The SR thread, let's see them!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jeepinoutwest, Jan 19, 2016.
  1. Mar 12, 2018 at 8:36 PM
    #2361
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    99’ Bro-Coma’s Revenge 3RZ 345k+
    Stock
    Yeah, on customoffsets.com they rate the stance by mild, aggressive, super aggressive ext. so instantly I thought of the pic I posted. You might have to put the 275’s on a tire stretcher lol!
  2. Mar 12, 2018 at 8:44 PM
    #2362
    txwhitacre
    txwhitacre Well-Known Member
    2018 Tacoma TRD OFF ROAD
    Is this the real pelican? Good looking truck. We need to introduce them.
  3. Mar 12, 2018 at 9:40 PM
    #2363
    NCJ88
    NCJ88 Well-Known Member
    Nick
    San Diego
    2017 Silver Tacoma SR
    I see. No stretching. Just looking to stick a nice ~33" under there with plenty of sidewall. I currently have 285/65r18(~33") which looks good but not the look I'm going for.
    Diablo169[QUOTED] likes this.
  4. Mar 13, 2018 at 1:25 PM
    #2364
    Monopod
    Monopod Well-Known Member
    2017 Silver sky tacoma SR I4 4x4
    plasti dip emblems, TRD off road wheels, pro clips cell phone mount. 20 percent tint.
    If i buy a pair of rear trd pro tail lights will they work just like my sr lights? Wasnt sure if i need to do some custom work since i have a SR. Basically was it just plug and play?
  5. Mar 13, 2018 at 1:28 PM
    #2365
    Monopod
    Do i need special rear light bulbs or can i use my existing ones.
  6. Mar 13, 2018 at 1:31 PM
    #2366
    Monopod
    Im still looking for someone in my area to help with my BHLM. Sacramento CA. Will pay!
  7. Mar 13, 2018 at 3:00 PM
    #2367
    2016 Tacoma SR
    2016 Tacoma SR Well-Known Member
    HOCO Maryland
    2016 MGM 4Runner SR5
    ToyTec Ultimate lift, FX Pro wheels, 295/70/17 Ridge Grapplers, AFE drop in filter.
    I assume you had steel wheels and went to aluminum? Steel wheel lugs are totally different than what's used on the aluminum wheels.
  8. Mar 13, 2018 at 6:35 PM
    #2368
    Yitties
    Yitties Member
    2017 AC SR
    Yes I just switched my stock steel rims on my 2017 SR to the Off-Road stock rims.
    Would any of these work? Keep in mind I pretty much have no knowledge about this subject lol so any help is appreciated.
    https://www.ebay.com/itm/24-TOYOTA-...c:g:7LUAAOSwB-1Y78OP&vxp=mtr&autorefresh=true
    https://www.ebay.com/itm/24-Pc-TOYO...orityMailSmallFlatRateBox!32792!US!-1&vxp=mtr
  9. Mar 14, 2018 at 8:43 AM
    #2369
    JMag04
    JMag04 Member
    2016 SR5 DCSB 4x4
    Hey guys,
    So I have an SR5 with steel wheels on, trying to switch them out to TRD beadlock wheels, could I get away with using the same TPMS? What did some of you who had steelies do when you switched to alloys? Much appreciated!
  10. Mar 14, 2018 at 10:03 AM
    #2370
    BAMA-256
    BAMA-256 Well-Known Member
    Rex
    Huntsville Alabama
    2017 SR 4x4 5 speed manual Past-2016 TRD Offroad 4x4
    I had some SCS wheels put on this weekend. The shop switched the sensors over from my steel wheels without saying anything. I was afraid it was going to be an issue as well, but wasn't with this shop
  11. Mar 14, 2018 at 10:05 AM
    #2371
    cohiker
    cohiker Well-Known Member
    2016 DCSB SW V6 4X4 Tacoma
    I had OR alloys put on. Discount Tire never mentioned the TPMS being a problem, they just switched em right over.
  12. Mar 14, 2018 at 10:15 AM
    #2372
    white_taco_
    white_taco_ Active Member
    Aren't the angle of the sensors not transferable between the steelies and alloy wheels? I think you can flip it the other way and use the steel wheel sensors but then it becomes an issue if you get a flat or get your tires replaced and the tech doesn't know about it.
    Ready_already likes this.
  13. Mar 14, 2018 at 10:25 AM
    #2373
    JMag04
    JMag04 Member
    2016 SR5 DCSB 4x4
    Thanks for the input! So no problem so far?
    I read about this, that's why I'm a little hesitant.. but I guess I'll just pull the trigger and change them to right ones when/if they break.
  14. Mar 14, 2018 at 11:52 AM
    #2374
    Monopod
    I really love this setup. Anyway you can send more pics? All around. Also are the .75 spacers bolt on or not?
  15. Mar 14, 2018 at 2:02 PM
    #2375
    Drunkdad
    Drunkdad Active Member
    Salt Lake City
    2016 Tacoma SR 4X4
    Yeah this is the biggest you will go with no lift. I leveled mine with 5100’s and this is the best size if you still have to use your truck as a daily driver.
    Smoothmove likes this.
  16. Mar 14, 2018 at 2:12 PM
    #2376
    Shawn_of_the_dead
    Shawn_of_the_dead Well-Known Member
    Shawn
    Miami, FL
    2020 Cement SR5 DCSB
    Correct, but they work just fine. Your tire shop would have to flip the sensors 180 degrees so now black part of the sensor is leaning away form the alloy wheel instead of against it (like it was on the steel).
    I had this done to mine and no problems. You will have to let the shop know if you have your tires changed. With a flat...maybe damage a sensor.
  17. Mar 14, 2018 at 3:49 PM
    #2377
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    Stock
    Yeah, they are plug and play.
  18. Mar 14, 2018 at 6:15 PM
    #2378
    fireemsdrew
    fireemsdrew Member
    Andrew
    2016 Taco 2.7 5spd
    Monthly payment
    I'm fashionably late (as usual), working night shift has me a bit off from the rest of the worlds schedule.
    Here's my 2016 SR. Has 2 inch block lift, with add-a-sprint in the rear. 2.7 paired w 5spd. Running 285/70/16's, shes a bit under powered but going from a diesel at work to this at home running my RPM's up isn't something I'm use to. Short list of mods are @CaliRaisedLed amber fogs, light bar behind grill with Caliraised brackets, adding speakers to rear doors, weather tech matts and side steps. Every one has damn good looking trucks!
  19. Mar 14, 2018 at 6:21 PM
    #2379
    Yitties
    Yitties Member
    2017 AC SR
    I did the same exact switch and when I went to the dealer they said that they weren't able to. Not sure if that was just the line they gave ,e but if you go to a shop I'm curious if they will make it work.
    Deathray likes this.
  20. Mar 14, 2018 at 7:27 PM
    #2380
    TACOROSSO
    TACOROSSO Well-Known Member
    2017 SR 4x4 5spd
    I bought a set of TRDOR wheels and tires (dirt cheap) a while ago, but with no lug nuts. I finally got around to ordering some lugs and mounted everything up last weekend.
    The Toyota part number for the alloy wheel lugs is 90084-94002. If these are equivalent to that part number, they should work. I went with used OEM ones.
    Yitties[QUOTED] likes this.
