The SR thread, let's see them!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jeepinoutwest, Jan 19, 2016.
  1. May 28, 2020 at 7:50 AM
    #4681
    zpcrowson42
    zpcrowson42 Well-Known Member
    17 TACO SR
    TRD Grille, LEDs, MB Wheels, Discoverer AT3 4S 265/75/R16
  2. May 28, 2020 at 7:53 AM
    #4682
    skierd
    skierd Well-Known Member
    David
    Fairbanks, AK
    2021 F150 XL STX Screw 4x4 2.7
    I’ve done both the wiper and fog light mod, they make the truck a lot better.
    davidstacoma likes this.
  3. May 28, 2020 at 8:25 AM
    #4683
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    Yeah I followed your posts on the fog light mod, good job! My Mictuning fog light switch and OEM harness should arrive tomorrow that will complete the parts I need for the fog light OEM (almost) mod.
    skierd[QUOTED] likes this.
  4. May 31, 2020 at 11:03 AM
    #4684
    JonCrown
    JonCrown Well-Known Member
    Jon
    SoCal
    2017 Tacoma Access Cab
    Rims, pro grill, exhaust, roof rack, lift, fogs, tires, headlights, taillights, ditch lights, bed rack, stereo system
    If anyone is interested in rear glass modular grid panels for 2nd and 3rd gen access cabs
    IG: @tacoma_twins is taking pre orders. I ordered mine already. No drilling necessary
    Misfit and YotaKid like this.
  5. Jun 1, 2020 at 10:48 AM
    #4685
    kmorgan3
    kmorgan3 Redside Electric, LLC | VLEDS
    Kyle
    PNW
    2020 4Runner SR5 Premium | RAM 1500
    Truck is at a good stopping point now that the gears and air locker are all straightened out so figured I'd share an updated photo:
    I'm moving a couple states away temporarily and will have a garage + extra time. Thinking about overhauling the suspension when I'm settled in. Just enrolled in a welding class for the fall - should be fun. I want to weld my own gussets, shock towers, etc.
  6. Jun 2, 2020 at 5:34 PM
    #4686
    mweidl
    mweidl Well-Known Member
    Mikey
    Southern California
    2017 Tacoma SR 4x4 Auto
    Ive had my front struts replaced twice already and they started making noise again. Im out of the manufactures warranty so Im on my own. Any recommendation on aftermarket struts? Not looking to lift the truck.
  7. Jun 2, 2020 at 6:54 PM
    #4687
    tbuz1964
    tbuz1964 Member
    Tom
    2018 Tacoma
    Sorry all I don't have a picture but I figured this was the right thread to ask this question since all you guys own SR's. How many of you have installed lockers? I am not rock climbing but was thinking about adding them.
  8. Jun 2, 2020 at 8:16 PM
    #4688
    Snaeper
    Snaeper Drinks like an 8, Drives like a 3
    Martin
    Phoenix, AZ
    2019 Quicksand SX 2.7 4x4 1990 Toyota Celica ST
    SnugTop Rebel, Infinity Kappa's, ToughDog 40mm
    KYB Gas-a-just, KYB Excel G or Bilstein 4600's will be quality OE replacement shocks/struts.
  9. Jun 2, 2020 at 8:58 PM
    #4689
    kmorgan3
    Kyle
    PNW
    I just installed a rear locker + gears. What do you want to know?
    ExplorHer and 09 Redneck like this.
  10. Jun 3, 2020 at 3:05 PM
    #4690
    tbuz1964
    tbuz1964 Member
    Tom
    2018 Tacoma
    What brand, how much and what type of driving do you do?
  11. Jun 3, 2020 at 3:14 PM
    #4691
    kmorgan3
    Kyle
    PNW
    I went with an ARB Air Locker for the rear and Nitro 4.88 gears. To power the locker I installed an ARB single in my rear bed cubby. I had a couple phone calls with Nitro before pulling the trigger on my setup.
