The SR thread, let's see them!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jeepinoutwest, Jan 19, 2016.
  1. Jan 17, 2019 at 2:12 PM
    #3021
    Tuna tacos
    Tuna tacos Well-Known Member
    2018 Barcelona SR Double cab 4x4
    Anyone know if these will rub with 255/85/16 on a stock 4x4 SR?
    RedDeadTaco and mikestaco17 like this.
  2. Jan 17, 2019 at 3:04 PM
    #3022
    Carter'sTaco
    Carter'sTaco Leave anything for us?....Just bodies.
    Carter
    The Desert..........Arizona.
    "Gloria" 2018 SR 4x4 DCSB
    King 2.5" Front w/adj.- TC UCA's- King Ext rears w/ adj.- ICON RXT's- Avid Offroad Rock sliders- RCI Skids- Onboard ARB in EE cubby- EE TPAM- s48o diff breathers kit- Exhaust re-route- Falken Wildpeak 32" AT3-W Spintech 3000 muffler- Uniden CB / 3' Firestik- Ultra Phantom 16x8's- Fog lights- Tint- TRD rubber floor mats- Seat covers- AC drain mod- Hood decal- Custom headlight wrap- K&N Filter- Cali rasied switch panel- Cali rasied Ditch bracket mounts-
    I paid a local shop to put these on my steel OEM rims which have the same off set and BS. They fit my truck just fine no rubbing at all...stock! That being said, ALL tacos vary just slightly. The only reason I dont have them on now is I found some 32" Falken Wildpeaks delivered for $400.00. Just couldnt pass up that price!
    If they didnt fit without rubbing you would be one of the unlucky few.
    Good luck!
  3. Jan 17, 2019 at 3:14 PM
    #3023
    Chriscolo
    Chriscolo Active Member
    2017 Tacoma SR 4x4
    I had 235/85/16 Ko2s on my SR when I purchased it. No rub and clean clearance. Leveled it and put 265/75/16's on it and sold the other tires. I think you should be just fine.
  4. Jan 17, 2019 at 4:57 PM
    #3024
    mikestaco17
    mikestaco17 Well-Known Member
    MIKE
    BAD ASS UTILITY CAB
    I have the sr utility 4x4 20170827_144848.jpg package I needed a 3 inch lift to fit 255 85 16s on stock steelies with 1.5 inch wheel spacers
    Carter'sTaco likes this.
  5. Jan 17, 2019 at 5:02 PM
    #3025
    Tuna tacos
    I see heard you need the spare steel time to use that size tire or life cause stock steel off set rubs but I never tried but thanks for info
  6. Jan 17, 2019 at 5:17 PM
    #3026
    Carter'sTaco
    Carter
    If I am positive its the offset that the spacers made that made you rub?
    I put on 255/85/16 on my stock steelies and they didnt rub at all. I did not use 1.5 spacers either. My rims and set up was completely stock except for the plastidip! Maybe I just got lucky with the alignment.
    mikestaco17[QUOTED] likes this.
  7. Jan 17, 2019 at 5:23 PM
    #3027
    SilverBulletII
    SilverBulletII Well-Known Member
    New England
    2017 Silver Tacoma SR, MT, 4 cylinders, 4X4
    My SR has "intermittent" wipers, but they are manual. I just push up on the wiper control for a one swipe function. Very easy and simple.
