The SR thread, let's see them!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jeepinoutwest, Jan 19, 2016.
  1. Dec 14, 2021 at 7:14 PM
    #6801
    onesixonetwo
    onesixonetwo Well-Known Member
    Do you know if there's any difference in the specs of the OR wheels and the SR5 wheels?
  2. Dec 14, 2021 at 9:05 PM
    #6802
    Shafenator
    Shafenator New Member
    Ben
    2020 Silver Tacoma SR
    2020 SR with Method NV305 16” and 265 wildpeaks. I need flush center caps those method center caps are hideous….
  3. Dec 14, 2021 at 10:35 PM
    #6803
    Cody830
    Cody830 Member
    Cody
  4. Dec 14, 2021 at 10:38 PM
    #6804
    bamataco4x4
    bamataco4x4 Well-Known Member
    Derek
    2021 Tacoma SR 4x4
    Lol, I got it off eBay. Just search “toyota steering wheel emblem” and you have a ton of choices. I just ordered 2 of the same and they fit on both my 21 Taco and my wife’s 20 Camry. The seller I bought from doesn’t have the listing active anymore but I just went with the cheapest. Paid $28 for the pair. I can’t stand fake chrome so it was necessary along with the 4x4 and V6 badge. Only thing left is the damn 4x4 knob in the cab and I can’t find anything I like to cover it.
    onesixonetwo[QUOTED] likes this.
  5. Dec 14, 2021 at 10:44 PM
    #6805
    907rx7
    907rx7 Well-Known Member
    James
    '20 Tacoma DCSB SR 4x4
    I can look tomorrow but guessing I have about 12 washes on my bottle and have used about 1/4 of it (2 ounces). It's just one spray per door, more for the bigger body panels. It has good hydrophobic properties as well but I bought it as a general drying aid and sealant. It is light enough weight that you can add your preferred wax on top of it for shine and additional protection.
    Also, it's cheaper through autogeek. I always try to order everything through them but run into shipping issues being in Alaska.
    LstMinutePanic likes this.
  6. Dec 15, 2021 at 5:53 AM
    #6806
    Scotfree
    Scotfree I drive slow
    2021 sr 4x4 2.7
    Claybar then Rejex.. then repeat Rejex 24 hours later and follow up with wax.. Rejex works on the fender well plastic too.. it’s boat sealant.
    playdixie likes this.
  7. Dec 15, 2021 at 8:53 AM
    #6807
    tacomacamper
    tacomacamper Member
    2020 DC 4x4 Tacoma
    Beautiful morning here in Conifer
    zacinnc78, PlLLs, SSMTRDOR and 4 others like this.
  8. Dec 15, 2021 at 1:20 PM
    #6808
    onesixonetwo
    Thanks! Do they come with adhesive backing or did you have to superglue it on?
  9. Dec 15, 2021 at 2:51 PM
    #6809
    bamataco4x4
    Derek
    2021 Tacoma SR 4x4
    It has pre installed 3M tape the exact shape of the emblem. I recommend disconnecting the battery, or you’ll be blowing your horn like crazy pushing it on.
  10. Dec 15, 2021 at 4:59 PM
    #6810
    2k2
    2k2 Flareless
    Zak
    Gen 3 SR 4x4 4cyl AC
    See Build Thread
    Thanks for responding with your experience. I may give this a shot.
  11. Dec 15, 2021 at 5:02 PM
    #6811
    2k2
    2k2 Flareless
    Zak
    See Build Thread
    Well I definitely wont be doing this... I'm used to white paint. Wash 2x per year never dry, spray wax once or twice a year. White always looks clean. Thanks for sharing, but I wont be putting this kind of work in....
  12. Dec 15, 2021 at 6:57 PM
    #6812
    Scotfree
    2021 sr 4x4 2.7
    lol.. my old truck was white and hid everything. They do make black wax, (wax that isn’t white when it dries). It makes black paint look amazing imo, fills fine scratches, but I would use a durable sealant first.
    onesixonetwo likes this.
