The SKINNY on skinny tires
Discussion in 'Wheels & Tires' started by LadyRed, Jan 19, 2018.
  1. Apr 7, 2021 at 7:45 AM
    #3881
    AStinkyBumb
    AStinkyBumb Well-Known Member
    Indiana
    2013 DCLB SR5 4x4
    Either of you guys have issues getting them balanced or did they add a ton of weights to the wheels to get them to balance? Mine have tons of little light weights on the inside of my wheels.
  2. Apr 7, 2021 at 7:56 AM
    #3882
    Kerbouchard!
    Kerbouchard! Well-Known Member
    Englewood, CO
    fishin' tank
    No issues balancing. The weights on my wheel look to be an average amount. Actually I think there's about half the amount of weights on the Klevers as when I had my Grabbers installed.
    I tell you one thing...at 20#s more per tire, I can definitely feel the difference.
  3. Apr 7, 2021 at 9:14 AM
    #3883
    montanacruiser
    montanacruiser Well-Known Member
    2017 DCLB Off Road
    Do these fit with out the cmc? Right now I am stock but will be going up 2" also does anyone know the weight?
  4. Apr 7, 2021 at 9:24 AM
    #3884
    tacotroy17
    tacotroy17 Well-Known Member
    Dustin
    SoCal
    2017 DCSB TRD-OR
    From what I have read, people are running them without CMC. I'll see how my truck accepts them. They come in around 60 lbs.
    Ovrlnd Taco likes this.
  5. Apr 7, 2021 at 9:28 AM
    #3885
    Sand_In_My_Taco
    Sand_In_My_Taco Well-Known Member
    NOR*CAL
    2025 1794 Tundra TRD-OR
    No CMC required.
  6. Apr 7, 2021 at 9:28 AM
    #3886
    montijo505
    montijo505 Moon soon?
    Rio Rancho, New Mexico
    08 4Runner SR5/ AKA The Great White Pig
    Damn those are heavy. I’m intrigued by the price but the 34x10.5 KO2’s I believe are around 52lbs.
  7. Apr 7, 2021 at 9:36 AM
    #3887
    Kerbouchard!
    Englewood, CO
    fishin' tank
    Yep, they're 10 ply rated with 3 ply sidewalls. Thicc boys.
    My bathroom scale showed 62.3 lbs. I have a 2" inch lift and am no where close to needing the cmc.
  8. Apr 7, 2021 at 9:40 AM
    #3888
    5465
    5465 Well-Known Member
    South
    2023 TRD Ex Cab
    That pretty light for a 34” tire with more than basic street treads. My old setup on my 2019 with Nitto’s in 285/75/16 (34”) were 65lbs each.
  9. Apr 7, 2021 at 10:17 AM
    #3889
    Silverlogic
    Silverlogic Well-Known Member
    Tyler
    San Diego, California
    2018 Silver DCSB TRDOR
    I was looking at the 34x10.5 KO2's but I couldn't find them anywhere for less than like $350 a tire, which is outrageous.
  10. Apr 7, 2021 at 10:35 AM
    #3890
    AStinkyBumb
    Indiana
    2013 DCLB SR5 4x4
    Yeah these are my first meaty tire I have ever owned. I can feel the ripples at low speeds on asphalt then at highway speed I can definitely feel the road more. Wife even mentioned the suspension felt rougher. I know beefier tires are harder to balance than low profile car tires but wasnt sure what "normal" was.
  11. Apr 7, 2021 at 10:40 AM
    #3891
    AStinkyBumb
    Indiana
    2013 DCLB SR5 4x4
    Yep I'm around 2.5" lift in the front, haven't CMC'd or done pinch weld and have zero contact lock to lock with zero offset 17x8.5 wheels. I did hear it rub something plastic while going over a curb earlier this week but that was nothing regular driving would see. I am sure I need to remove the coil and test at full stuff to see if I need to trim plastic wheel well or heat it and re mold it.
  12. Apr 7, 2021 at 10:47 AM
    #3892
    montijo505
    God bless I just checked and you’re right, they’re ridiculous. The more I look at them I’m leaning towards 255/80/17 Toyo Open County RT. Measures 33” and weighs 56lbs.
  13. Apr 7, 2021 at 11:03 AM
    #3893
    Sand_In_My_Taco
    NOR*CAL
    Check your tire pressure. Having it too high will make you hate these tires.
  14. Apr 7, 2021 at 11:07 AM
    #3894
    tacotroy17
    Dustin
    SoCal
    2017 DCSB TRD-OR
    I'm coming from 10 ply 265/70r17 ridge grapplers so the weight isn't much different on my end.
  15. Apr 7, 2021 at 11:18 AM
    #3895
    montijo505
    I had Nitto MT’s before and didn’t mind. I’ve gotten spoiled with these P rated Wildpeaks though. So light and nice on the road, but I’m always worried about popping one in the dirt. Guess I’ll just have to get over the weight lol.
  16. Apr 7, 2021 at 12:45 PM
    #3896
    Discount Tire
    Discount Tire Tire & Wheel Specialists Vendor
    Arizona, USA
    At this time we are not able to order the Kenda Truck tires, however you are correct we are able to get the UTV and some trailer tires.
  17. Apr 7, 2021 at 2:40 PM
    #3897
    Kerbouchard!
    Englewood, CO
    fishin' tank
    What are you running yours at? I had mine mounted and balanced last week. The shop inflated to 38 psi. I haven't checked to see if there's a better recommendation.
  18. Apr 7, 2021 at 2:56 PM
    #3898
    montijo505
    do a chalk test. Easy and useful
    doublethebass likes this.
  19. Apr 7, 2021 at 3:04 PM
    #3899
    Kerbouchard!
    Englewood, CO
    fishin' tank
    Man, who has chalk just layin' around these days?
    barf likes this.
  20. Apr 7, 2021 at 3:12 PM
    #3900
    Sand_In_My_Taco
    NOR*CAL
    32 up front, 28 in the rear.
    Chalked.
    TOYO Open country MTs
