The SR thread, let's see them!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jeepinoutwest, Jan 19, 2016.
  1. Nov 19, 2020 at 2:31 PM
    #5621
    Puppypunter
    Puppypunter Well-Known Member
    Johnny
    2019 Black SR
    Man, do I have a deal for you! I think I have a way of doing the OEM LEDs on an SR. I need a guinea pig though. So if you get the OEMs, I am willing to give someone a set of harnesses to test. No cost, just need a report back on the function. So PM me if you end up getting a set. (By the way, I’m not just wildly guessing these will work, I have tested them as far as I can, and they’ve worked as expected)
  2. Nov 19, 2020 at 2:35 PM
    #5622
    sandiegohasthebesttacos
    sandiegohasthebesttacos Well-Known Member
    tempting but i already have a set of alibaba ones that i'm good with for now. i'm sure someone with an sr or sr5 will take you up on your offer.
  3. Nov 19, 2020 at 3:00 PM
    #5623
    Puppypunter
    Johnny
    2019 Black SR
    Cool, it’s an open offer. Maybe if I stopped calling them guinea pigs... I e tested it with a panel of LED lights, but not the actual headlight yet.
  4. Nov 19, 2020 at 5:01 PM
    #5624
    repp089
    repp089 Active Member
    Devon
    New Jersey
    2020 Silver Tacoma SX
    Good to know. Do you have any experience with morimoto? And I was thinking I would just buy the harness they use on the upgrades models from Toyota. A lot of the OEM parts I’ve been buying are off parts.Toyota.com and a LOT cheaper than at the dealership, so I figured I would stick to them.
  5. Nov 19, 2020 at 5:11 PM
    #5625
    the morimoto xb headlights are considered the best plug and play LED option from the local lighting expert crashnburn80. which OEM harness are you referring to?
  6. Nov 19, 2020 at 5:13 PM
    #5626
    repp089
    Devon
    New Jersey
    They are entirely plug and play? Or did you have to upgrade your wiring? And although I took it with a grain of salt, I was told at the dealership that I would need to upgrade my wiring harness for the LED headlights if I decided to do that
  7. Nov 19, 2020 at 5:19 PM
    #5627
    mdp5094
    mdp5094 Well-Known Member
    Pennsylvania
    2020 Super White Tacoma SX Access Cab
    Mudflaps, KC G4 fogs, TRD grill, Black Letter inserts.
    SR SX in work mode..
  8. Nov 19, 2020 at 5:19 PM
    #5628
    they're entirely plug and play with no upgrade to wiring. i think you do need to tap into a fuse but they give you everything you need to do that.
    TRS makes a harness but it's for TRD only https://www.theretrofitsource.com/toyota-tacoma-oem-led-headlight-conversion?quantity=1
    some guy on here upgraded his SR5 to the OEM LED headlights but I can't find the thread and puppypunter is the first person i've seen to offer a harness for testing. definitely no OEM option though.
  9. Nov 19, 2020 at 9:37 PM
    #5629
    McHugh83
    McHugh83 Member
    2016 sr acess cab
    2016 Toyota Tacoma access cab SR 2.7L 2wd i just paid it off . I want to lift the truck and want to run lt265 75 r16 on the stock sr5 rims that i replaced my steel wheels with since ive had the truck i added cruise control,intermitten whipers, fog lights. Will i need wheel spacers if so what size ? Im new in here so take it easy on me fellows. Will this lift work on 2wd.Screenshot_20201119-230351_Chrome.jpg received_706245563224239.jpg
    rblalliance and SilverBulletII like this.
  10. Nov 20, 2020 at 8:58 AM
    #5630
    Snaeper
    Snaeper Drinks like an 8, Drives like a 3
    Martin
    Phoenix, AZ
    2019 Quicksand SX 2.7 4x4 1990 Toyota Celica ST
    SnugTop Rebel, Infinity Kappa's, ToughDog 40mm
    That lift will be fine, you shouldn't need wheel spacers. A comparable kit to consider would be the Eibach Pro Truck Lift.
    Burns and McHugh83[QUOTED] like this.
