The "shutter" and the "check engine"
Discussion in '1st Gen. Tacomas (1995-2004)' started by bobmartin, Aug 31, 2010.
  1. Aug 31, 2010 at 10:29 AM
    bobmartin
    bobmartin [OP] New Member
    Houston, TX
    99 Prerunner SR5
    Deck plate
    I hit about 55mph and the truck started to shutter and the engine light came on. Hooked it to the laptop and it said there was a misfire in cylinder 2. I've changed all the spark plugs, wires, and swapped two coils around just to try to diagnose. Still having the same problem with the lack of power and a heavy shutter. Check engine light is on and off and sometimes flashes. All I know now is to start checking fuel injectors. I ran a bottle of Lucas through the gas tank with no luck. Do I pull the injectors and ultrasonic them? replace them? Anything else?
  2. Aug 31, 2010 at 1:49 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    WHat code did you get? Did you do any research online for that code?
  3. Aug 31, 2010 at 1:56 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    Your piston rings might be fried and your experiencing blow by which would explain lack of power and possibly the shutter
  4. Sep 1, 2010 at 5:34 AM
    350TacoZilla
    350TacoZilla Well-Known Member
    Hancock MD
    1997 3RZ 5spd 4x4 Reg Cab
    2.7L 3RZ,K&N filter, 4" deck plate mod,flowmaster 40 series,3" suspension lift, hybrid 52"chevy/toyota rear springs.
    I would start with injectors.. do what you did for coils swap one with another if the problem moves then thats the cause..
  5. Sep 1, 2010 at 5:49 AM
    98tacoma27
    Ben
    Not Beech Creek
    It's going to be a 300 series code. Tons of things can cause this. Seeing how you have eliminated the plugs and wires, i would check the following:
    In order of easiest to hardest.
    • Connector connection
    • Vacuum hose connection​
    • PCV hose connection​
    • PCV hose​
    • Mass air flow meter (clean it) ​
    • Injector
    • Fuel pressure​
    • EGR system (Only for 3RZ–FE)​
    • Ignition system
    • Engine coolant temp. sensor​
    • Compression pressure​
    • Valve clearance​
    • Valve timing​
    • ECM
    It could also be a cam or crank sensor.
  6. Sep 1, 2010 at 5:55 AM
    Space Wrangler
    Space Wrangler Well-Known Member
    JCT
    Ga
    04 DC 4x4
    04 Tacoma 4x4 Double Cab SAW 2.0's Alcan's Ion 171 wheels 15x8 (-27mm bs) 32" BFG AT's
    make sure there is ZERO moisture anywhere near the plug boot or in the spark plug hole. ...i washed my truck and a day later had the exact same symptom. ..i had cylinder 3 misfire. i swapped plugs, changed wires, ect. ..turnd out to be condensation in the hole the spark plug goes in.
