The SR thread, let's see them!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jeepinoutwest, Jan 19, 2016.
  1. Aug 25, 2020 at 8:12 PM
    #5281
    TKitchTaco
    TKitchTaco Subs for work tacos for play
    Trent
    Jersey shore
    2020 AC SR SX super white
    Desert Does it Seat jackers LasFit LED headlight/taillight kit Plastidipped wheel emblems tailgate inserts
    Just put on some cooper discoverer at3 265/75/16’s. Loving the new aggressive look. Installed the trd OR grille a few weeks back, plastidipped it black so it matched the fenders better
  2. Aug 26, 2020 at 3:05 AM
    #5282
    Fishingeek603
    Fishingeek603 Well-Known Member
    New Hamphire
    2023 TRD Sport, Super White Access Cab 4x4
    Fox 2.0 front with res adjustable rears jba ucas icon rxt leaf pack.
    Does anyone know if this center blank is usable? It doesnt look like the one to the left of the steering wheel, and its a little bit of a process to get to this one. Figured I would ask before ripping my center console apart.
  3. Aug 26, 2020 at 3:21 AM
    #5283
    2k2
    2k2 Flareless
    Zak
    Gen 3 SR 4x4 4cyl AC
    See Build Thread
    Nicely done.
    SCTACO831[QUOTED] likes this.
  4. Aug 26, 2020 at 7:13 AM
    #5284
    Tacman19
    Tacman19 Well-Known Member
    Dave
    Mid Missouri
    19 Tacoma SOLD
    As many as I can fabricate
    This forum is obsessed with headlights. Go to your brick and mortar parts store and get a pair of Silverstar Ultra's $33 and you won't have to destroy your wiring harness, headlight assemble, lift your truck and do the stupid ass needle bearing and cam position sensor...lol I'm 63 years old, can't see at night and those bulbs will work just fine. Whiter, not brighter....ya know? If you can't see after that, consider eye surgery to correct the issue. LOL
    Zim
    pismo61, ClassicVW, Boghog1 and 2 others like this.
  5. Aug 26, 2020 at 8:14 AM
    #5285
    skierd
    skierd Well-Known Member
    David
    Fairbanks, AK
    2021 F150 XL STX Screw 4x4 2.7
    there’s a sticky for this:
    https://www.tacomaworld.com/threads/3rd-gen-hid-vs-led-vs-halogen-h11-projector-headlights.589465/
    to summarize, a $14 set of Phillips H9 bulbs require a little trimming of the connector and metal tabs and are the brightest halogen upgrade.
    The h11 GE/Tungram +130 and GE Xenon +120’s are nearly as good but fit without modifications and cost about $35 for the set.
    Fully coated bulbs like the silver stars will have less output than stock.
    davidstacoma likes this.
  6. Aug 26, 2020 at 8:52 AM
    #5286
    8Whiskey2
    8Whiskey2 Stellaaa
    Travis
    Arkansas
    2019 Cavalry Blue TRD Off Road
    Derp, LEDs, BFGs, Leer Camper
  7. Aug 26, 2020 at 9:33 AM
    #5287
    skierd
    David
    Fairbanks, AK
  8. Aug 26, 2020 at 9:34 AM
    #5288
    cburnscrx
    cburnscrx Active Member
    2018 Tacoma SR 4x2 4cyl
    None yet - It’s my father in laws truck
  9. Aug 26, 2020 at 9:58 AM
    #5289
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    This folks ^^^
    I’m running the GE/Tungsram Megalight Ultra +130 H11 in my low beams, good improvement over stock. Have some Philips H9 to modify for low beams when one of these burn out if I want, also a backup set of the Tungsram +130.
  10. Aug 26, 2020 at 10:46 AM
    #5290
    TACOROSSO
    TACOROSSO Well-Known Member
    2017 SR 4x4 5spd
    i read the first couple of posts there: my understanding is that the H9s throw the most light, the downside being they’ll just burn out a bit quicker. but it seems to suggest the stock projector lamps (opposed to older reflector housings) prevent H9s from blinding other drivers, despite the dramatic increase in light...
    is anybody here running those philips H9s, and has that been your experience?
    forgive me for not reading that entire thread (it’s *quite* long) but that’s really my only concern now with moving to the H9s. seems like a great performance upgrade for the money, i just can’t stand when people fuck around with their headlamps and end up blinding everyone else at night, so i don’t want to be “that guy.”