  11. Nov 20, 2020 at 4:05 PM
    #5631
    OhioTaco68
    OhioTaco68 John 3:16
    Central Ohio
    16' Tacoma SR5 4x4 access cab Silver Sky Metallic
    AVS in channel window deflectors Predator steps Tinted front windows De-badged all chrome emblems Matte black tailgate lettering Matte black door badges Silver door sill lettering Weathertech mud guards Tacoma bed mat Interior LED lighting Lamin-X yellow fogs Hyper yellow DRL LED 3rd brake light bulbs CLEARZ 3rd brake light lens LED back up lights Access LITERIDER tonneau cover Console cover w/Toyota logo Hondo radio knobs NeoSupreme seat covers TRD shift knob Toyota Dark Satin Alloy wheels Toyo Open Country AT3 tires Red glovebox lettering Red vent rings/ control knobs Husky all weather mats Toyota bed mat
    Looks nice! What is the exact Toytec kit you used?
    VR812 likes this.
  12. Nov 20, 2020 at 4:26 PM
    #5632
    5465
    5465 Well-Known Member
    South
    2023 TRD Ex Cab
    BOSS-TTFCS-2016 - Toytec Boss Coil-overs with 650lbs springs.
    E60-82-007-02-01-P - Eibach Pro-Truck Rear Sport Shocks (0-1.5" Lift) for 05+Tacoma
    BK-1 - Rear 1 inch Block Kit (includes U-bolts)
    I ordered the UCA’s from JBA off-road
    OhioTaco68[QUOTED] likes this.
  13. Nov 21, 2020 at 8:36 AM
    #5633
    Snaeper
    Martin
    Phoenix, AZ
    One thing to add, if you run that in the 3" range of lift, you will definitely need UCA's. Not having a front differential and drive shafts makes you lighter up there, so you'll definitely be close to that.
    McHugh83[QUOTED] likes this.
  14. Nov 21, 2020 at 9:04 AM
    #5634
    sled dog
    sled dog Well-Known Member
    FYI, you don't need to lift the truck to fit those tires. Stock suspension SR, stock wheels and BFG KO2s in 265/75/16:
  15. Nov 21, 2020 at 9:32 AM
    #5635
    Puppypunter
    Johnny
    2019 Black SR
    Yeah, the SR/SR5 use the same circuit for turn and DRL. Because of this, you need to get creative. Since the TRD models have separate DRL and Turn, they can be easily adapted to the OEM LED's. Doing it with the SR/SR5 though is definitely more involved. The best solution I have come up with is integrating a DRL controller into the mix. There are ways around this, but they are kind of pain (tapping back to the stalk switch, tapping rear turn signals, that kind of thing). The harness I made is plug-and-play, much the same as the harnesses being sold for the TRD's is, it just has some added hardware between the plugs.
  16. Nov 21, 2020 at 5:25 PM
    #5636
    are you going the module route like depo? i had those mock trd pro headlights and my biggest problem with those was that there was a >2 second delay from when you used your blinkers to when they would flash on the headlights. i'm guessing the module had something to do with that.
    the headlights i have now have the turn signals on as DRL's (like normal) then to get the white DRL's you have to switch to the parking lights on the stalk so both the amber and the white DRL's are on at the same time. there's no lag for the turn signals though so an improvement on the depo's.
    https://www.alibaba.com/product-det...spm=a2700.galleryofferlist.0.0.aee47bf2qciuzC
  17. Nov 21, 2020 at 5:42 PM
    #5637
    Puppypunter
    Johnny
    2019 Black SR
    Going to incorporate the HDRL controller from VLEDs.
    Edit: They do not have a delay from when you first turn on the signal. When you are done turning though, and the turn signal is turned off, it does take a second or two to go back to white. They would act the same as switchbacks as far as color and function. Like I said, there are ways around that, tying them into the parking lights can be one option. Tapping the rear signals and the stalk signal for DRL is the only way I can see as far as how to do without a controller and still have the stalk switch function correctly. But That is a pretty complicated route. Doable, and if you don't mind complicated, I could talk you through it. But my intent is to come up with a lot more simple approach that people can DIY.
  18. Nov 21, 2020 at 6:08 PM
    #5638
    Bluesjam
    Bluesjam Well-Known Member
    Paul
    2020 Tacoma SR Magnetic Grey Double Cab 4x4
  19. Nov 21, 2020 at 6:23 PM
    #5639
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    Boghog1[QUOTED] likes this.
  20. Nov 21, 2020 at 8:30 PM
    #5640
    Fire
    Fire Well-Known Member
    Humboldt County
    2021 Toyota Tacoma with Poverty Package.
    Steering wheel
    I love this truck.
