The SKINNY on skinny tires
Discussion in 'Wheels & Tires' started by LadyRed, Jan 19, 2018.
  1. Apr 19, 2023 at 4:45 AM
    #5861
    asanelli
    asanelli Well-Known Member
    Tony
    Golden CO
    3rd Gen Tacoma TRD Offroad
    Has anyone experienced their 255s are more prone to side strikes and hits while on the trail / rock crawling causing alignment issues due to not be as buoyant?
    Have you had buoyancy issues?
  2. Apr 19, 2023 at 8:08 AM
    #5862
    dirtnsmores
    dirtnsmores A camping truck
    Southern California
    06 DCLB Prerunner
    OME885/5100, DAKAR MED-DUTY, SOFTOPPER
  3. Apr 19, 2023 at 9:29 AM
    #5863
    montijo505
    montijo505 Moon soon?
    Rio Rancho, New Mexico
    08 4Runner SR5/ AKA The Great White Pig
  4. Apr 19, 2023 at 9:53 AM
    #5864
    PTSDTherapy
    PTSDTherapy Well-Known Member
    22 SR5 DCSB
    I read thru this thread a few months ago and seem to recall someone saying that 235/85/16 fit the spare tire holder without modification. I can’t for the life of me find it now. Anyone know if that size does indeed fit without modding the carrier? Thanks
  5. Apr 19, 2023 at 10:23 AM
    #5865
    ME OFF Rd
    ME OFF Rd Well-Known Member
    Jim
    Maine
    2013 TRD Off Road Edition
    - Digital Fit WeatherTechs - OME 885x Coils w/ Bilstein 5100's @ 0" - Rear Bilstein 5100's with ToyTec 2" AAL
    235? That should fit just fine, That is around the same size a stock tire just skinny.
  6. Apr 19, 2023 at 11:47 AM
    #5866
    PTSDTherapy
    22 SR5 DCSB
    Thanks for the reply. I asked because of the diameter difference 30.5 vs 31.7. Getting new tires while on an excursion and don’t want to have to do parking lot mods to get my spare to fit.
    Would be awesome if we could put this in a sticky with all the different tire sizes that fit with no modification and then those that fit with modification and what is needed to accomplish fitment.
    kylehorvath and Road_Warrior like this.
  7. Apr 19, 2023 at 4:20 PM
    #5867
    DuffyBank
    DuffyBank Well-Known Member
    Yes, no issues. That is what I have
  8. Apr 19, 2023 at 11:06 PM
    #5868
    JonWB
    JonWB Well-Known Member
    Jon
    Idaho
    2018 TRD OR Access Cab
    I really appreciate this response. Thank you. I just found the tire pressure calculator online that does indeed show 37psi from the OEM conversion. I also noticed that all the tire pressure charts for the C load only go down to 35, so that’s a good point.
    I spent months going back and forth between which tires I wanted. I think the 255/75’s in C are a good match for the Tacoma. In the end, I couldn’t justify the mass and weight of the 285/70r17’s. I think I would have also been happy with a 275/70, but the Toyo’s were only in load E, and I was intrigued about the concept of a skinny. The truck does not feel any more sluggish to me coming from an SL 265/75r16, and so far the overall traction has been really good.
    I can’t be much help regarding fitment on a stock setup as I have about 2” up front and negative offset. My front mud flaps had to come off with the -10, but it’s possible that would be the case even at stock offset.
    montijo505 and BLtheP[QUOTED] like this.
  9. Apr 20, 2023 at 3:39 PM
    #5869
    montijo505
    That calculator blew my mind because it said 35 for my 285 Duratracs, which is what they chalk tested out to
  10. Apr 20, 2023 at 3:56 PM
    #5870
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Informationally, the tire pressure calculator said I need to run 35 psi. Chalk testing put my pressure at 30, which I have been running for a year with perfect tread wear. Additionally, it says my car needs 35psi, while ive been running 37 voa chalk testing. Not sure it's as encompassingly accurate as some might think.
    TartanEagle likes this.
  11. Apr 20, 2023 at 4:00 PM
    #5871
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Are you 100% sure you used it perfectly? It’s based on pure math that stems from the factory tire pressure and builds upon the exact load rating a tire is physically built to carry at a certain pressure based on its characteristics….don’t see how it could be inaccurate.
    I do see lots of folks use the calculator incorrectly. Also, tires are probably not as picky about perfect pressure anyways. A few psi low or high likely isn’t going to have a huge long term effect. There are also many people who don’t know how to chalk test properly either….so lots of variables. Not implying you don’t know how to chalk your tires or use the calculator, just asking.
    And as stated earlier, 35 will be the minimum recommendation if using metric LTs because they are not rated below that.
    BC Hunter likes this.
  12. Apr 20, 2023 at 4:18 PM
    #5872
    DuffyBank
    The calculator is designed on the theoretical model of the tire ratings, not the tire.
  13. Apr 20, 2023 at 4:23 PM
    #5873
    BLtheP
    Plano, TX
    Should be plenty close enough unless a tire is horribly out of spec.
  14. Apr 20, 2023 at 4:26 PM
    #5874
    DuffyBank
    It sets data points for ratings, how a manufacturer meets or exceeds those data points will vary.
    It also ignores varying tire pressure based on road and load conditions.
    chris4x4 likes this.
  15. Apr 20, 2023 at 4:33 PM
    #5875
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yeah, I used it correctly.
  16. Apr 20, 2023 at 4:54 PM
    #5876
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    THAT could be the case. OEM tires were a Load C range, and the ones I have now are E. Considering I fluctuate between D and E rated tires, the chalk test is fine for me.
    BLtheP[QUOTED] likes this.
  17. Apr 20, 2023 at 5:01 PM
    #5877
    BLtheP
    Plano, TX
    If factory pressure was not a lot more than 35, and factory were LTs, if you upsized in LTs then it would make sense that you found 30 to be best. In that scenario the calc will not tell you to go below 35, due to liability. Larger tires need less pressure so eventually you hit the floor of 35 despite the larger tires probably needing less. Just a guess anyways but I’m assuming you upsized tires or else you’d probably run factory pressure.
    chris4x4[QUOTED] likes this.
  18. Apr 20, 2023 at 5:03 PM
    #5878
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I did. Factory was 32's, and I went to 34's.
    AmateurTaco1313 likes this.
  19. Apr 21, 2023 at 10:41 AM
    #5879
    Maxx
    Maxx Well-Known Member
  20. Apr 25, 2023 at 8:25 PM
    #5880
    Dusty T.
    Dusty T. Well-Known Member
    Portland, OR
    2002 Tacoma 4x4 TRD; 2003 Honda Element
    Anyone able to fit a 255 in the stock spare location on a FIRST GEN with the factory hitch? The wings/mounts need to be modified of course which I already did somewhat to fit the 265's. Searched this thread and saw a couple first gen posts but not a ton of detail of what they did to make it work and if it ultimately cleared everything, including the differential during articulation.
