The SR thread, let's see them!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jeepinoutwest, Jan 19, 2016.
  1. Feb 15, 2022 at 10:27 AM
    #6981
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    I found it. Main power wire had fractured off more or less at the module. I done fixed it.
    TartanEagle[QUOTED] likes this.
  2. Feb 19, 2022 at 9:22 PM
    #6982
    Metal Toy
    Metal Toy Well-Known Member
    2021 2.7L AC 4x4
  3. Feb 19, 2022 at 11:00 PM
    #6983
    Tenricco
    Tenricco Well-Known Member
    Tommy
    2021 Tacoma SR DCSB
    Weather-tech mudflaps, 20% tint
    love it- what kind of fog lights? Also, how did you install- to a switch or factory switch? That’s my next mod on my SR but interested to see your set up. Also, which wiring harness did you purchase?
  4. Feb 19, 2022 at 11:12 PM
    #6984
    Dood86
    Dood86 Well-Known Member
    Kyle
    Everett, Washington
    21 tacoma sr long bed 2wd
    Led lights
    Next need to get sae fog lights and wire third brake lightin canopy.20220219_012305.jpg
  5. Feb 22, 2022 at 5:53 PM
    #6985
    AlphaQ1ns
    AlphaQ1ns Well-Known Member
    2020 SR DBC V6 4x4
    My 2020 DBC V6 4x4 came with the tow package. Like someone stated I believe it was a convenient package. Not bad for 30k
  6. Feb 22, 2022 at 6:13 PM
    #6986
    Tlaloc1916
    Tlaloc1916 Well-Known Member
    Magnolia Tejas
    2021 SRish 4x4
    That’s because it’s a V6 and not the 2.7l.
    SR with the 2.7 don’t come with tow package from what I was told at the dealer.
    MeefZah and AlphaQ1ns like this.
  7. Feb 23, 2022 at 6:04 AM
    #6987
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    Correct.
    I frequently reply to this thread and forget that the SR is made in 6 cyl. For some reason my little brain always associates the SR as being the basiest base 4 cyl like what I got.
    The 4 cyl SR for sure doesn't come with a hitch or tow package.
    I've owned a couple 3rd gen 4 cyl (2017, 2021) in both SR Convenience and straight SR base trim and none has had a hitch or wiring in place until I installed them.
  8. Feb 23, 2022 at 6:05 AM
    #6988
    RunUp
    RunUp Well-Known Member
    great looking truck
    Gus and 2k2[QUOTED] like this.
  9. Feb 23, 2022 at 10:34 PM
    #6989
    Cody830
    Cody830 Member
    Cody
    Just wondering if anyone has swap the oem trd off-road "bilstein" suspension over to their SR , and if so did it give it any kind of ride difference ?
  10. Feb 24, 2022 at 6:03 PM
    #6990
    2k2
    2k2 Flareless
    Zak
    Gen 3 SR 4x4 4cyl AC
    See Build Thread
    My father in law has an OR AC. It rides a good bit stiffer than my SR. I'd imagine it'd be a stiffer ride. I love the SR suspension for a daily driven pavement mobile, but I'm not offroad very often.
    Scotfree likes this.
  11. Feb 25, 2022 at 5:13 AM
    #6991
    Brawwp
    Brawwp Well-Known Member
    Oahu
    2022 white SR 4x4
    Does the SR have more room for tires being that it doesn’t have the plastic fenders?
    I have a 4x4 SR on order and was hoping to get away with 285/70/17 on 0 offset methods with a 2” front level and SPC UCAs. I plan do for full dobinsons eventually, but just to quickly and cheaply fit the tire/wheel combo I want without rubbing.
  12. Feb 25, 2022 at 11:02 AM
    #6992
    2k2
    2k2 Flareless
    Zak
    See Build Thread
    I wouldn't bank on it.
    My 265/75/16 flareless taco rubbed up front on the drivers side in reverse. The place you'll likely have issues will be the cab mount.
  13. Feb 25, 2022 at 11:57 AM
    #6993
    Brawwp
    Oahu
    2022 white SR 4x4
    Yeah I was hoping with the SPC UCAs I can push the wheel forward a little to avoid cab mount hitting. Maybe not though
  14. Feb 25, 2022 at 12:25 PM
    #6994
    2k2
    2k2 Flareless
    Zak
    See Build Thread
    My offset is -25 so I had that scrub radius rubbing on the front bumper. But even still. I was REALLY close to my cab mount. Another 1/2 inch and I would have had some major rubbing. Not sure you'll make it. Might want to research a bit more in some other threads. That being said.. being flareless isn't going to buy you any substantial room in the areas of concern when it comes to rubbing.
  15. Feb 25, 2022 at 12:41 PM
    #6995
    Brawwp
    Oahu
    2022 white SR 4x4
    Gotcha! Thanks for the info. Yeah I’m searching hard, and I know how much everyone hates that “will it rub” post lol.
  16. Feb 25, 2022 at 12:48 PM
    #6996
    2k2
    2k2 Flareless
    Zak
    See Build Thread
    Lol... yeah. Every taco is different. I really wanted 285s with -12 offset until I found out how much work I had to do.
    Scotfree and Brawwp[QUOTED] like this.
  17. Feb 25, 2022 at 4:10 PM
    #6997
    NewMexiMan
    NewMexiMan Well-Known Member
    2016 SR 5 Speed
    Interesting, since most on here claim that size will fit "no issues, no rubbing bro." Unexpected that a mass-market vehicle would have significant individual variation like that.
    MeefZah likes this.
  18. Feb 25, 2022 at 4:49 PM
    #6998
    TartanEagle
    TartanEagle Well-Known Member
    '17 ACLB 4x4 MT
    I think the bigger reason for differences is the wheel. Many buy aftermarket wheels which now changes it away from a "mass-market vehicle".
    I run 255/85R16, stock steel wheels, stock suspension and do not rub.
    I have some weight up front (skids, frnt hitch, sliders), but not a large steel frnt bumper or permanently mounted winch. Can only compare apples to apples, I guess.
    MeefZah likes this.
  19. Feb 25, 2022 at 5:23 PM
    #6999
    AlphaQ1ns
    2020 SR DBC V6 4x4
    Yup, I agree on this one. I have the same size tire on OEM rims and I do hear the rub on reverse in the driver side
  20. Feb 25, 2022 at 7:17 PM
    #7000
    NewMexiMan
    2016 SR 5 Speed
    Good to know, thanks. You like that size?
