The SR thread, let's see them!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jeepinoutwest, Jan 19, 2016.
  1. Jul 24, 2020 at 2:54 PM
    #4901
    2k2
    2k2 Flareless
    Zak
    Gen 3 SR 4x4 4cyl AC
    See Build Thread
    Hmmm. Looks like this may be a potential issue with 20s. Iirc the other issues I saw were also with 2020s
    AlphaQ1ns[QUOTED] likes this.
  2. Jul 24, 2020 at 2:57 PM
    #4902
    AlphaQ1ns
    AlphaQ1ns Well-Known Member
    2020 SR DBC V6 4x4
    Hope enough Taco owners reported it up.
  3. Jul 24, 2020 at 3:00 PM
    #4903
    2k2
    2k2 Flareless
    Zak
    See Build Thread
    I'd imagine an issue like that cant go unaddressed. Well I guess I have 3 years or 36k miles to see if this happens to my truck.
    Tacomaroma and AlphaQ1ns[QUOTED] like this.
  4. Jul 24, 2020 at 3:04 PM
    #4904
    AlphaQ1ns
    2020 SR DBC V6 4x4
    True that
  5. Jul 24, 2020 at 3:44 PM
    #4905
    Fleischwagen
    Fleischwagen 2.7 > 3.5
    North Jersey
    2017 SR 5MT 4X4
    5.29's, ARB locker, 6112/5100, Deaver AAL, LCE Header, aFe dry-flo filter, Hurst/Core shifter, CBI T3 Front, Warn Winch, CB/UHF Radio equipment, Backrack, KC fogs and spots
    I had an issue a while ago with my 17's cluster but mine doesnt have the fancy color display in the center. The actual gauges were bouncing around while maintaining a constant speed/rpm. Called dealer, mentioned it. Told me theyd look into it. 2 weeks later, driving home from work it started doing it, I video taped it and drove right there. Replaced my cluster under warranty
    YotaKid, ExplorHer and AlphaQ1ns like this.
  6. Jul 24, 2020 at 3:48 PM
    #4906
    CBrob
    CBrob Well-Known Member
    Rob
    stock 2003 and stock SR 2020
    not a single mod
    IMG_20200723_142200.jpg got some 16 x 8 raceline addicts with falken AT s. 265 75 r16
  7. Jul 24, 2020 at 4:54 PM
    #4907
    BaseTaco2.7
    BaseTaco2.7 Well-Known Member
  8. Jul 24, 2020 at 5:09 PM
    #4908
    AlphaQ1ns
    2020 SR DBC V6 4x4
    I did the same thing too. I did a video when I started the truck just in case it clears itself and that I have proof it actually did have the issue.
  9. Jul 25, 2020 at 9:25 AM
    #4909
    2001Tacoma
    2001Tacoma Well-Known Member
    2019 SR I4
    @TacoMike Thank you for the information and help, great link you attached, its defiantly worth doing, thnx
  10. Jul 25, 2020 at 10:13 AM
    #4910
    TacoMike
    TacoMike Well-Known Member
    Pennsylvania
    '19 SR AC Utility 4x4
    You're welcome.
  11. Jul 25, 2020 at 11:59 AM
    #4911
    BaseTaco2.7
    IMG_E0375.jpg Wants to be a TRD so bad haha
    TRD4X4TOY, Burns, Roll_Terps and 3 others like this.
  12. Jul 25, 2020 at 1:20 PM
    #4912
    CBrob
    Rob
    not a single mod
    Paradise divide
  13. Jul 25, 2020 at 2:44 PM
    #4913
    BaseTaco2.7
    IMG_E0378.jpg 1.5 spacer
    2k2 and Fleischwagen like this.
  14. Jul 25, 2020 at 4:20 PM
    #4914
    2k2
    2k2 Flareless
    Zak
    See Build Thread
    SR - mainly stock/OEM. This is how they should roll off the assembly line.
    TRD4X4TOY, Misfit, ExplorHer and 8 others like this.
  15. Jul 25, 2020 at 6:16 PM
    #4915
    HybridTacoma
    HybridTacoma Active Member
    Weston
    2019 Black Tacoma SR
  16. Jul 25, 2020 at 7:35 PM
    #4916
    PuyallupJon
    PuyallupJon 2020 AG Pro
    Jon
    Puyallup, WA
    2020 Tacoma
    With the negative offset on those wheels do you have any rubbing?
    I think your truck looks great just like that!
    HybridTacoma and Misfit like this.
  17. Jul 25, 2020 at 7:44 PM
    #4917
    2k2
    2k2 Flareless
    Zak
    See Build Thread
    I had minor scrub radius rubbing in reverse. Had to heat and massage both front fender liners near the bumper (bottom front corners). Had to heat and massage rear fender liner near the pinch weld. I didn't want to have to, but I knew it was a possibility with the negative offset. I feel like a good alignment tech could have alleviated the rub, I was just too cheap to get an alignment since the truck is new and it tracked straight and drove nice.
    Thanks man. I'm basically done. Dont think I'm doing anything else that doesn't improve function. As far as aesthetics go I'm not going to do anything else. I need some mud flaps and a bed mat. Then I'm done
  18. Jul 25, 2020 at 7:55 PM
    #4918
    PuyallupJon
    Jon
    Puyallup, WA
    2020 Tacoma
    shit looks great just like that man
    good job!
  19. Jul 25, 2020 at 8:04 PM
    #4919
    2k2
    2k2 Flareless
    Zak
    See Build Thread
    Much appreciated. Big difference that wheels, proper sized tires, and some added lighting adds to these base pickups.20200315_184124.jpg
    Boyettexan and CBrob like this.
  20. Jul 26, 2020 at 2:24 AM
    #4920
    bbahunter
    bbahunter Well-Known Member
    Ma.
    2020 Black Bearded Taco
    I love the looks of this truck. You nailed it with the color scheme with the wheels and truck.:thumbsup:
    CBrob[QUOTED] likes this.
