The SR thread, let's see them!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jeepinoutwest, Jan 19, 2016.
  1. Jan 29, 2024 at 9:51 AM
    #7881
    Samuel
    Samuel Well-Known Member
    Samuel
    Johnson City, Tennessee
    2022 TRDOR, 2024 RAV4, and 2024 Corolla Hatch
    Nothing major yet.
    If you don’t have any better offers, I’ll give you $20,000 cash.
  2. Jan 29, 2024 at 9:53 AM
    #7882
    SSMTRDOR
    SSMTRDOR Well-Known Member
    2020 TRD OR 4X4
    Looks like a nice clean truck. Keep it!
    YUKONSLY[QUOTED] likes this.
  3. Jan 30, 2024 at 6:37 AM
    #7883
    2k2
    2k2 Flareless
    Zak
    Gen 3 SR 4x4 4cyl AC
    See Build Thread
    Yeah.. seriously... I'd keep it
    YUKONSLY and SSMTRDOR[QUOTED] like this.
  4. Feb 1, 2024 at 6:22 AM
    #7884
    2k2
    2k2 Flareless
    Zak
    See Build Thread
    Man .... I'll tell ya..... Things are getting pretty pricey lately. I'm gonna probably do my 60k service on my 4x4 4 cyl SR once the weather breaks in a couple months. I figure that it's a good idea to hit the drain/refill on my trans fluid as well as get the xfer case since I didn't mess with those at 30k.... I've been in 4WD a lot more in the past 30k, so I think it's a good idea to get a few quarts of fresh trans fluid and see what the xfer case liquid gold looks like. I'm also going to have a good look at my brakes and replace the pads if they are getting low.... If not I'll have them on hand.... maybe I can get 80k or more out of the originals.
    It's gonna cost me about $500 just in fluids and maintenance parts... Seems really outrageous, I remember when $500 could buy you a pretty nice weekend down the shore. Have a look at the parts list if your interested.....
    60k service
    Front diff ~2 qt
    12157-10010 ~$2 fill washer
    90430-24017 ~$2 drain washer
    Rear diff ~4 qt
    Redline 75w85 ~$110 (6QT)
    Xfer case 1 litre
    90340-A0003 fill/drain washer ~$2 each
    Toyota 08885-81080 ~$100
    Transmission
    Torque specs:
    Drain plug - 15 lb-ft (14mm)
    Overflow plug - 15 lb-ft (5mm hex)
    Fill plug - 29 lb-ft (24mm or 15/16")
    Parts:
    Toyota ATF WS fluid - Toyota part # 00289-ATFWS ~6qt $80
    Drain plug gasket - Toyota part # 35178-30010 ~$3
    Overflow plug gasket - Toyota part # 35178-30010 ~$3
    Fill plug gasket - Toyota part # 90301-15004 ~$2
    Cabin filter
    88508-01010 ~$20
    Air filter
    17801-0C040 ~$20
    Front brake pads
    04465-04090 ~$80
    Wiper inserts
    85214-04030 ~$10
    85214-0E140 ~$10
    davidstacoma and pismo61 like this.
  5. Feb 1, 2024 at 6:31 AM
    #7885
    BirchyBoy
    BirchyBoy Well-Known Member
    ‘20 Tacoma SR DCSB
    I got the new wheels (OEM SX wheels) and tires installed and will be getting my sliders in the next couple of weeks. I’m buying a set of RSG from a good friend.
  6. Feb 1, 2024 at 10:10 AM
    #7886
    pismo61
    pismo61 Well-Known Member
    Temecula,Ca.
    SR 4x2 auto.
    Yep.Ive gone to all SuperTech stuff unless they dont have the right spec of lubricant.I change when required.
  7. Feb 1, 2024 at 3:28 PM
    #7887
    Wpnsman
    Wpnsman Member
    VA
    2023 SR 4WD V6 Access Cab
    My "New" 2023 SR was delivered today,
    One owner with 15K miles and very clean. Planning on 265/75R16 tires on new alloy 16x8 wheels. Along with the Eibach Stage 1 kit as I don't want it lifted, just leveled with better shocks/coils.
