The SKINNY on skinny tires
Discussion in 'Wheels & Tires' started by LadyRed, Jan 19, 2018.
  1. Sep 24, 2021 at 7:35 AM
    #4501
    E.J.
    E.J. International Overlander
    Josh
    NWA
    2017 White Tacoma TRD Off Road
    AM-JKLWKZup14sTR-bhG0ml3F9cEYgVCks7XC6Cw_6d7ba2694e37f9135fc45c173618502dcb9c858f.jpg
    AM-JKLWO3koUAiR2_GF0OQpiqXjcDPO2dEU2VnPC_d50ed6ac1dfaf33e1dfbbd47e92c3f115b541986.jpg
    AM-JKLV7m2rZjWxeo62FaiESeIIRsep0CBJRnaK8_b85f688eb1cee31c8366b402e8a0f284befaafa1.jpg
    A couple of weeks ago while prepping for a trip I found some sidewall damage on one of my old 255/85 16 STMaxx. I had wanted to do Toyo MT's next but they wouldn't have come in time so I rolled the dice on these 255/85 16 Falken Wildpeak MT01's. So far they aren't any louder than my old Coopers were with 8/32nds tread depth (they had just hit that point where they get louder). Anyway I immediately put 2,300k miles on them on a trip to Colorado, not bad on the highway and pretty great on the dirt. Thumbs up so far, will have to see how long they last.
  2. Sep 24, 2021 at 7:47 AM
    #4502
    grantacoma123
    grantacoma123 Well-Known Member
    Grant
    2020 Tacoma Sport
    Do you have any rubbing with those? I have 17” wheels, but have 255/75s and am wondering if I should make the move to 255/80
  3. Sep 24, 2021 at 7:51 AM
    #4503
    E.J.
    Josh
    NWA
    None, and when the STMaxx were first installed the truck was at stock height. Seems like rubbing issues have more to do with tire width and wheel offset than with height.
  4. Sep 24, 2021 at 8:35 AM
    #4504
    grantacoma123
    Grant
    2020 Tacoma Sport
    Dang, good to hear.. I only have about 5000 on mine right now. Wishing ai had just pulled the trigger on the 255/80s instead but was worried about possible rubbing
  5. Sep 24, 2021 at 11:42 AM
    #4505
    Brownmatthall
    Brownmatthall Well-Known Member
    Saratoga Springs, NY
    2016 TRD OR DCSB
    Those wildpeak mt's are most likely gonna be my next tire very soon, do you see snow at all?
  6. Sep 24, 2021 at 12:08 PM
    #4506
    E.J.
    Josh
    NWA
    I'm in NW Arkansas so not much at all.
  7. Sep 24, 2021 at 12:23 PM
    #4507
    Brownmatthall
    2016 TRD OR DCSB
    Womp, been nervous about how an MT will perform in the winter up here but the tread seems similar to the wildpeak ATs I'm running now so I'm hoping they're in the ballpark of those
  8. Sep 24, 2021 at 12:40 PM
    #4508
    clenkeit
    clenkeit Well-Known Member
    Colin
    Lakewood, CA
    2010 White DCLB TRD Sport
    Am I just a noob who doesn't know any better? Or was the damage worse than the pic makes it look? Based on what I'm seeing I would not have ran out and replaced those tires.
  9. Sep 24, 2021 at 2:17 PM
    #4509
    Ovrlnd Taco
    Ovrlnd Taco Well-Known Member
    Conrad
    Madison, WI
    2020 Tacoma TRD Offroad
    Stage 4 IVD lift, CBI Bed Bars, CBI Ditch brackets, Rigid DSS Lights, Switch Pros 9100, 255/85/16 MT01
    I just got the Wildpeak MT01 in 255/85/16. I live in Madison, WI. So I can let you know how they are once winter rolls around.
  10. Sep 24, 2021 at 2:38 PM
    #4510
    Brownmatthall
    2016 TRD OR DCSB
    I'll have mine before winter, we can suffer together :cheers:
    Ovrlnd Taco[QUOTED] likes this.
