The SKINNY on skinny tires
Discussion in 'Wheels & Tires' started by LadyRed, Jan 19, 2018.
  1. Jan 19, 2020 at 8:15 AM
    #2561
    50tree
    50tree Well-Known Member
    Portland, OR
    2017 Tacoma TRD OR 4x4 DC-SB
    None yet, that's why I'm here now
    No spacers, I’m planning on getting a swing out for the rear, so I did not have the spare put underneath. I have read that you can get it to fit. You can search for it and a few comments about it comes up.
    Captbrad88[QUOTED] and RobP62 like this.
  2. Jan 19, 2020 at 8:21 PM
    #2562
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Yea, the OEM on mine are great road tires but my first impression in a couple inches of snow is not very promising.
  3. Jan 20, 2020 at 8:11 PM
    #2563
    lude9285
    lude9285 Member
    Do any or all of these sizes fit on stock suspension without rubbing issues?
    I have a 2019 Off Road DCLB. I’d like to put them on a set up SCS f5 wheels. I’m open to 16” or 17”.
    255/85/16
    255/75/17
    255/80/17
  4. Jan 20, 2020 at 8:22 PM
    #2564
    2DaMtns
    2DaMtns Well-Known Member
    2011 TRD Sport DCLB in MGM
    Lift, tires, stuff
    I don't know if the geometry and fitment are different on the third gens, but I have the OME 2.5" lift and 255/80/17s on my 2011. It also has an ARB bumper and winch. They rub a little on the corner of the fender flare and inner fender on the outside part of the rear portion of the front wheel wells.
  5. Jan 22, 2020 at 6:17 AM
    #2565
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    Ive read in this thread that 255/85r16 or 255/80r17 will rub a bit on the fender liner.
    For those of you running this tire size, can the rubbing be resolved with a heat gun?
    Also, how’s the rubbing off road?
    Much appreciated :cheers:
    Kolter45 and RobP62 like this.
  6. Jan 22, 2020 at 11:58 AM
    #2566
    Sensitometry
    Sensitometry Member
    Steven
    16’ Dclb Tacoma trd4x4
    I’m looking for a used or spare Cooper tire STT pro discover LT235/85R16 and thought this thread might be a useful resource. I got a great deal on them and they helped get me introduced to 4wheeling.
    well a couple weekends ago I got a small gash in one tire and, though it holds air, it makes a bubble when driving at highway speeds. So it’s off the truck and I’m on my original wrangler as a spare.
    I know it’s a long shot, just looking to see if anyone has a used or spare tire they don’t need and want to sell.
    I’m located in north Orange County.
    [edit - also something I’ve learned and others should note is that using a tire size smaller than what the truck recommends voids the warranty on these tires. Tires sizes equal to or larger do have warranty.]
    RobP62 likes this.
  7. Jan 23, 2020 at 2:42 PM
    #2567
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Welcome to the forum! :hattip:
    Make sure you check the B/S/T section and local threads for OC areas. Craigslist is also a good resource, as well as Facebook Marketplace.
  8. Jan 24, 2020 at 7:04 PM
    #2568
    AZ_Tumbleweed
    AZ_Tumbleweed Well-Known Member
    Wilmington, NC
    2020 TRD OR DCSB Cement 4x4 AT
    Just got my Maxxis 255/85/16s put on my 2020 OR tonight. Walmart took almost 4 hours to mount them and broke two of my TPMS sensors....
    RobP62 likes this.
  9. Jan 24, 2020 at 7:27 PM
    #2569
    Norsemanvike
    Norsemanvike Well-Known Member
    Escondido, CA
    '18 Sport 4x4, DblCb, ShBd, BBP
    Are they replacing the sensors?
    RobP62 likes this.
  10. Jan 24, 2020 at 7:35 PM
    #2570
    AZ_Tumbleweed
    Wilmington, NC
    Yea they will. They got some generic valve stems from oreillys for now and will be ordering two replacement TPMS.
    Typically i would go to discount tire but the tires from walmart were cheap and the $25 hazard warranty/lifetime balancing is too good to pass up
    RobP62 and Norsemanvike[QUOTED] like this.
