The "so easy a caveman can do it" abs disable mod with pics
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Btnewman, Apr 28, 2012.
  1. Apr 28, 2012 at 4:02 PM
    Btnewman
    Btnewman [OP] Benjamin Newman
    Benjamin
    Grand Junction co
    Uh. It's beat to he//. But it's only 1 owner.
    Custom body work/damage ARB rear locker Bumpers Shocks Other parts Tires and Rims Air tank fully plumbed into truck "Golf ball mod"
    So there is tons of good abs disable tech/wiring threads already going, so why not add another?
    I have dug through every one of them until my eyes were puking. This is what i came up with for disabling my ABS in a low tech, no frills, I don't even know the right names for the wires and connectors write up. with pics.
    I honestly cant remember which thread I got this info off, But I do want to extend a warm wet hug to the guys that have poured over manuals, wiring diagrams and fried many fuzes to finally put together an easy mod for this. thank you
    so the specifics:
    the truck started out as a 2007 double cab sport, no factory locking diff, no traction control.
    this mod allows the driver to disable and enable the ABS withOUT having to restart the truck, it works in real time.
    all you need is
    a few ft of wire,
    wire cutters/stripper
    a 3 pole switch of any flavor
    some butt connecters
    beer...
    first, pull the pocket out of the dash on the drivers left side, the one that lets you access the fuses.
    next
    locate this plug:
    pull that plug out and fish it out of the bottom of the console
    Then cut the light green wire next to the white one with the black stripe
    (this pic was taken with the connector hooked up, I had to run a quick errand in the middle of this.)
    now take the side of the wire that goes back into the wiring harness and do whatever you have to do using wire and butt connectors, or solder, or tape or whatever and connect it into the middle pole of the switch
    I only had black wire so i painted 1 or 2 stripes around the wire for identification.
    then take and connect one of the outside poles again by any way that suits you, to the connector side of the green wire.
    and last, ground the last outer pole of the switch.
    stuff everything back in its hole and go find a dirt road and slam on the brakes with the switch on, then do it again with the switch off for the "piece of mind final check"
    On the dash you with see the ABS light turn on when the abs is disabled, and back off when abs is enabled, also you will see the "rear differential locked" emblem on the console light up with the abs light as well, even if your truck never came with a factory locking diff.
  2. Aug 23, 2012 at 6:13 PM
    BradyT88
    BradyT88 Well-Known Member
    Think this mod would also disable traction control and all that BS? I kind of wonder where it makes the locker light come on. Although I wonder if it will interfere with my locker...
  3. Aug 24, 2012 at 7:40 AM
    mutilatedjak
    mutilatedjak n00b waffle
    WA
    11 DC SB TRD Sport 6spd
    BP-51s, Dakar leafs, ARB bumper, 4xinnovations rear HC, 3x trail camera, pure android, lightforce 170s, Dick Cepek 255 85s extreme terrain.
    Yea I would like to know if it kills any of the VSC and such
  4. Aug 24, 2012 at 7:46 AM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Any of the TRD Off Road guys should be able to answer that. This mod mimicks locker engagement, so whatever is disabled with the locker engaged will be disabled by this mod.
  5. Aug 24, 2012 at 7:59 AM
    BradyT88
    Then yes it will:D Thanks!
  6. Nov 19, 2012 at 4:36 PM
    goualon69
    goualon69 Well-Known Member
    Mathieu
    Québec, Canada
    2011 sr5 tacoma
    I have read a lot about abs disable! I have 2011 4x4 4doors auto trans, VSC, no diff lock, now I am running without abs fuse, I think this way discribed here will be the essy way for me? and will do the same as running without fuse! do you agree?
  7. Nov 19, 2012 at 4:45 PM
    myfirst06taco
    myfirst06taco Well-Known Member
    Clarke county ,VA
    06 SR5 4X4
    5100's eibach coils , Allpro leaf pack , roll up tonneau cover with led bed lights, hids, homertaco grill
  8. Nov 28, 2012 at 2:31 PM
    WailuaTaco808
    WailuaTaco808 A.L.O.H.A. Member
    Phil
    Hawaiian Islands
    2010 Tacoma TRD SPORT Kauai Built
    Oh boy...
    HELLL YEAAAAA MELT IT SWITCH FO DA WINNNN!!! just roasted my 35's! u da man great writeup! :burnrubber: :burnrubber:
  9. Nov 28, 2012 at 2:40 PM
    Btnewman
    Benjamin
    Grand Junction co
    It doesthe same as running without the fuse.
  10. Nov 28, 2012 at 2:47 PM
    The Traveler
    The Traveler Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    Hate to be a buzzkill, but can't you roast your tires by just holding down the VSC button for 5 seconds?? :confused:
    I'm still not entirely sure what difference the ABS killswitch makes when off-roading. I don't think I've ever felt the ABS kick in under my foot or on the dash while wheelin'.
  11. Nov 28, 2012 at 9:40 PM
    Btnewman
    Benjamin
    Grand Junction co
    I have had abs kick in and send me sailing into some pretty rough spots waaaaaaasy too fast!
  12. Nov 28, 2012 at 9:42 PM
    Country101
    Country101 Well-Known Member
    NW Arkansas
    08 tacoma access cab V6 4x4 manual
    dirty truck mod, custom trailer scratch on tailgate, husky floorliners, OME Lift
    Yeah, I've had the abs put me in the creek and almost in the ditch while turning a corner. ABS sucks.
  13. Nov 28, 2012 at 9:46 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    ABS or traction control ?
  14. Nov 28, 2012 at 10:15 PM
    Utard
    Utard Well-Known Member
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    Sounds like you are driving to fast for the conditions?
  15. Nov 28, 2012 at 10:16 PM
    Btnewman
    Benjamin
    Grand Junction co
    Abs, that's stuff is evil! It activated if only one wheel was at all in the air or sliding, then you can just kiss any chance of immediately stopping goodbye
  16. Nov 28, 2012 at 10:23 PM
    OZ-T
    Peter North
    British Columbia
    ABS on these truck sure sucks on snow
    TXpro4X4 and stevotivo12 like this.
  17. Nov 28, 2012 at 10:24 PM
    Btnewman
    Benjamin
    Grand Junction co
    Or sand, or rocks, or driveways and mall parking lots....
    TXpro4X4 likes this.
  18. Nov 28, 2012 at 10:41 PM
    OZ-T
    Peter North
    British Columbia
    Isn't that a Dr. Seuss book ?
  19. Nov 28, 2012 at 10:49 PM
    Btnewman
    Benjamin
    Grand Junction co
    Is it that obvious that I just got done putting kids to bed?
  20. Nov 28, 2012 at 10:57 PM
    OZ-T
    Peter North
    British Columbia
    Is this the same location / solution as your method ?