  8. Jan 17, 2019 at 6:11 PM
    #3028
    RedDeadTaco
    RedDeadTaco The Hipster Woodsman
    Andrew
    Aiken, SC
    '16 Barcelona Red OR
    Mobtown Sliders, Aluminum Skids Bilstein 6112/Extended 5100’s Iron Man constant load leafs JBA High Caster UCA’s Diamond Back Tonneau 285/75/r16 Cooper STT Pros Method 702’s Uptop Overland Alpha Roof Rack
    Are you running aftermarket UCA's, Thinking about going the 255/85 route with my dark alloys
  9. Jan 17, 2019 at 6:55 PM
    #3029
    Jim=2015 TRD PRO
    Jim=2015 TRD PRO Well-Known Member
    Jim
    MD
    2015 TRD PRO
    Something to fill those wheel wells
  10. Jan 17, 2019 at 7:36 PM
    #3030
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    Same here. :thumbsup:
  11. Jan 17, 2019 at 8:18 PM
    #3031
    alice the cat
    alice the cat Active Member
    San Diego
    2018 SRAC 2019 SRDC
    This is my sons SR. We bought it for him when he graduated high school to commute to college. Luckily he had saved every penny ever given to him so he did some small mods like a lift and TRD Pro wheels (ebay and later discovered they were reps) tint and keyless entry. My first car in 1989 was a toyota pickup so it's come full circle. I liked his truck so much I ordered one for myself that will be here soon.
    16SRMGM, JoeManji, tractng and 11 others like this.
  12. Jan 17, 2019 at 11:10 PM
    #3032
    5465
    5465 Well-Known Member
    South
    2023 TRD Ex Cab
    That’s awesome, he’s a lucky boy ! (Probably derseves it :) More details about the build, lift, tire size ?
  13. Jan 18, 2019 at 12:50 AM
    #3033
    alice the cat
    San Diego
    2018 SRAC 2019 SRDC
    His was, as mine will be, the cheapest tacoma you can buy... he deserves better but loves it. Maxtrac lift with 1 inch spacers in the rear to make up for the wider track the spindles created. 285's for the tires (Nitto somethings) zero rubbing. I think it was a 4 inch lift overall like a 4 front and 3 rear. We wanted it to sit dead level and that's not easy here in San Diego where everyone likes the front to ride much higher than the rear.
    This was meant to be a the budget builds of all budget builds and I think we did it. As his dad I think its a perfect first truck with no back seat and must be the slowest thing on the San Diego freeways ;)
  14. Jan 18, 2019 at 12:56 AM
    #3034
    njburchardt
    njburchardt Well-Known Member
    Nate
    2016 Silver Tacoma
    There are some pretty cool mods on here!
    alice the cat likes this.
  15. Jan 18, 2019 at 1:05 AM
    #3035
    alice the cat
    San Diego
    2018 SRAC 2019 SRDC
    His Birthday. I recreated what my father did for me on my birthday. It was pretty cool.
  16. Jan 18, 2019 at 5:30 AM
    #3036
    ClassicVW
    ClassicVW Well-Known Member
    George
    North and South Jersey
    2018 Tacoma SR 4x2 2.7 DCSB MGM
    Get back to us one day after you ride in a light rain for an hour and a half.
    Thirty8special, Yann and MCCM like this.
  17. Jan 18, 2019 at 5:31 AM
    #3037
    SilverBulletII
    New England
    Been there. Done that. Still smiling.
  18. Jan 18, 2019 at 5:41 AM
    #3038
    MCCM
    MCCM Well-Known Member
    Jerry
    Clarksville
    2018 SR 4x4
    None yet.
    +1
    Yann likes this.
  19. Jan 18, 2019 at 5:48 AM
    #3039
    Taco/Jäger
    Taco/Jäger Well-Known Member
    2016 Tacoma SR 2wd
    4D4237A3-E64A-4A65-A045-5F12DDF85A45.jpg 524F8213-33CC-4F6A-8110-2C048CBEFD3E.jpg
    Here’s my 2016 SR 2wd
    TT005, 282773, bulalo and 2 others like this.
  20. Jan 18, 2019 at 5:57 AM
    #3040
    Yann
    Yann Well-Known Member
    Mick
    South Carolina
    98 Base I4 4x2 / 18 SR V6 4x4
    A/C Drain Pro Grille Intermittent Wipers Blacked out Wheels Blacked out Badges Gasshole Nfab Predator Bars Tweeter Upgrade Kicker Upgrade Morimoto Amber LED Fog Lights Meso fuse box Stage 1 taillights
    Nice rack .
