The SR thread, let's see them!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jeepinoutwest, Jan 19, 2016.
  1. Nov 14, 2020 at 3:49 PM
    #5581
    5465
    5465 Well-Known Member
    South
    2023 TRD Ex Cab
    Finished up my wheels last night & had the Toyo RT’s mounted today. Decided to go a little smaller this time 265/75/16’s.
  2. Nov 15, 2020 at 4:29 AM
    #5582
    mikelh
    mikelh Well-Known Member
    Mikel
    Atlanta
    2016 Tacoma / 2010 FJ Trails Team
    any lift? I see red UCAs
  3. Nov 15, 2020 at 4:45 AM
    #5583
    Freeheelbillie
    Freeheelbillie Well-Known Member
    Billie
    Saint Clair, MI
    2019 Tacoma SR, DCSB
    FRONT END King Stage 3 3” RR Coil Overs SPC UCA’s REAR END King Stage 3 BAMF Shock Relocation Rear AAL Heavy ARB Universal Diff Breather Kit TIRES & RIMS 16” Method Bronze BFG K02 (315/75/R16) ARMOR Demello Off Road Baja Hoop Front Bumper Main Line Overland Rock Sliders w/ Top Plate ¼” Aluminum RCI Fuel Tank Skid RCI Fuel Tank Straps RCI Rear Diff Skid RCI A-Arm Skids RCI – Front, Transmission, and rear Transfer Case Skid DRIVE LINE YotaWerx, BlackHawk Tune Re Geared w/ Nitro 4.56 Package Front ARB Air Locker Rear ARB Air Locker 8” Reverse Clamshell 3.73 & Down Carrier RECOVERY ComeUp Seal Gen2 9.5RS Winch, Synthetic Line ComeUp Seal Hawse Fairlead ARB On Board Twin Air Compressor LIGHTING Squadron-R Pro Amber Fogs (Wide Cornering) Baja Designs Rock Lights Squadron Sport Fogs (qty 4) Baja Designs Bed Light Kit SPODS, HD 8 Circuit Switch Panel
    Just snagged this 2019! Sadly letting my 2007 go to a new home today...
    907rx7, repp089, davidstacoma and 3 others like this.
  4. Nov 15, 2020 at 7:39 AM
    #5584
    5465
    South
    2023 TRD Ex Cab
    2/1” lift with Toytec coilovers & shocks with a 1” block.
  5. Nov 15, 2020 at 9:05 AM
    #5585
    mikelh
    Mikel
    Atlanta
    looks great! How easy does the back sag when there’s a load on? I have an AC with a topper and wondering if I should go 1” or 1.5” in the rear
  6. Nov 15, 2020 at 9:32 AM
    #5586
    Snaeper
    Snaeper Drinks like an 8, Drives like a 3
    Martin
    Phoenix, AZ
    2019 Quicksand SX 2.7 4x4 1990 Toyota Celica ST
    SnugTop Rebel, Infinity Kappa's, ToughDog 40mm
    Are you wanting rake or level with a shell?
    I have a SnugTop Rebel (ACLB) and went with a Headstrong 3-leaf AAL and I got 1.5"~ of lift to pair with 1.5"~ of lift on the front, allowing me to keep my rake when empty, but level when there's stuff in the bed. I think it handles the weight well.
    Our leaf packs suck, so I wouldn't really recommend using a block to lift if you're running a shell, especially if you plan to put stuff back there frequently.
  7. Nov 15, 2020 at 9:45 AM
    #5587
    mikelh
    Mikel
    Atlanta
    Torn between Toytec spacer lift and Bilstein 5100. I won’t be doing any off roading, just want to lift up the vehicle a bit without shelling out on too much. Had high end suspension components on my FJ and I never used them to their full extent, figured the Tacoma won’t really do anything more challenging. I’m trying to level the truck since I don’t tow much.
  8. Nov 15, 2020 at 9:46 AM
    #5588
    5465
    South
    2023 TRD Ex Cab
    It’s going to sag the same way as the stock setup, it just moved the leafs down 1”. Heading home from the tire place with the 4 oem wheels and tires in the back, probably dropped 1”, a bit surprised it wasn’t more.
    I ran the semi-same setup on my 2019 SR 2.7, with a topper and it was perfect with a 1” block. The 2021 SR V6 is close to level without a load ?
    There’s also a 1” BL on that truck, but it’s still a coilover setup with a 1” block. Tires were 285/70/17.
    ETBA, Tacman19, Artjr and 2 others like this.
  9. Nov 15, 2020 at 9:49 AM
    #5589
    kmorgan3
    kmorgan3 Redside Electric, LLC | VLEDS
    Kyle
    PNW
    2020 4Runner SR5 Premium | RAM 1500
    I saw that thread. Glad you pulled the trigger - that was a pretty good deal.