  11. Sep 24, 2021 at 3:13 PM
    #4511
    E.J.
    Josh
    NWA
    Normally I would have run them a little while longer, but I wasn't going to head out over 1k miles from home on it.
  12. Sep 25, 2021 at 9:42 PM
    #4512
    106
    106 Well-Known Member
    '21 DCLB TRD Off Road - Army Green
    I visited Hollister Hills today and found a lot of rubbing under flex and certain turning conditions. Mainly drivers side.
    I haven't decided with which suspension pieces to go with yet but now I have more pressure to just pull the trigger. Forcing function :)
  13. Sep 25, 2021 at 9:51 PM
    #4513
    Saturnine
    Saturnine YVAN EHT NIOJ
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    It'll be fine in deep powder and slush and less so on ice or hard pack. Tread is less important than siping, which MT generally have less or none of
    Brownmatthall[QUOTED] likes this.
  14. Sep 25, 2021 at 10:31 PM
    #4514
    DuffyBank
    DuffyBank Well-Known Member
    235/85/16 DuraTracs
    JDSmith, E.J., Siebermd and 2 others like this.
  15. Sep 25, 2021 at 11:31 PM
    #4515
    bzzr2
    bzzr2 Well-Known Member
    I have had 2 sets of the ST Maxx’s and three sets of the AT3W’s. I feel the AT3W’s are quite a bit better for winter driving conditions. I will either get another set of the same next spring or try the new Toyo 255’s.
    Jonofthehills[QUOTED] likes this.
  16. Sep 25, 2021 at 11:41 PM
    #4516
    bzzr2
    I hand siped my Toyo MT 255’s, just the centre treads, it made a massive difference! I had made a 2000km trip with snowy conditions for 3/4 of it, promptly went and picked up a tire groover and got at it. I wouldn’t recommend it though, the tires seemed to dry rot in the centre area over the winter. I did buy a 2nd set of these also but wouldn’t buy them again.
  17. Sep 26, 2021 at 6:27 AM
    #4517
    DuffyBank
    I now have my tires siped whenever I buy new ones. It is my work truck for the bush and I'm replacing tires every two years anyways, so a little additional wear isn't an issue.
    Guy at the tire shop delivering my keys after the latest new set "siped pizza cutters, you'll go anywhere this winter."
    bzzr2 and Brownmatthall like this.
  18. Sep 26, 2021 at 6:41 AM
    #4518
    TacoPandaTRD
    TacoPandaTRD Well-Known Member
    TacoPandaTRD
    Chilliwack, British Columbia, Canada
    2020 Toyota Tacoma TRD Off-Road
    Always looking to modify! Check out my Instagram @TacoPandaTRD
    How have I not come across this forum before :eek: I’ve been on pizza cutters for the past 6 months. Rocking 255/80r17 Falken Wildpeak AT3W. They have been a phenomenal tire on and off-road. I’ve had other Wildpeak sizes before but never a skinny and I’m actually really enjoying them. I don’t think I’ll ever swap to a wider tire, unless it’s a 35” pizza cutter. This was me eyeballing my buddies 35x10.5 Kenda Klever
  19. Sep 26, 2021 at 12:35 PM
    #4519
    Jonofthehills
    Jonofthehills Well-Known Member
    Arcata, CA
    15 trd 4x4
    Nice. Thanks for the feedback. The new Toyo in 255/80/17 look promising. Not many ratings on them yet, but the price and weight (51lb/tire) look good. Decent looking winter capabilities too.
    bzzr2[QUOTED] likes this.
  20. Sep 26, 2021 at 12:37 PM
    #4520
    patdeezy
    patdeezy Well-Known Member
    souLcaL
    '19 OR 4x4 SuperWhite DCSB
    That Kenda Klever sidewall looks so interesting haha
    TacoPandaTRD[QUOTED] likes this.
