The SR thread, let's see them!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jeepinoutwest, Jan 19, 2016.
  1. May 4, 2020 at 4:43 AM
    #4541
    2k2
    2k2 Flareless
    Zak
    Gen 3 SR 4x4 4cyl AC
    See Build Thread
    Added some grille lights. I'll probably still eventually pick up the xtrek grille. 20200503_194902.jpg 20200503_194921.jpg
    YotaKid likes this.
  2. May 4, 2020 at 4:44 AM
    #4542
    2k2
    2k2 Flareless
    Zak
    See Build Thread
    I'll post up pics of them lit once I get them wired up.
  3. May 4, 2020 at 11:12 AM
    #4543
    YotaKid
    YotaKid Well-Known Member
    AZ
    2017 SR 4x4
    Those look pretty fresh. Let’s see them lit
  4. May 4, 2020 at 12:05 PM
    #4544
    2k2
    2k2 Flareless
    Zak
    See Build Thread
    Ok. I'll finish wiring them up in a day or so. Drilling holes and grinding the back of the grille took way longer than it should have. That top part of the grille looks easy to poke holes in, but there is some stuff behind that panel that made it a pita to mount the lights.
  5. May 4, 2020 at 1:00 PM
    #4545
    Ajschn06
    Ajschn06 Well-Known Member
    2020 Tacoma SR Double Cab- MGM
    Cologne and Rhoto's…..sounds like a good time..
  6. May 4, 2020 at 1:00 PM
    #4546
    bizjettech
    bizjettech Well-Known Member
    Sunny Florida
    Can any of you new 2020 SR owners confirm or deny that KEYLESS ENTRY is now INCLUDED on all
    2020 SR models ?? I've been researching this online and getting lots of conflicting answers.....I'm looking for
    a definitive yes or no.....does your 2020 SR have keyless entry?
  7. May 4, 2020 at 1:14 PM
    #4547
    makeitcount19sx
    makeitcount19sx Well-Known Member
    Corey
    MA
    Super White '19 SX 4x4 2.7
    ditchies, switchback drls, led lows, minor interior mods, need a cap!
  8. May 4, 2020 at 1:46 PM
    #4548
    SSMTRDOR
    SSMTRDOR Well-Known Member
    2020 TRD OR 4X4
    Keyless entry is part of the optional convenience package. Not standard equipment. From the build config tool at toyota.com
  9. May 4, 2020 at 1:50 PM
    #4549
    bizjettech
    Sunny Florida
    I'm getting conflicting info on that......seems as though the "build config tool" is not correct for the 2020.
    I've got the dealer looking into it....
  10. May 4, 2020 at 3:10 PM
    #4550
    2k2
    2k2 Flareless
    Zak
    See Build Thread
    Mine does, but it has the convenience package. I don't think the utility package has keyless entry standard.
  11. May 4, 2020 at 3:15 PM
    #4551
    2k2
    2k2 Flareless
    Zak
    See Build Thread
    Done. I'm kinda anal about dressing and protecting non-factory wiring, so that took more time than the actual install. Hopefully these things hold up. If not I'll have a grille with 4 holes in it. I guess when these things give out I'll have a reason to get the xtrek grille. Sorry no night pics.
    YotaKid[QUOTED] likes this.
  12. May 4, 2020 at 3:16 PM
    #4552
    YotaKid
    AZ
    2017 SR 4x4
    You got that done fast!! That looks awesome man
  13. May 4, 2020 at 3:16 PM
    #4553
    bizjettech
    Sunny Florida
    I was just informed by my dealer that the conveinience pkg is standard on the SR V-6 tacomas and is only available as an add on option
    for the SR 4 cylinder tacomas......this might be a regional things, not sure.....
  14. May 4, 2020 at 3:19 PM
    #4554
    2k2
    2k2 Flareless
    Zak
    See Build Thread
    Once I get fog lights I want to tap into the fog light fuse (currently tapped into passenger headlight). Can anyone confirm that tapping into the fog light fuse will work? Never seen anyone do this?
  15. May 4, 2020 at 5:23 PM
    #4555
    Ajschn06
    My 2020 SR definitely has keyless entry
  16. May 4, 2020 at 6:05 PM
    #4556
    socal drifter12
    socal drifter12 If we can't fix it, YOU DON'T PAY
    Ken
    2020 Tacoma
    MY 2020 SR 4 cylinder did not come with keyless entry.
  17. May 4, 2020 at 6:10 PM
    #4557
    Yann
    Yann Well-Known Member
    Mick
    South Carolina
    98 Base I4 4x2 / 18 SR V6 4x4
    A/C Drain Pro Grille Intermittent Wipers Blacked out Wheels Blacked out Badges Gasshole Nfab Predator Bars Tweeter Upgrade Kicker Upgrade Morimoto Amber LED Fog Lights Meso fuse box Stage 1 taillights
    Where did you mount the switch?
  18. May 4, 2020 at 6:10 PM
    #4558
    2k2
    2k2 Flareless
    Zak
    See Build Thread
    Thanks. I appreciate it. I'm not the best photographer but heres some night pics -- couldn't take a head on because the photo quality was even worse, but you get the idea. 20200504_205154.jpg 20200504_205130.jpg
  19. May 4, 2020 at 6:21 PM
    #4559
    2k2
    2k2 Flareless
    Zak
    See Build Thread
    Edit -- sorry. That question wasn't for me.
  20. May 4, 2020 at 6:49 PM
    #4560
    sandiegohasthebesttacos
    sandiegohasthebesttacos Well-Known Member
    left side cubby in the small blank slot. perfect fit.
    if i could do it over again i'd probably do it in the center underneath the climate controls. my knee gets in the way sometimes with the switch on the left side.