  10. Nov 15, 2020 at 9:52 AM
    #5590
    mikelh
    Mikel
    Atlanta
    That looks just right. It seems like 2” in front with 1” block in the rear is the magic number. I’d like to throw down $$$ for high end stuff but to be honest. The roughest roads I face are pothole in ATL lol
  11. Nov 15, 2020 at 10:03 AM
    #5591
    Snaeper
    Martin
    Phoenix, AZ
    It all depends on what your budget is, really. I've driven a Bilstein 5100 shod 3rd gen and it rode really nice. I spent $1200~ altogether on my suspension and I've been really happy with it's on and off road performance.
    After seeing what my leaf springs were doing when I went to install my AAL's, I'm not a fan of the idea of blocks, but that's just me.
    It's not listed on their website, but Westcott Designs makes an interesting kit which they just expanded to the standard Tacoma suspension. It's a different take on the spacer kit that doesn't f&$* your suspension's geometry. Most customers I've read about who have it rave about the ride (basically that it maintains the stock ride behavior). I'd say find some TRD OR Bilstein take-offs and combine them with the Westcott kit to get the lift and performance for minimum investment. They do a block lift in the rear.
    EDIT: Then again, doing the math on that (~$400 for Westcott kit and ~$200 for Bilstein take-offs) puts you right at Eibach Pro Truck lift kit pricing.
    So maybe consider the Eibach kit, seems like it'll suit the price/performance you're looking for.
    EDIT2: Only potential issue with the Eibach kit is that it's rated at 2" of lift... but that's likely for the V6's. I4's are lighter, so you might end up with more which would likely require an UCA.
    mikelh[QUOTED] likes this.
  12. Nov 15, 2020 at 4:55 PM
    #5592
    Freeheelbillie
    Billie
    Saint Clair, MI
    Thanks man, I ll be heading out to get it early this week. I'll post the details when I get back home.
  13. Nov 16, 2020 at 5:42 PM
    #5593
    OldSkoolArcher
    OldSkoolArcher Well-Known Member
    Nick
    PA
    '24 Tacoma OR, '24 Defender 110, '15 WK2
    Ok, I’ll bite.
    2020 SX, 6 Cyl, 4x4, Auto
    265/75/16 Duratracs on stock suspension (for now)
    A few other cosmetic add-ons.
    The SX seemed like the best bang for the buck to me. I have owned 2nd Gen OR and Sports in past and honestly can’t/couldn’t justify the difference in price again.
    Driveway poser shot.....
    Dmesser92, ETBA, rblalliance and 12 others like this.
  14. Nov 17, 2020 at 10:13 AM
    #5594
    repp089
    repp089 Active Member
    Devon
    New Jersey
    2020 Silver Tacoma SX
    Where did you purchase the bezels for your fog lamps? I just purchased all of the other required parts for the install, but i don’t want to pay $60 for each bezel from Toyota
  15. Nov 17, 2020 at 11:06 AM
    #5595
    TartanEagle
    TartanEagle Well-Known Member
    '17 ACLB 4x4 MT
    Great to hear!
    My '17 2.7L has 16,000 on it --- and still runs like new. :rofl:
    Seriously though, I have no problem believeing 400K maintenance free miles with these guys. Couldn't be happier with my choice. Hope yours continues doing so great!
  16. Nov 17, 2020 at 11:08 AM
    #5596
    TartanEagle
    '17 ACLB 4x4 MT
    I like that domed bed cover. Will prolly allow for better mpg! :hattip::rofl:
  17. Nov 17, 2020 at 11:08 AM
    #5597
    SilverBulletII
    SilverBulletII Well-Known Member
    New England
    2017 Silver Tacoma SR, MT, 4 cylinders, 4X4
  18. Nov 17, 2020 at 12:09 PM
    #5598
    repp089
    Devon
    New Jersey
    Hit 2000 miles this week. So far the truck runs like a dream. Couldn’t be happier. Fog Lights going on next week, wheels and tires to follow. Can’t wait!
  19. Nov 18, 2020 at 7:14 PM
    #5599
    Fullstrut850
    Fullstrut850 Well-Known Member
    Frank
    NW Florida
    2019 SR5 4x4 DCSB White
    Has anyone installed OEM bed lights on 3rd gen? I don’t have the pop out cover for them so I doubt that they are pre-wired but was hoping someone has installed them that could give some advice before buying everything.
    davidstacoma and mikelh like this.
  20. Nov 18, 2020 at 7:21 PM
    #5600
    AlphaQ1ns
    AlphaQ1ns Well-Known Member
    2020 SR DBC V6 4x4
    I have the 2020 SR V6 DBL CAB and when I popped out the break lights it has prewired clamped on the side.
    Fullstrut850[QUOTED] likes this.
