The SKINNY on skinny tires
Discussion in 'Wheels & Tires' started by LadyRed, Jan 19, 2018.
  1. Nov 12, 2019 at 7:43 AM
    #2341
    Clay7160
    Clay7160 Well-Known Member
    2018 MGM TRDOR DCLB 4x4
    GYEON ceramic coating
    Very quiet - easy to balance - lightest 255/85/16 available. A friend that owns mechanic shop installs lots of them, runs them on 3500 lifted dodge diesel and pulls quite often with them and he is still pleased.
    TacoIII[QUOTED] likes this.
  2. Nov 12, 2019 at 4:22 PM
    #2342
    snowtaco2
    snowtaco2 Well-Known Member
    Nobody
    Middle Of USA
    2018 OR BBP
    Stock for now
    The 33x10.50R17LT 121 R KR601 10P weighs 46.87 lb per tire.
    This is the response I got from kenda when I emailed them
  3. Nov 12, 2019 at 5:51 PM
    #2343
    JAStaco
    JAStaco Well-Known Member
    MT
    2013 Tacoma DCLB
    Elka 2.5 RR w/ adjusters front and rear, JBA UCA's, Icon RXT, SEMA 4R pro wheels, Meso Customs interior lights, Wheeler's Superbumps front and rear
    @GladiatorNOT was told 47lbs when he emailed Kenda directly. Unfortunately he wasn't able to get a weight on his set prior to installing. That's extremely light for an E rated tire. Pretty crazy if it's true given the D rated 35 is 62lbs.
    Navigator1[QUOTED] likes this.
  4. Nov 12, 2019 at 6:54 PM
    #2344
    Navigator1
    Navigator1 Assistant to the Regional Manager
    Spokane WA
    18 TRDORDCLBCEMENT
    Well even if it falls between that and the 52 lbs that Amazon says it’s got to be the lightest tire in that rating and size range. Thanks.
  5. Nov 13, 2019 at 4:41 AM
    #2345
    jerzsubbie
    jerzsubbie Well-Known Member
    Davidson, NC
    ‘13 GX460
    I just came here to mention the Kenda Klever 33x10.5 offerings, but you guys are already on it.
    I’ll need tires sometime in 2020 so I’ve begun researching and am between RidgeGrappler 255/80/17 and this new Kenda RT 33/10.5/17. If I had an appetite to regear, I’d do the 35x10.5’s.
  6. Nov 13, 2019 at 5:00 AM
    #2346
    Taco-Grinder
    Dan
    Fond du Lac, WI
    On my 2013 I have 2 1/4 lift in the front and 2 inch in the rear. 255/75/17 mounted on 17×8.5 Ray 10s
    dirtnsmores, Kolter45, RickS and 2 others like this.
  7. Nov 13, 2019 at 6:29 AM
    #2347
    mac84
    mac84 Well-Known Member
    Alabama
    2015 Tacoma TRD Sport 4WD MGM
    Exactly what I needed... thank you!
    Taco-Grinder likes this.
  8. Nov 13, 2019 at 6:35 AM
    #2348
    bzzr2
    bzzr2 Well-Known Member
    Light means thin construction to me. Great for pavement use but maybe not as ideal for severe trail use
    JCWages likes this.
  9. Nov 13, 2019 at 1:59 PM
    #2349
    jerzsubbie
    Davidson, NC
    ‘13 GX460
    You have to find that happy medium. Too heavy and you lose flexibility and grip that you really want when aired down on the trail. But yes, too light and you have poor durability.
  10. Nov 14, 2019 at 11:44 AM
    #2350
    bzzr2
    All of the 2nd gen and forward Tacomas are heavy enough to run the beefiest of the 255 tires. Radial tires aired down enough are gonna flex and grip well with our rigs! Now a heavy bias ply tire under a suzuki samurai is a different story. The Toyo 255’s are the heaviest of the bumch here and they flexed and formed great under my 2018 access cab. Ran them on a much lighter 2dr jk for much more severe wheeling than the Tacoma would ever do and they worked wonderfully.
  11. Nov 15, 2019 at 8:09 PM
    #2351
    gr8tacsprt10
    gr8tacsprt10 Well-Known Member
    Vince
    Kirtland AFB, New Mexico
    Going the skinny route.. installing 255/75/17 bfg mud terrains tomorrow
  12. Nov 16, 2019 at 10:13 AM
    #2352
    gr8tacsprt10
    Vince
    So far I like em..
    dirtnsmores, Kolter45, RobP62 and 5 others like this.
  13. Nov 16, 2019 at 11:20 AM
    #2353
    Taco-Grinder
    Dan
    Fond du Lac, WI
    Looks nice :thumbsup:
    RobP62 likes this.
  14. Nov 16, 2019 at 11:44 AM
    #2354
    Sna
    Sna Well-Known Member
    Alberta
    ‘15 trd sport 6MT dcsb, mostly stock?
    Have had the 255/85R16 Dick Cepek Extreme Country tires on 3rd gen 16” Toyota TRD wheels for a while and they have been very good so far. Just a few updated pictures of the truck. Lost some go with the bigger wheels but will be re-gearing next year.
  15. Nov 19, 2019 at 9:31 AM
    #2355
    Arctic Taco
    Arctic Taco Firefly, Serenity Ed. -Arctic Taco, a slow build
    Denali Park, Alaska
    98 Tacoma Xtra Cab DLX, 85 Toyota LWB 4x4
    dents and missing bits, built in the Gravel garage, hillbilly trained mechanic…
    Finally got the right combo, 235/85 R16 Toyo ATll on stock 16x7” OEM spare steelies, rides better and seems to wear better than the 16x8” Tundra steelies...
    Time will tell, but I like the look.919D98A4-9D51-425A-ADE5-083F2E8B554E.jpg Tundra 16x8” steelies C874C27C-F892-4B1D-8400-FB1256E69748.jpgStock OEM spare 16x7”
    Kolter45, Boghog1, RobP62 and 5 others like this.
  16. Nov 19, 2019 at 3:49 PM
    #2356
    Rexfordian13
    Rexfordian13 Well-Known Member
    J
    Albany/NY Capital District
    2015 TRD Sport DCSB MT
    Finally ordered Cooper Discoverer ST Maxx today to be installed next week. 255/85/16
    fingers crossed they work out...5 of them.
    RobP62 and Sna like this.
  17. Nov 19, 2019 at 5:34 PM
    #2357
    gr8tacsprt10
    Vince
    What PSI do you guys run best on 255/75/17?
  18. Nov 19, 2019 at 5:41 PM
    #2358
    IvanhoeTaco
    IvanhoeTaco Well-Known Member
    Eastern NC
    2005 Supercharged Converted Prerunner
    Total Chaos 3.5 LT, King Coilovers, 35x11.5r17 on Falcon T2, ADV 4 inch fiberglass, 4.88 gears, FJ cruiser transfer case, 4 runner front diff, Cab mount relocate, archive hangers, shackles, king 2.5x14 rear shocks, icon rxt leaf springs, king hydro bumps
    I run my nexens at 35psi in the winter
  19. Nov 19, 2019 at 5:42 PM
    #2359
    IvanhoeTaco
    Eastern NC
  20. Nov 19, 2019 at 8:51 PM
    #2360
    Adude
    Adude Well-Known Member
    Pnw
    04 Double cab
    16x7 oem steels kick ass.
