The SR thread, let's see them!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jeepinoutwest, Jan 19, 2016.
  1. Jan 18, 2019 at 6:01 AM
    #3041
    Taco/Jäger
    Taco/Jäger Well-Known Member
    2016 Tacoma SR 2wd
    Here is a better pic of the rack. Yakima Mega Load Warrior with Rhino Rack Ski/Rod holders mounted on MOBTOWN Rack.
  2. Jan 19, 2019 at 7:48 PM
    #3042
    mikestaco17
    mikestaco17 Well-Known Member
    MIKE
    BAD ASS UTILITY CAB
    no stock uca
  3. Jan 19, 2019 at 7:52 PM
    #3043
    mikestaco17
    MIKE
    BAD ASS UTILITY CAB
    with no lift I couldn't turn at all I hit front bumper hard and cab mount with no wheel spacers, I lifted did wheel spacers and I hit nothing plenty of room even when stuffed
    Carter'sTaco[QUOTED] likes this.
  4. Jan 19, 2019 at 8:21 PM
    #3044
    mikestaco17
    MIKE
    BAD ASS UTILITY CAB
    pics?
  5. Jan 19, 2019 at 8:22 PM
    #3045
    STi and Taco
    STi and Taco Not a Super Hero
    Steven
    Georgia
    '16 Tacoma SR 4x4 Access Cab Black, 2012 Subaru STi Hatchback Black, 1995 Acura Legend L Gold (RIP), 2020 Corolla Hatchback
    Diode Dynamics LED Inerior Lighting https://www.diodedynamics.com/by-vehicle.html?no_cache=1&find=2016-toyota-tacoma-115242 Hella Supertone Horns Some Joe Schmuckitelli Keyless Entry Intermittent Wiper Mod - Thanks to @moe2o4 Cruise Control Mod - Thanks to @moe2o4, again Anytime Back-up and Front Mount Camera Mod - Courtesy of @Logistics91 (amazing customer service helping me get it just the way I wanted it set up) Drawtite Class IV trailer hitch with 7/4 pin connector and P3 Tekonsha Brake Controller RokBlokz Mud Flaps Access Cab Rear Seat Storage Mod - Thanks to @Cagedodger for the original idea. Just modified it to fit my needs. https://www.tacomaworld.com/threads/access-cab-storage-organization.453774/page-4#post-17877877 Method 701 Black Wheels 265-70r17 Nitto Ridge Grapplers Fumoto Drain Valve Weather Tech Floor Liners and Side Window Deflecors Tuxedo TruXport Bed Cover Access Cover Motion LED Light Strip. Mounted 2 in the bed. Air Dam Delete Demello Off-Road Overlander Aluminum Winch Bumper with Baja Hoop and Squadron Sport LED Spots Warn M8000 Winch Silex center console organizer and tray Full Bed and Under Hood LED Lighting A/C Condensation Drain Relocation Rostra Front Heated Seats aFe Power 51-82722 Magnum FORCE Stage-2 Si Pro DRY S Cold Air Intake System (Part #51-82722) Prolightz clear LED fog lights w/ lamin-x overlay Red line Hood struts Diode Dynamics Hi/Low beam HID conversion kit MesoJDM 4 switch cubby panel, 7 switch Center panel and Center console Coin Holder @mesojdm Carhart Gray Front Seat Covers Curtis Class IV receiver B&W Tri-ball hitch King 2.5 Front Coilover/Rear Shock 25001-119/25001-121 Coming Soon: Differential Breather Relocation Mod New tires, can't decide
    I have a simple request from any of you guys here. I have a 2016 Access Cab SR 4x4, stock size tire, 16in steelies and suspension. Can anyone of you with the same set up measure from the ground to the front fender, centered on the middle of the hub on both sides? I just finished installing the demello aluminum winch bumper and warn m8000 winch and forgot to take the measurement before I installed to make sure it didn't lower the front too much.
    Thanks much. Will post pics when it's all buttoned up.
  6. Jan 19, 2019 at 9:56 PM
    #3046
    Tuna tacos
    Tuna tacos Well-Known Member
    2018 Barcelona SR Double cab 4x4
    Nice truck! Stock suspension? Tire size? Any spacers? No rub? Just checking cause rims you have I like the setup looks simple!
  7. Jan 19, 2019 at 10:03 PM
    #3047
    Yann
    Yann Well-Known Member
    Mick
    South Carolina
    98 Base I4 4x2 / 18 SR V6 4x4
    A/C Drain Pro Grille Intermittent Wipers Blacked out Wheels Blacked out Badges Gasshole Nfab Predator Bars Tweeter Upgrade Kicker Upgrade Morimoto Amber LED Fog Lights Meso fuse box Stage 1 taillights
    @Taco/Jäger I think he's asking you .
