The SR thread, let's see them!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jeepinoutwest, Jan 19, 2016.
  1. May 5, 2020 at 8:48 PM
    #4581
    Beancooker
    Beancooker Alea iacta est
    The middle of Arizona
    2021 Jeep Wrangler Rubicon
    Lots, straight from the factory.
    Might as well join the picture fun...
  2. May 6, 2020 at 9:55 AM
    #4582
    Tuna tacos
    Tuna tacos Well-Known Member
    2018 Barcelona SR Double cab 4x4
    Bilstein 5100 maxed stock springs on front
    AAL on rear Bilstein 5100 also came about 2/2 stock rake. 265/75/16 pro Comp at sport E rated. Ride like stock just higher very comfortable with no rub!
    Boyettexan[QUOTED] likes this.
  3. May 6, 2020 at 11:13 AM
    #4583
    Kaiser1
    Kaiser1 Well-Known Member
    2017 tacoma
    When I needed a new key fob it was way cheaper to just get a after market alarm with keyless entry.
  4. May 6, 2020 at 3:35 PM
    #4584
    2k2
    2k2 Flareless
    Zak
    Gen 3 SR 4x4 4cyl AC
    See Build Thread
    For all you folks who added foglights to the SR, may sound cheap, or dumb, but has anyone taken the stock SR bezels and drilled out a hole for the lamp. The OEM bezels are $30 each and I'm looking to try and get away without having to buy them.
  5. May 6, 2020 at 3:57 PM
    #4585
    sandiegohasthebesttacos
    sandiegohasthebesttacos Well-Known Member
    you'd still have to fab up some mounting points on the back end. it'd look too tacky for me.
  6. May 6, 2020 at 4:37 PM
    #4586
    ClassicVW
    ClassicVW Well-Known Member
    George
    North and South Jersey
    2018 Tacoma SR 4x2 2.7 DCSB MGM
    Have a search on eBay. There are several Toyota dealers that sell there. Even if you don’t buy there, you can see the part numbers.
  7. May 6, 2020 at 4:43 PM
    #4587
    2k2
    2k2 Flareless
    Zak
    See Build Thread
    This truck looks nice. Is there a lift on it?
    YotaKid likes this.
  8. May 6, 2020 at 4:53 PM
    #4588
    tpp4
    tpp4 Well-Known Member
    Memphis
    2018 DCSB SR
    Someone has tried that on here and they said it was a mess. IIRC the holes don't line up
    Misfit likes this.
  9. May 6, 2020 at 4:56 PM
    #4589
    Tacomaroma
    Tacomaroma Well-Known Member
    Mark
    Oregon
    2020 SR Access V6 4wd Midnight Black.
    SX pkg, 265s, fogs, dog platform, lighted visors, LED interior.
    You can get the whole kit for 50 bucks on ebay. Even if you change out the lights, you still would have the bezels. I still have my old non holed bezels available if drilling your others doesn't work out and you just want to go back to stock.
  10. May 6, 2020 at 4:58 PM
    #4590
    2k2
    2k2 Flareless
    Zak
    See Build Thread
    Fair enough probably not worth the time and aggravation. I figured that somehow the angle of them is somehow different to compensate for the lamp. thanks
  11. May 6, 2020 at 5:00 PM
    #4591
    2k2
    2k2 Flareless
    Zak
    See Build Thread
    I saw several kits, however they all seem to have the OR bezels. I wanted the angled sr5 bezel which is the same as what's on the SR, but with the lamp cutout
  12. May 6, 2020 at 8:07 PM
    #4592
    TACOROSSO
    TACOROSSO Well-Known Member
    2017 SR 4x4 5spd
    if you’re not in a rush, keep your eye on the B/S/T section. i scored my fogs and bezels there for $20 shipped and i’ve seen several others since...
    not *too* uncommon since a lot of guys upgrade to LED pods, etc., and nobody else has a use for sr5 stock.
    on the other hand, i had to buy the light stalk and harness new, which was over $100 iirc...
  13. May 6, 2020 at 8:59 PM
    #4593
    skierd
    skierd Well-Known Member
    David
    Fairbanks, AK
    2021 F150 XL STX Screw 4x4 2.7
    It’s from N-Fab. I bought this one because it was an Amazon Warehouse deal for $60, otherwise I would have gotten The version with 4 tabs for larger lights.
    N-FAB T1630LD Gloss Black Light Bar; Multi-Mount System (MMS) Toyota Tacoma 16-18 https://www.amazon.com/dp/B01K9BMZV6/ref=cm_sw_r_cp_api_i_vD4SEbBBKG023
    Seventh likes this.
  14. May 6, 2020 at 11:53 PM
    #4594
    pomai808
    pomai808 Active Member
    Hawaii
    2016 4x4 Tacoma SR
    Should I red delete?
    BobcatSR and JonCrown like this.
  15. May 7, 2020 at 7:42 PM
    #4595
    2k2
    2k2 Flareless
    Zak
    See Build Thread
    I'd like to see more pictures of this truck
    BobcatSR and kite_325 like this.
  16. May 7, 2020 at 9:57 PM
    #4596
    JonCrown
    JonCrown Well-Known Member
    Jon
    SoCal
    2017 Tacoma Access Cab
    Rims, pro grill, exhaust, roof rack, lift, fogs, tires, headlights, taillights, ditch lights, bed rack, stereo system
    Yes
    kmorgan3 likes this.
  17. May 7, 2020 at 10:12 PM
    #4597
    Slidoomz
    Slidoomz Well-Known Member
    David
    Riverside,CA
    Ford F150
    Misfit, davidstacoma, ETBA and 3 others like this.
  18. May 8, 2020 at 4:13 AM
    #4598
    2k2
    2k2 Flareless
    Zak
    See Build Thread
    Wish I got a white one.....
  19. May 8, 2020 at 7:39 AM
    #4599
    that looks nice!
    shell, sliders, and tires?
  20. May 8, 2020 at 5:30 PM
    #4600
    Slidoomz
    David
    Riverside,CA
    Ford F150
    The shell is a leer 100xr, sliders are cali raised led offroad 0 degree(i kinda regret getting these), tires are 315/70 r17 falken wildpeaks m/t.
    Misfit likes this.
