popped loose with a few taps of the mini sledge)
    4.put new rotor on.
    5.put caliper back on and tighten the caliper bracket bolts
    6.put wheel back on
    7. lower vehicle off jack
    8. Have a beer...or six
    9. go enjoy your new rotors free of vibration (suggest waiting a few hours if you opted for the six beers)
    Also if you haven't done your brake pads..go ahead and replace those too. I think I paid $35 for new front pads.