    The locker I got on sale for $650 shipped. The shop I went through provided my gears and labor for $1,700 and they put the locker in for no charge. I ran my own airline and did the compressor install, however. I also did the oil swap at the 500 mile mark and replaced all crush washers for pretty cheap.
    I tow a 1,000 lb aluminum drift boat 2-3 times per week. The truck is my daily driver, although now it will be garaged as I'm moving to Utah and working from home for a year. As far as off roading goes I have hit 5 dedicated trails in the 10 months I've owned the truck. Otherwise 40% of the trucks odometer (4,000 out of the 10,000 miles it has) has been racked up on gravel or dirt roads. The gears are worth it if you tow and drive steep roads without a doubt. I don't Offroad enough to justify the price of the locker, in my opinion. I got it at a steep discount, but even then it's questionable. Is it nice to have? Sure. But really I haven't gotten my monies worth, yet. I just wanted to do it at the time of the gears because you might as well crack the diffs open once and once only. I also got the compressor as a gift. If I would have had to pay $1,000 for the locker, $350 for the compressor, and $100 for the mount I wouldn't have done it. Look for deals!
  12. Jun 11, 2020 at 6:47 AM
    #4692
    AlphaQ1ns
    AlphaQ1ns Well-Known Member
    2020 SR DBC V6 4x4
    Does anybody know what this plug is for? It's behind the grill. TIA
    CBrob and davidstacoma like this.
  13. Jun 11, 2020 at 7:03 AM
    #4693
    davidstacoma
    David
    NC
    Fog light connector, connects up to the OEM fog light harness you don’t have.
    I added fog lights to my SR, did a modified (easier) version of Nitori’s SR OEM fog light mod:
    Nitori's OEM SR Foglight mod!
    AlphaQ1ns[QUOTED] likes this.
  14. Jun 11, 2020 at 7:14 AM
    #4694
    AlphaQ1ns
    2020 SR DBC V6 4x4
    I did the same too I added an aftermarket fog lights. Has someone used it for anything else like a light bar?
  15. Jun 11, 2020 at 7:17 AM
    #4695
    davidstacoma
    David
    NC
    That connector isn’t going to do anything without the fog light relay installed and wiring to the ECU to give it a command to pick up the relay. All that is in the link I provided. Can’t see using it for other purposes but it’s possible with the ECU wiring however your Fog Light dash Indicator would come on lol.
  16. Jun 11, 2020 at 7:20 AM
    #4696
    TacoStarv
    TacoStarv Well-Known Member
    New Jersey
    2020 Black Tacoma SR
    Hey guys so I had a cracked fog light, the company send a whole replacement kit, fogs lights, bezels with cutouts and wiring hardness. I only need the fogs lights, does anyone wants everything else? You can get yourself better than stock fog lights. Just pay me the shipping
  17. Jun 11, 2020 at 7:27 AM
    #4697
    willconltd
    willconltd Well-Known Member
    Orlando, Florida
    Its just a switched connection, you could literally use it for anything. I gave up trying to find the other half of that harness and lopped it off and crimped on a standard H11 fog light harness plug. I did the same with the aftermarket light bar and made my own fog light harness for less than 15 bucks for all the wiring. The factory harness is like $75 for $3 worth of wiring and connectors.
  18. Jun 11, 2020 at 7:42 AM
    #4698
    Boyettexan
    Boyettexan Well-Known Member
    Boyette
    77584
    2021 TRD WHITE
    Ironman Nitro Stage 2,Mickey Thompson
    Hi, if offer is still up i can zelle you the amount for shipping ;)
    TacoStarv[QUOTED] likes this.
  19. Jun 11, 2020 at 7:46 AM
    #4699
    TacoStarv
    New Jersey
    DM your address and I’ll ship it to you
  20. Jun 11, 2020 at 7:52 AM
    #4700
    Boyettexan
    Boyette
    77584
    2021 TRD WHITE
    just did should be in the in box
