The SKINNY on skinny tires
Discussion in 'Wheels & Tires' started by LadyRed, Jan 19, 2018.
  1. Mar 21, 2021 at 2:00 PM
    #3741
    Poncate
    Poncate Well-Known Member
    PNW
    04 DCSB 4x4
    Got my 255/80r17 Coopers mounted up last week!
    jpm99338, darthsside, devale and 10 others like this.
  2. Mar 22, 2021 at 7:55 AM
    #3742
    Kerbouchard!
    Kerbouchard! Well-Known Member
    Englewood, CO
    fishin' tank
    No idea. I ordered mine last Friday. Will post some pics once they're installed.
    Swartzy165[QUOTED] likes this.
  3. Mar 22, 2021 at 6:44 PM
    #3743
    Dampahee
    Dampahee Well-Known Member
    So Cal
    2019 TRD Off Road
    Fox Factory 2.5 extended travel w/DSC Eibach 650x14 springs Fox Factory 2.5 x 12 in smoothies with rr and DSC / Accutune Adventure tune Archive Garage shock relocation Archive Garage hammer hangers with 3.6" shackles Archive Garage high clearance cross bar Deaver Expedition u402 stage1leaf pack Camburg Racing Uniball UCA's Total Chaos Gusseted Spindles Marlin Crawler HD LCA/cam tabs Frame Brace gussets @weldstaco front diff reinforment kit Wheelers u-bolt flip kit with super-bumps Crown performance SS 24 in extended rear brake lines SS extended front break lines Exhaust re-route mod Dirt King Cab Mount Relocation OV Tune-91 Performance Nitro 5.29 Gears ARB Front Locking Differential ARB High output in board compressor Slee On-board compressor mount Blais Bros Taco differential breather mod Schmellfab 12.5° sliders with kick out RCI steel IFS skid RCI steel transmission skid RCI steel T-case skid RCI LCA skid BAMF Rear differential skid Relentless Fabrication hybrid front bumper Relentless Fab High Clearance rear bumper ATHF rear fender supports SOS performance rear disc brake conversion Trimmed Fenders 2.5" Softopper TRD Heritage grill RFT Raptor lights Morimoto XB headlights Baja Designs amber S2 flush mount chase lights Baja Designs S8 30 in lightbar Cali Raised Relay Mount Cali Raised cubby switch mount Smittybuilt X20 10 k winch Factor 55 Fairlead Factor 55 Flatlink E Factor 55 Flatlink Ropeguard Tandem Off Road Manor winch solenoid mount 1.25 inch Spidertrax wheel spacers 17x9 Ultra Wheel x103 beadlocks 35/11.5/17 Nitto Trail Grapplers Fend-X Wheel Liners Clazzio leather seat covers Taco Garage DMM Mount Taco Garage Anytime Front/Rear Camera MESO Customs Chrome Delete MESO Extended fuse cover AVS in channel low-profile wind visors Kicker CS tweeters, 6x9, 6.5's Kicker Key amp Kilmat sound deadening
    Skinny-ish 35's maybe, 35/11.5 trail grapplers. Awesome tire all around, been very pleased with them.
  4. Mar 22, 2021 at 7:07 PM
    #3744
    Poncate
    PNW
    04 DCSB 4x4
    Cool photo
  5. Mar 22, 2021 at 7:12 PM
    #3745
    Dampahee
    So Cal
    2019 TRD Off Road
  6. Mar 22, 2021 at 7:15 PM
    #3746
    JMcFly
    JMcFly Well-Known Member
    Central FL
    2012 Tacoma SR5 4x4
    I like the skinny
    Dampahee[QUOTED] likes this.
  7. Mar 22, 2021 at 7:30 PM
    #3747
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    Sick buddy
  8. Mar 22, 2021 at 7:45 PM
    #3748
    Dampahee
    So Cal
    2019 TRD Off Road
    Thanks man!