  11. Jan 24, 2020 at 8:58 PM
    #2571
    AZ_Tumbleweed
    Wilmington, NC
    Also what PSI do you guys typically keep your 255/85/16s at? These are 8 ply, load range D and Walmart filled them to 65 psi which is the max tire PSI.
    Im use to having 35" KM2 and KM3s which i ran at 28psi on my Jeep so im not sure if its normal to run such a has PSI on these truck tires
    RobP62 likes this.
  12. Jan 24, 2020 at 9:58 PM
    #2572
    JCWages
    JCWages Well-Known Member
    Grass Valley, CA
    2018 GMC Canyon SLE 4x4
    King 2.5 coilovers, 33s, steel bumpers and stuff.
    It's not. That pressure is way too high unless you're carry a massive load. Most run something between 28psi and 35psi depending on their weight.
    Jasonstacoma, RobP62 and Casper66 like this.
  13. Jan 25, 2020 at 9:26 AM
    #2573
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    35 would be a good place to start.
    Hot Taco sauce, JCWages and RobP62 like this.
  14. Jan 25, 2020 at 9:54 AM
    #2574
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    That blows. Any resolution?
  15. Jan 25, 2020 at 10:24 AM
    #2575
    Rexfordian13
    Rexfordian13 Well-Known Member
    J
    Albany/NY Capital District
    2015 TRD Sport DCSB MT
    Yes, it does. I am keeping an eye on exhaust heat...its a little close to the pipe.
  16. Jan 25, 2020 at 11:52 AM
    #2576
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Use simple math to determine the correct PSI.
    Follow this example replacing the numbers here with those from your truck and tires. A long time ago, a member on here used the same method and it was spot on. I looked for it but found this instead. Same principle
    Calculate Tire Pressure
    After talking to a few guys about tire pressure, I was worried. Everyone seems to have a different opinion on tire pressures when converting from a p-metric tire to an LT tire. Many say you are fine to go by what is written on the door, which is not always correct.
    Here is how I personally calculate tire pressure. You need to get the specs from YOUR tire on the sidewall.
    The XXXXX has a curb weight of 5,690lbs. We need to add some weight because we have 1-2 people, bumper(s), winch, sliders, heavier tires, wheels, skid plates, lights, roof rack, etc.
    I don't want to have to calculate all of that, so lets just round up to 6,000 lbs.
    6000/4 = 1500 lbs per tire.
    The XXXXX TIRES in XXX/XXRXX are rated at 3,640 lbs @ XX psi. EACH.
    If you take 1500/3640 = .412
    That means that I am loading up 42% of what the tire can handle (these are load range E tires -- some of you only have D tires).
    Now, if you take 42% of 80 PSI you get 33.6.
    That means that I should be running NO LESS than ~34 PSI in each tire.
    To play it safe, I will run 35PSI and give me some leeway
    Haji DontSurf likes this.
  17. Jan 25, 2020 at 12:27 PM
    #2577
    RocTaco
    RocTaco Free stun!
    Pete
    Green Mtns
    21' SR5 Trail AG
    Unfortunately it's not that simple.
    Really what you need to is figure out what the load rating for your stock tires is, and look up the load table for the tire you want to put on. That will tell you the psi needed to maintain the carrying capacity of the OEM.Screenshot_20200125-151846.jpg
    Using your method yields a pressure of 37-38psi, which according to this would be inadequate.
    Link for the entire PDF here
    https://www.google.com/url?sa=t&sou...FjASegQIBxAF&usg=AOvVaw0zaHumL9xB01d0CRYFLPCS
    Haji DontSurf and RobP62[QUOTED] like this.
  18. Jan 25, 2020 at 2:00 PM
    #2578
    boston23
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    Shouldnt the chalk line test tell you if theyre properly inflated?
    Haji DontSurf and RobP62 like this.
  19. Jan 25, 2020 at 2:14 PM
    #2579
    Sharpish
    Brian
    30 will have better grip, less power to the ground and a softer ride. 40 will have better gas mileage and lower turning effort at the expense of bumpy hard ride.
    35 is just right
  20. Jan 27, 2020 at 2:34 PM
    #2580
    AZ_Tumbleweed
    Wilmington, NC
    Update:
    My Maxxis bighorn do rub a bit in the front at full flex :(
    RobP62 and Brownie_Man like this.