    CusterFan and Tullie D like this.
  11. Aug 26, 2020 at 11:27 AM
    #5291
    willconltd
    willconltd Well-Known Member
    Orlando, Florida
    Its a standard button hole. Get some unwaxed dental floss, get a loop behind the plastic and yank it out. Then you can feed the wires back through the center console without disassembling your dash.
    These switches match the factor color better than anything else I've found so far.
    https://www.aironboard.com/online/products/switches/toyota-push-switches.html?color=288
  12. Aug 26, 2020 at 11:57 AM
    #5292
    skierd
    David
    Fairbanks, AK
    Projectors have a built in glare shield, so no the uncapped H9 bulb won't have more glare compared to stock. I've used them for the last 2 winters (no need for headlights in Alaska in summer) and they are a massive improvement over the stock bulbs. When my last set popped one of the bulbs, I sent the still working h9 to crashnburn80 to test. It still tested better than the stock bulbs at its end of life, but had lost about 25% of its original output. My plan going forward is to put a new set of h9's in every September.
    Boghog1 and Fishingeek603 like this.
  13. Aug 26, 2020 at 12:19 PM
    #5293
    Fishingeek603
    New Hamphire
    Thank you! much appreciated. I think im going to get a cali raised switch panel for that useless cubby hole to the left of the steering wheel. But I will remember this for the future.
  14. Aug 26, 2020 at 12:32 PM
    #5294
    Fishingeek603
    New Hamphire
    Im not tying to kick up the dust on this subject... Iv'e read just about every single forum including the one cited below. the oe bulbs do suck.. end of story. The IIHS even gave them a shitty score for there lights. Its a stupid problem to be having considering we are in the year 2020. I figured I would ask here because this group is less likely to have every light mod known to man kind on the front of there truck ha.
    Tacman19[QUOTED] likes this.
  15. Aug 26, 2020 at 12:48 PM
    #5295
    TACOROSSO
    2017 SR 4x4 5spd
    informative, thanks.
    out of curiosity, do you still run H9s as high beams too? or have you tried those 9011s?
    i skimmed around a bit and it seems like those might be a similar plug-in halogen upgrade, though i haven’t seen crashnburn80’s take on them, or if they’ll run too hot, etc.
  16. Aug 26, 2020 at 1:06 PM
    #5296
    skierd
    David
    Fairbanks, AK
    I am still using the stock h9 high beams. I’ve added a pair of Hella 700 driving lights with 100w bulbs (instead of the supplied 55w) with a 12ga wire harness to supplement my high beams. :) Mo’ light mo’ betta!
    I have also re-aimed my headlights up slightly from stock, roughly 5/8” up at 20’ as that’s the furthest back I can park from the garage door inside my work’s warehouse. This has helped more than the bulb replacements: the high beams now actually shine down the road and the low beams extended at least 75 yards further than the stock aim. I’m still inside Toyota’s recommendations for aim, just on the high side vs the stock aim which is on the low side.
    9011’s won’t fit: their geometry is different than than the H11/H9 bulbs and won’t put the filament in the correct location for optimal performance. I’ve used them to upgrade my wife’s 9005 based high beams and my old Subaru’s 9005 high beams and they are a massive upgrade when appropriate.
    TACOROSSO likes this.
  17. Aug 26, 2020 at 1:21 PM
    #5297
    TACOROSSO
    2017 SR 4x4 5spd
    ah okay that makes more sense. i think i found myself on a T4R (9005) crosspost or something... i’ll be trying out the H9 swap though, thanks again.
    skierd[QUOTED] likes this.
  18. Aug 26, 2020 at 2:17 PM
    #5298
    2k2
    2k2 Flareless
    Zak
    See Build Thread
    Interesting... I thought about a low beam adjustment. Any pointers. These headlights just seem so dim compared to anything I've ever owned. Adding foglights didn't help much (at least not as much as I had hoped )
  19. Aug 26, 2020 at 2:18 PM
    #5299
    8Whiskey2
    8Whiskey2 Stellaaa
    Travis
    Arkansas
    No clue. I didn't measure the light output, but I know when I'm driving there is a (positive) difference from stock.
    They aren't actually that much different looking as far as color output when compared to stock either. Just my two pennies. :thumbsup:
  20. Aug 26, 2020 at 3:52 PM
    #5300
    skierd
    David
    Fairbanks, AK
    sure thing, here’s a write up I did in the headlight thread
    onesixonetwo likes this.
