The SR thread, let's see them!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jeepinoutwest, Jan 19, 2016.
  1. Dec 18, 2021 at 2:22 PM
    #6821
    LinksFaction
    LinksFaction New Member
    Dylan
    2021 BR Tacoma SR
    2.5 King RR Front and Rear with adjusters Camburg Uniball Uppers OME Dakar Medium duty leaf springs Method MR304 16x8 +0 offset Cooper Discoverer AT3 XLT 285/75/16
    3E0226A4-98E8-4BE7-85B6-8B801D23FAF0.jpg 0FCEC13F-C579-4296-A922-81E4945737FB.jpg My 2021 Barcelona Red Tacoma SR on King 2.5s and 16x8 Method 304
    Pancho8190, drumr04, BTH1 and 10 others like this.
  2. Dec 19, 2021 at 8:15 AM
    #6822
    SSMTRDOR
    SSMTRDOR Well-Known Member
    2020 TRD OR 4X4
    Nice looking lift wheel/tire combo. Post more pics!!!
    Bro, be careful with that license plate on the front dash. If you get in an accident it could fly through the cabin and hurt someone.
  3. Dec 19, 2021 at 2:32 PM
    #6823
    LinksFaction
    Dylan
    2021 BR Tacoma SR
    Thanks man! I’m taking a trip Joshua tree and big bear next week, I’m hoping to get nice pictures there! And yea I actually just got a ticket for the license plate so I took it off lol
    Finn-2187 likes this.
  4. Dec 19, 2021 at 3:05 PM
    #6824
    oyemengitsamie
    oyemengitsamie amie.
    Gainesville, FL
    2020 Toyota Tacoma SR V6 4x4 in MGM
    does anyone know if adding 1.25” wheel spacers on stock sr5 wheels with 275/75/16 tires would rub?
  5. Dec 20, 2021 at 9:05 AM
    #6825
    MGS1
    MGS1 Active Member
    I have 265/75/16 General Grabber ATX, no lift, no rubbing, no cutting needed. There is a post on here re: largest size tires without lifting, rubbing and cutting and this is the size .
  6. Dec 21, 2021 at 10:19 AM
    #6826
    Mazdadan
    Mazdadan Well-Known Member
    Dan
    BONES JONES
    gotta say she did just fine, cab and bed packed full. MPG dropped to 16 and endless downshifting but it as happy with how she did.
  7. Dec 25, 2021 at 2:05 PM
    #6827
    2k2
    2k2 Flareless
    Zak
    Gen 3 SR 4x4 4cyl AC
    See Build Thread
    Most likely... you might get away with 265s
  8. Dec 26, 2021 at 4:02 PM
    #6828
    Snaeper
    Snaeper Drinks like an 8, Drives like a 3
    Martin
    Phoenix, AZ
    2019 Quicksand SX 2.7 4x4 1990 Toyota Celica ST
    SnugTop Rebel, Infinity Kappa's, ToughDog 40mm
    Strong chance, especially with the space increasing the arc the wheel takes when turning, combined with the wider tire. All but a guarantee you'll rub.
  9. Dec 26, 2021 at 4:38 PM
    #6829
    oyemengitsamie
    Gainesville, FL
    sorry, I meant 265*
  10. Dec 26, 2021 at 4:43 PM
    #6830
    Tacomike18
    Tacomike18 Well-Known Member
    J
    I have an sr with the 16x7 wheel and 265/70r16 toyo at tire and when the tire is turned all the way, I have one once from the fender liner.
  11. Dec 26, 2021 at 7:24 PM
    #6831
    Cody830
    Cody830 Member
    Cody
    Anyone here switched to a set of oem trd pro taillights ? If so are they plug and play prolly a dumb question but just curious before purchasing a set hahaha
  12. Dec 26, 2021 at 7:24 PM
    #6832
    radclerk1
    radclerk1 Well-Known Member
    Vic
    2017 Access Cab 2.7L Manual 4x4
    None
    Yes. Plug and play
    Cody830[QUOTED] likes this.
  13. Dec 26, 2021 at 7:24 PM
    #6833
    2k2
    2k2 Flareless
    Zak
    See Build Thread
    I have 16x8 -25 offset 265/75/16 and even after massaging fender liners I still scrub radius rub in reverse at 2/3 to 3/4 turn on the front drivers side with a passenger in the cab mount area is tight but clears. With a little number crunching and an offset calculator you can compare your current wheel offset with the additional 1.25" spacers and get an idea of how close to -25mm you are. The aggressiveness of the tread also comes into play as well. I have wildpeak at3w. If I had a milder at tire I probably wouldn't rub at all.
    With an 8" wide rim, I'd say -20 mm offset would clear. If you get up above (or down below depending how you look at it)-25mm offset the chances of scrub radius rubbing with an aggressive tread pattern will be highly likely.
    Now if the rim is 7" wide then these numbers are out the door and you could probably get away with a bit more poke without rubbing. I did a lot of number crunching when buying wheels cuz I didn't want to rub. I wanted plain 5 spokes, very lightweight, a finish that wasn't black, 16x 8", and some poke. I wound up with scs f5s -25mm I really was looking for something with -19mm offset, but I couldn't find anything.
    If you take my specs 16x8 -25mm (3.5 backspace) knowing I have very minor rubbing and use an online offset comparison tool vs the setup you are looking at you can get a pretty good idea of your clearance.
  14. Dec 26, 2021 at 8:54 PM
    #6834
    onesixonetwo
    onesixonetwo Well-Known Member
    Are you talking about the LED or halogen Pro lights? If LED, I think you need an additional aftermarket harness.
    If you're getting the halogens, where are you getting them from? I'd love to find these but Toyota parts stores are still selling them for a lot.
  15. Dec 27, 2021 at 10:36 AM
    #6835
    TacoMike
    TacoMike Well-Known Member
    Pennsylvania
    '19 SR AC Utility 4x4
    It's been awhile since I posted a pic of my SR Utility, did some hunting on the farm this morning.
    BTH1, MeefZah, rblalliance and 7 others like this.
  16. Dec 27, 2021 at 10:39 AM
    #6836
    MNFinn7300
    MNFinn7300 Well-Known Member
    Erik
    2021 Tacoma SR DCSBV6
    Softopper, Diode Dynamics Fog lights, BD Spot lights
    Baby, it's cold outside.
  17. Dec 27, 2021 at 11:09 AM
    #6837
    littlegreySR
    littlegreySR New Member
    2017 Tacoma SR 4x4
    testing out the new Kenda Klever AT2
  18. Dec 27, 2021 at 1:22 PM
    #6838
    zpcrowson42
    zpcrowson42 Well-Known Member
    17 TACO SR
    TRD Grille, LEDs, MB Wheels, Discoverer AT3 4S 265/75/R16
    Got the Tyger soft shell roll up bed cover for Christmas from the wife this year. So far so good, we'll see how it holds up. 12252.jpg 1225.jpg
  19. Dec 27, 2021 at 3:27 PM
    #6839
    2k2
    2k2 Flareless
    Zak
    See Build Thread
    Once my wildpeak atw3s wear out I'm getting a set of these..
    littlegreySR[QUOTED] likes this.
  20. Dec 27, 2021 at 6:44 PM
    #6840
    Tenricco
    Tenricco Well-Known Member
    Tommy
    2021 Tacoma SR DCSB
    Weather-tech mudflaps, 20% tint
    Few things I’ve done:
    20% tint all around
    Kicker tweeters
    Arm rest cover
    Rek Gen flaps
    Matte gray TRD wheels in falken 265/70s
    Bed lights
    Black chrome OEM exhaust tip
