The SR thread, let's see them!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jeepinoutwest, Jan 19, 2016.
  1. Nov 1, 2016 at 6:14 PM
    #581
    PuyallupJon
    PuyallupJon 2020 AG Pro
    Jon
    Puyallup, WA
    2020 Tacoma
    You can do all kinds of things with the center cap on the MK6 my friend.
  2. Nov 2, 2016 at 3:51 AM
    #582
    Smoothmove
    Smoothmove Well-Known Member
    Stan
    Dallas TX
    2020 TRD OR CEMENT
    MesoCustoms
    I just did the intermittent wiper switch replacement. Took 5 min.
  3. Nov 2, 2016 at 4:42 AM
    #583
    jeffmansion
    jeffmansion Well-Known Member
    16UTILITY4x4MT2.7
    K&N 63 series CAI, AVS Vent Visors, 16x8 Level 8 MK6 Rims, 285/75/16 MT, Eibach Pro lift, JBA UCAs, Wheelers 3leaf AAL, DV8 skidplate, Westin bedmat, Backrack, swaybar delete, Magnaflow cat-back, 9Drive throttle controller, 2LO Mod, Cali Raised Rock Sliders, Tyger rear bumper, Chinese Body Armor front bumper clone, 10K pound Winch, Smoked headlights, LED Bulbs.
    Thanks. Those decals were already planning to come off. the quality of the vinyl was not great. Truck looks good either way. But they are off now, looks better off, and closer to stock looking. Less decals the better.
  4. Nov 6, 2016 at 2:09 AM
    #584
    Taka The Tacoma
    Taka The Tacoma Enjoy the Roy
    2017 SR 2.7L 4WD
    TRD Rims, duratrac tires
    GreysonTHAO08, Bob1sh, nv529 and 4 others like this.
  5. Nov 6, 2016 at 8:50 AM
    #585
    2016 Tacoma SR
    2016 Tacoma SR Well-Known Member
    HOCO Maryland
    2016 MGM 4Runner SR5
    ToyTec Ultimate lift, FX Pro wheels, 295/70/17 Ridge Grapplers, AFE drop in filter.
    Hey so the order form / build spec sheet on my Tacoma says its a limited slip rear. I have read that the SR doesn't come with a limited slip rear. How do I know what I've got back there?
  6. Nov 6, 2016 at 9:11 AM
    #586
    2016 Tacoma SR
    HOCO Maryland
    Correct, automatic limited slip. So basically traction control then.
  7. Nov 6, 2016 at 9:29 AM
    #587
    2016 Tacoma SR
    HOCO Maryland
    Cool. good to know. Now I just have to get my stability control to stop freaking out at random and significantly retarding throttle response.
  8. Nov 6, 2016 at 9:38 AM
    #588
    2016 Tacoma SR
    HOCO Maryland
    There is a relearn process for the stability system. Apparently installing a lift sometimes freaks it out. I plan to do the procedure buy haven't yet. I hope that solves it.
  9. Nov 6, 2016 at 9:50 AM
    #589
    2016 Tacoma SR
    HOCO Maryland
    lol it's actually something you have to do, it won't auto learn.
    0uTkAsT[QUOTED] likes this.
  10. Nov 19, 2016 at 4:16 PM
    #590
    Taka The Tacoma
    2017 SR 2.7L 4WD
    Installed 2008 Tacoma double cab running boards! Didn't directly fit and had to do some modifications. Also got a trailer hitch from Amazon which needed modifications.
    OhioTaco68 likes this.
  11. Nov 19, 2016 at 5:10 PM
    #591
    2016 Tacoma SR
    HOCO Maryland
    What mods were required to fit the running boards?
  12. Nov 19, 2016 at 5:19 PM
    #592
    Taka The Tacoma
    2017 SR 2.7L 4WD
    Drilling of back brackets, closes to rear tire, to running board as double cab brackets are further apart and isn't a direct bolt on to body.
  13. Nov 19, 2016 at 5:21 PM
    #593
    2016 Tacoma SR
    HOCO Maryland
    OK I picked up a set from a 2012 double cab which will be going on my 2016 double cab however I haven't tried to fit them yet. We'll see what happens on Wednesday when I have time to install them!
  14. Nov 19, 2016 at 5:23 PM
    #594
    Taka The Tacoma
    2017 SR 2.7L 4WD
    Yours should be a direct fit. It's going from double cab to access and viceversa where you'll run into trouble. Good luck!
    2016 Tacoma SR likes this.
  15. Nov 21, 2016 at 3:03 PM
    #595
    jeffmansion
    16UTILITY4x4MT2.7
    Just Fluid Filmed up
  16. Nov 21, 2016 at 10:03 PM
    #596
    rbark11
    rbark11 Well-Known Member
    Bay Area, CA
    great looking truck there. can't wait to swap out the wheels on mine
    jeffmansion[QUOTED] likes this.
  17. Nov 21, 2016 at 10:49 PM
    #597
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
  18. Nov 29, 2016 at 11:17 AM
    #598
    Planterson
    Planterson New Member
    2016 Tacoma, the mere SRDC
    Westin 4" Oval Steps, TUFF AT01 Rims (-13mm), Dynapro AT-M 265/75/R16, Husky X-Act Contour
    Hello all, first post. Thought I'd share my lil' fella. SR Double Cab, shortbed, Barcelona Red. Just put some Dynapros on (265/75/r16) - they ride great on this truck. Haven't noticed any power issues. I have a really wide stance for a Tacoma (-13mm offset) - adding fender flares so they should line up flush when the flares are on. Putting on piano black "Tacoma" badges next week. Then, it's on to fog lights! Still looking for a headache rack that doesn't look ridiculous - not many options for these guys out there yet. Might do roof racks... we shall see.
  19. Nov 29, 2016 at 2:43 PM
    #599
    Toronto Tacoma
    Toronto Tacoma Well-Known Member
    Blair
    Toronto Canada
    2019 TRD Offroad
    None,
    Nice Truck,
    In Canada the SR 4x4 is only offered with a 5spd access cab, How ever it does include the factory colour matched flares,
    Keep us posted on your fog light choice,
    On my SR, I removed the front air dam.IMG_1054.jpg IMG_1081.jpg IMG_1028.jpg
    ExplorHer and CusterFan like this.
  20. Nov 29, 2016 at 9:58 PM
    #600
    Lduenasjr
    Lduenasjr Member
    2016 White Tacoma SR
    Hafa Adai! what's your plans on that 3rd gen? i just recently did a 4inch rough country lift on mine
    vrod671 likes this.