  8. Jan 19, 2019 at 10:19 PM
    #3048
    Tuna tacos
    Yea sorry wasn’t looking when I pressed quote thanks bro!
  9. Jan 20, 2019 at 2:00 AM
    #3049
    Ttthawaii
    Ttthawaii Member
    2018 Tacoma 4cyl
    Hey there!
    New to Tacoma World, so not sure if this is the correct way to post, but I'm looking for some seasoned ears to tell me if my new Tacoma SR 2018 engine sounds 'normal'. Dealership checked it out and says it is, but... it's the dealership... listened to other 4 cyl Tacoma's and did no hear the same 'knocking' 'clanking' sounds..
    Will be peace of mind for someone other than the Toyota tell me that it's 'normal'.
  10. Jan 20, 2019 at 4:51 AM
    #3050
    Taco/Jäger
    2016 Tacoma SR 2wd
    Stock uca, Pro comp 2.25” leveling kit up front, Low Range OffRoad 1” block in the rear. Bilstein 5100 in rear only. Cooper ST Maxx 235/85/16 (31.9”). No rubbing anywhere no CMC. Oh this is also a 2WD so I don’t have to worry about needle bearings also I have no issues with alignments.
    Tuna tacos[QUOTED] likes this.
  11. Jan 20, 2019 at 4:57 AM
    #3051
    Taco/Jäger
    2016 Tacoma SR 2wd
    My 2016 SR 2wd has heated mirrors.
    u wish u could ride likes this.
  12. Jan 20, 2019 at 4:59 AM
    #3052
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    Cool! I am probably mistaken about my comment. Guess I should delete it. Thanks.
  13. Jan 20, 2019 at 5:09 AM
    #3053
    ClassicVW
    ClassicVW Well-Known Member
    George
    North and South Jersey
    2018 Tacoma SR 4x2 2.7 DCSB MGM
    I can't tell what part of the ruck that is in the video. From what area on the truck are you measuring that sound?
    Doesn't sound normal to me, but if you're doing it from under the hood, anything is possibly 'normal'. Definitely should not hear that from inside the cab.
  14. Jan 20, 2019 at 5:13 AM
    #3054
    STi and Taco
    Steven
    Georgia
    Looks like camera was pointing at the fuse box. All that noise in the video just sounds like your typical direct injection 4cyl. They are ticky AF. Especially when you listen from under the hood. @Ttthawaii
    Ttthawaii likes this.
  15. Jan 20, 2019 at 5:13 AM
    #3055
    epa4wd
    epa4wd Well-Known Member
    Eduardo
    2019 SR
    Clazzio Seat Covers OR Wheels 40% tint Side Steps KC Fog Lights
    Looks like under the hood, driver’s side.
    I can’t remember hearing that on my 09’ or my father’s 19’.
  16. Jan 20, 2019 at 5:15 AM
    #3056
    epa4wd
    Eduardo
    2019 SR
    I think he is refering to the knocking in the background.
    Maybe he could go to the dealership and listen to another one in the lot to compare.
  17. Jan 20, 2019 at 5:34 AM
    #3057
    ClassicVW
    George
    If you open the hood and listen, any engine and it's various accessory parts makes an abundance of sounds. We usually don't focus or obsess on them, they're just kinda accepted as background noise. But, if you point a microphone somewhere and concentrate on what you're hearing, well, then you can think something is abnormal.
  18. Jan 20, 2019 at 5:43 AM
    #3058
    Claudiomartinof
    Claudiomartinof Well-Known Member
    2019 TRD OFF ROAD 6MT
    My 4cyl with 35k sounds like that.... it does sounds normal to me...
    Ttthawaii[QUOTED] and CusterFan like this.
  19. Jan 20, 2019 at 6:04 AM
    #3059
    STi and Taco
    Steven
    Georgia
    Seems like the camera microphone is probably picking up and magnifying the engine noises he's hearing. Still sounds totally normal for these DIT engines. Something I had to get used to since I'm more used to working on turbo'd subarus. That kind of ticking from a STi means engine rebuild. lol
    Ttthawaii and CusterFan like this.
  20. Jan 20, 2019 at 7:08 AM
    #3060
    FLATBLAK
    FLATBLAK Member
    utah
    2018 SR
    3” front lift, rockstars on 33s, tint, and black roof
    Here’s my 18 sr.
    Here’s what I’ve done so far:
    Wrapped the roof black
    Tinted windows
    3” lift (spacer) in the front, stock in the rear (I wanted a little squat)
    20” rockstars
    33s