  13. Dec 16, 2021 at 5:43 PM
    #6813
    WinterFalco
    WinterFalco Well-Known Member
    Donald
    2018 Midnight Black SR 4x4 Double Cab
    Added aftermarket Rims and Tires, Fog Lights, Mudflaps, Entune with Nav
    I added the exact same fog light kit to my SR. I drilled a hole in the firewall, sealed it with rush proof paint and put in a gromet to protect the wire. Changed the switch to a $15 dollar one that is blue and better quality. Fog lights work great! I also did add a fuse, so the lights go off when I turn the ignition off, just in case I forget to turn off the fog lights.
    playdixie and Finn-2187[QUOTED] like this.
  14. Dec 16, 2021 at 6:03 PM
    #6814
    littlegreySR
    littlegreySR New Member
    2017 Tacoma SR 4x4
    new 265/70R16 Kenda Klever at2
    only 39lb
  15. Dec 17, 2021 at 5:57 AM
    #6815
    2k2
    2k2 Flareless
    Zak
    See Build Thread
    Wow! 39lb...
    Do they make a 265/75/16?.
    My wheels and tires were solely purchased for weight. I wasn't necessarily concerned with looks. My wildpeak SL are 43 lbs which is light. 4lbs of rotating weight could save some mpg (not much -but every lb helps ). I'm running about 22-23mpg in the summer and 19-21 in the cold.
    tacomacamper likes this.
  16. Dec 17, 2021 at 6:00 AM
    #6816
    2k2
    2k2 Flareless
    Zak
    See Build Thread
    I been using colinite 845 mixed with distilled water in a spray bottle. Works good use it everywhere.. no white residue. Looks awesome and beads for 6 to 8 months. I guess my problem isnt how to protect black paint... I just want it to look nice without the work
  17. Dec 17, 2021 at 7:28 AM
    #6817
    littlegreySR
    2017 Tacoma SR 4x4
    Yes they do make a 265/75r16. 116T is 40.62lb
    tacomacamper and 2k2 like this.
  18. Dec 17, 2021 at 3:49 PM
    #6818
    Gus
    Gus Well-Known Member
    Wayne, Pa.
    2020 Access Cab SR Utility Package Barcelona Red
    Rear sliding window, intermittent wiper switch, center console tray, glove box organizer shelf, WeatherTech front mats and mud flaps, 3D MaxSpider behind-the-front-seats mat, bed lights, MESO climate control rings, XPEL tailgate protection, Desertdoesit.com seat jackers, RAV4 radio knobs, glove box letters.
    Hmmm, I have used Colinite but not with distilled water. Curious to know more about that.
  19. Dec 17, 2021 at 7:23 PM
    #6819
    2k2
    2k2 Flareless
    Zak
    See Build Thread
    I basically shake up the colinite to get it to its thick oily gel-like consistency. Pour some distilled water into an old spray wax container, add some colinite to the same container then shake it up. I add more water/wax until I get the consistency of the spray to come out like thin wax as opposed to water. You'll have to experiment to see what you like. I go through a bottle of colinite per year (which is a lot for this type of wax). I really dont wash my truck very often but since my truck is black I always use this afterward. Its basically almost like waxing it, but it only takes half the time. Spray one panel at a time, wipe clean with a microfiber towel -- done.
    Poor mans spray wax. $20 a year as opposed to $6 to $12 per bottle of spray wax. My son uses it on his taco as well, so it does 2 trucks. Works just as good as the stuff you'd buy in a store and costs way less.
    Colinite is good for this because the overspray doesnt dry to a white chalky residue. You can use it on everything with no worries
    Scotfree likes this.
  20. Dec 18, 2021 at 7:00 AM
    #6820
    Nikolav1990
    Nikolav1990 Well-Known Member
    Niko
    Magog, QC, Canada
    2018 toyota tacoma sr5 access cab automatic 2.7
    Only canadian models come qith the heated seats and the color matched fender flares, i got mine ita a doublecab with the 6ft bed it has heated seats and 4wd v6 for 31500usd still waiting to receive it ordered in late november 2021, i think they put this model here as fender flares really help to protect in the wintertime with the sand they put on the roads the gravel really blasts away at the sides without fender flarws and mudguard and i think at that price you just cant get a better package anywhere cant wait to get it my access cab is really too small for a family of 4
    Finn-2187[QUOTED] likes this.
