The SKINNY on skinny tires
Discussion in 'Wheels & Tires' started by LadyRed, Jan 19, 2018.
  1. Sep 29, 2019 at 1:56 AM
    #2081
    Nicklovin
    Nicklovin Mall Crawlin Through Life
    Nick
    Huntington Beach, CA
    00 The Tunda - 0̶4̶ P̶r̶e̶r̶u̶n̶n̶e̶r̶ - 0̶1̶ O̶v̶e̶r̶l̶a̶n̶d̶e̶r̶ - 07 FJ Mall Crawler Xtrme
    Tacoless
    Thanks but I asked about regular A/Ts not M/Ts, main reason for going skinnys is to somewhat save mpg so a mud terrain wouldn’t really help me out. Wish bfg made an AT skinny though, I love bfg.
    4.5 backspace good to know thanks. I’m probably going to get some new wheels so trying to figure out what’s perfect for this setup. Oh and pretty sure I’m gonna so some clearing with a BFH regardless
  2. Sep 29, 2019 at 2:14 AM
    #2082
    Navigator1
    Navigator1 Assistant to the Regional Manager
    Spokane WA
    18 TRDORDCLBCEMENT
    I didn’t see any mention of towing characteristics with the skinnys. I’m currently on 265/75/16 Duratracs at 45 lbs each. I’m looking to possibly go to 255/80/17 Falkens. Weight wise their only about 7 lbs heavier so I guess I’m more worried about the effective higher gear I would be facing. Any opinions or experiences towing with the 33” skinny’s?
    Edit: I’m in the PNW so mountains are a thing. Also only towing a 2-3k lb boat.
  3. Sep 29, 2019 at 8:10 PM
    #2083
    bzzr2
    bzzr2 Well-Known Member
    I run the Toyo MT's, my mileage is quite good considering the tire, I really notice no MPG difference from having falken 265's before these, only differences are the Toyo's drive better, look better, more better better!
    anyway you want 17's you mention, BFG makes 34x10.5r17 KO2's. their dimensions are identical to the Toyo MT. looks like you're all set.
    Casper66 likes this.
  4. Sep 29, 2019 at 8:15 PM
    #2084
    Nicklovin
    Nick
    Tacoless
    :anonymous: I wish I could get 34s. Maybe when I get a new daily, then I'll do something fun/stupid with the truck
    Also probably gonna get the coopers when america's tires big sale happens in november
  5. Sep 29, 2019 at 8:20 PM
    #2085
    bzzr2
    do some research, they measure 33.5, just like the toyo 255's, the bfg km3 are 33.3, the cooper st maxx are 32.8 and so are the dick cepeks, the falken 255's are 33.1, so are the toyo at2 i believe.
    so if you want skinny 33 why not just get the ones you want now? get at it.
  6. Sep 29, 2019 at 10:04 PM
    #2086
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    I noticed a difference before and after. I have M55 skinnies. In the hills, the truck has a harder time staying in 4th with the converter locked. I tow a 3000 lb travel trailer. I’m on the cusp of wanting a regear. Around town the power is down but it’s still drivable.
    Navigator1[QUOTED] likes this.
  7. Sep 30, 2019 at 6:20 AM
    #2087
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Picking up a set of SCS Ray 10's in 17x9 and I want to put 255/80/17 Cooper St Maxx on them. I am lifted 3 inches in front and currently have OEM Trail Wheels with 255/75/17's on them with zero rub. Below is the specs to the wheels, what will be needed to prevent rubbing? I have mud flaps on currently as well.
    17 X 9 6 X 139.7 3.50" -38mm 25lb 14oz
  8. Sep 30, 2019 at 6:56 AM
    #2088
    Hairy Taco
    Hairy Taco Jungle of Love
    North of Hell
    08 TRD
    255's on a 9" wide rim seems like a bit of a stretch. Will them be within Cooper recommended wheel specs?
  9. Sep 30, 2019 at 7:05 AM
    #2089
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Hmmmmmmmmmm thanks for that. Research again.
  10. Sep 30, 2019 at 7:06 AM
    #2090
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Says rim range is 6.5 to 9
    Hairy Taco[QUOTED] likes this.
  11. Sep 30, 2019 at 7:17 AM
    #2091
    Hairy Taco
    North of Hell
    08 TRD
    good to go. Given the specs on SCS wheels, I suspect you will, at the least, need to lose your front mud flaps to remedy the rub. Maybe more, like fender trimming. If you want to keep your flaps, you might consider keeping the Toyota rims.
    Perhaps one day SCS will produce some 7-8" wide wheels with their oh-so-sweet design and finish.
  12. Sep 30, 2019 at 7:20 AM
    #2092
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Yeah I would like to keep my mud flaps on. Thank you sir
  13. Sep 30, 2019 at 7:22 AM
    #2093
    JCWages
    JCWages Well-Known Member
    Grass Valley, CA
    2018 GMC Canyon SLE 4x4
    King 2.5 coilovers, 33s, steel bumpers and stuff.
    Most manufacturers don't recommend a 255 on a 9" rim. If all you are doing is street cruising it would be fine but for aggressive off-road and especially sand it is not a wise choice. That's the main reason I haven't tried a 255/80/17 on my DV8 17x9s. I'd love to get rid of my frame rubbing issue (GM problem, not a Taco problem) but I won't trade rubbing for bead seat issues and more wheel damage. I wish there were more options for a 265/75/17 or 275/75/17. :)
  14. Sep 30, 2019 at 7:28 AM
    #2094
    Hairy Taco
    North of Hell
    08 TRD
    I have the more common 17x8.5" SCS Wheels. When I first got them I ran 265 70-17 and I had to lose the flaps and trim a bunch. Its the aggressive offset/backspacing more than the tires that create the issues it seems. I also run a 3" lift
    Perhaps some folks with your actual combo will speak up.
  15. Sep 30, 2019 at 7:33 AM
    #2095
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
  16. Sep 30, 2019 at 7:47 AM
    #2096
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    '15 DCSB TRD Sport 4wd super white (sold) '13 access cab SR5 4wd
    piddly stuff
    For 255’s? Huh I was thinking 8” wide
  17. Sep 30, 2019 at 7:49 AM
    #2097
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Just going by what it shows on DTD
    Casper66[QUOTED] likes this.
  18. Sep 30, 2019 at 7:51 AM
    #2098
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    There is not much difference from a 265/70/17 and a 255/75/17 I could just put 265/70/17's on them as summer wheels
  19. Sep 30, 2019 at 7:56 AM
    #2099
    Hairy Taco
    North of Hell
    08 TRD
    SCS wheels are particularly nice. I have 2 sets, the Stealth 6 and the SR8. I just love 'em so would never steer you away from them.
  20. Sep 30, 2019 at 8:07 AM
    #2100
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    So I would imagine a 265/70/17 would be fine then?