    Same. They've been good to me.
  9. Mar 22, 2021 at 7:56 PM
    #3749
    BountyOR_VF2
    BountyOR_VF2 "If in doubt, flat out!"
    NorCal Bay Area
    2017 WHITE TRD TCSB OR
    Very Nice!~!
    BadDad69! likes this.
  10. Mar 23, 2021 at 8:00 AM
    #3750
    Kerbouchard!
    Englewood, CO
    fishin' tank
    2 of 5 33x10.50 Kenda Klevers came In yesterday. They look goooood.
    I did some measuring. They are for sure not true 33s. They’re 32 inches tall on the dot. My 265/70/17s are worn down to just over 30”, so these will be a big improvement.
    The pic by the truck is super distorted.
    taco kai, Ovrlnd Taco, devale and 6 others like this.
  11. Mar 23, 2021 at 4:36 PM
    #3751
    Juspat2
    Juspat2 Well-Known Member
    Justin
    MatSu, Alaska
    2016 Black TRD Sport Access
    Nice - what are you running tire wise? 255s?
  12. Mar 23, 2021 at 5:09 PM
    #3752
    Saturnine
    Saturnine YVAN EHT NIOJ
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    Real world weights: 255/85r16 dick cepek extreme country. Scale may not be 100% accurate but it's close, if not right on
    Juisebocks, devale and somebody like this.
  13. Mar 23, 2021 at 8:13 PM
    #3753
    Astr0Aar0n
    Astr0Aar0n Well-Known Member
    Portland, OR
    19' Tacoma TRD OR V6 4x4 DCSB cavalry blue
    Quite a few things at this point..
    Yup, 255/85r16
    Juspat2[QUOTED] likes this.
  14. Mar 23, 2021 at 8:34 PM
    #3754
    tacotroy17
    tacotroy17 Well-Known Member
    Dustin
    SoCal
    2017 DCSB TRD-OR
    Do you know what the weight of these is?
  15. Mar 23, 2021 at 10:41 PM
    #3755
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    60lbs per tire!
    tacotroy17[QUOTED] likes this.
  16. Mar 23, 2021 at 10:45 PM
    #3756
    Buttskevin21
    Kevin
    Washington
    Stock-ish
    Been running the 33x10.5x17 Kenda Klever Rts for the last 5k miles, they are phenomenal. Fairly quite, handle wet roads well, and work awesome in the snow and on snow covered roads. I've plowed snow up to the headlights with them, and they do well on pnw trails. Wrapped my outer bead in duct tape, so havent had any problems airing down to the single digits in the snow with my 8.5 wide wheels. No real sign of wear yet, just some trail rash here and there. Going to Moab next month so I'll see how they do on some real rock
  17. Mar 23, 2021 at 11:44 PM
    #3757
    tacotroy17
    Dustin
    SoCal
    2017 DCSB TRD-OR
    Thank you!
  18. Mar 24, 2021 at 3:38 AM
    #3758
    AStinkyBumb
    AStinkyBumb Well-Known Member
    Indiana
    2013 DCLB SR5 4x4
    man all these good reviews on the Kenda Klever's is starting to wear on me. I was sold on wildpeaks until I saw these. I would LOVE to do their 35/10.5/17 but dont want to regear and lose the spare space under the bed at the same time. I am heavily considering these Kenda's now after reading tons of good reviews here and on other sites.
  19. Mar 24, 2021 at 6:38 AM
    #3759
    Kerbouchard!
    Englewood, CO
    fishin' tank
    Correct, I just put one of mine on a bathroom scale. It read 62.8.
    Buttskevin21[QUOTED] likes this.
  20. Mar 24, 2021 at 6:48 AM
    #3760
    Buttskevin21
    Kevin
    Washington
    Stock-ish
    You cant beat the price either, for some reason when I got mine, they were $169 a tire for the 33 on Simpletire.com. I think they are around 200 a tire now though