  8. Feb 13, 2024 at 5:54 AM
    #7888
    JimmyMac603
    JimmyMac603 Member
    Jim
    Here's my "new to me" 2020 SR with HD Series 20's. Its auto with the i4 motor, bit under powered, but I'm not doing anything crazy with it.
  9. Feb 13, 2024 at 6:31 AM
    #7889
    JHP
    JHP Well-Known Member
    Heart of the South
    2022 Whilte Tacoma SR 2.7 DCSB
    Towing Package, Bed Mat, Roll-up Tonneau Cover
    Nice truck! From one 4-cylinder to another, the longer you own it the more you will like it. HUGE difference at the gas pump compared to my daughter's 6-cylinder TRD Pro.
  10. Feb 13, 2024 at 9:22 AM
    #7890
    2k2
    2k2 Flareless
    Zak
    See Build Thread
    The 4 cyl is a turd as far as power goes. I know because I drive one... My son's v6 is a huge difference. It takes some getting used to. ECT PWR will be your friend.
    Pushing heavy rims and tires doesn't help the i4 either .. rotational weight became an important factor for me with my truck.
    davidstacoma likes this.
  11. Feb 13, 2024 at 10:54 AM
    #7891
    Clinch Mountain Preacher
    Clinch Mountain Preacher Serpent handler
    3rd gen AC SR5 4x4
    Also huge difference in maintenance costs and overall reliability especially vs the 2GR-FKS. Those 2.7 Tacos are dope if they match-up with your intended use.
    JimmyMac603, Soonr1, Scotfree and 2 others like this.
  12. Feb 13, 2024 at 12:46 PM
    #7892
    SwollenGoat
    SwollenGoat Onwards and Upwards!
    ‘21 ACLB, ‘99 XCLB, ‘92 RC, ‘85 4R
    Are you doing the trans filter too?
  13. Feb 13, 2024 at 1:46 PM
    #7893
    2k2
    2k2 Flareless
    Zak
    See Build Thread
    Nope. I hadn't planned on it. I would assume I need to drop the pan for that...I was just gonna do a drain/refill. 3-4 quarts. I am curious if I have an "underfilled from the factory" truck
    Scotfree and SwollenGoat[QUOTED] like this.
  14. Feb 13, 2024 at 1:51 PM
    #7894
    2k2
    2k2 Flareless
    Zak
    See Build Thread
    Indeed they are .. easy to work on. No fussing with oil changes. Reliable. Reasonable on gas.
    I love mine, however if I towed regularly, or if I lived in a hilly or mountainous region I would probably hate the i4...
  15. Feb 13, 2024 at 6:57 PM
    #7895
    Ken710
    Ken710 Well-Known Member
    2017 Silver TRD Sport
    Anyone here owned a 4cyl & traded it in for a 6cyl? What did you dislike about the 4cyl that warranted the trade?
  16. Feb 14, 2024 at 5:12 PM
    #7896
    2k2
    2k2 Flareless
    Zak
    See Build Thread
    I didn't trade mine, however my son has an SR SX package V6 (we both have 2020s so the tune and sw is all the same). I have been driving it once a week since he's been deployed just to keep it fresh. The difference is substantial vs my I4....
    He does have a Borla Exhaust system and a K&N intake, so I'm not really sure how much more zip that adds, but it sure does sound tough.
    When I step on the gas with my i4, it just kinda sits there and wonders if you really want to give it that much .... Then it decides to start going..... Then it takes it's good old time getting there.......once it finally gets up to speed its fine. I will say that ECT helps the laggy response quite a bit. The V6 doesn't lag quite as much and when you step on it it has the ass to get up and go. I find myself constantly having to slow it down in my son's V6.
    I have also noticed on hilly and mountainous terrain that the i4 seems to labor a little going up hill, like it doesn't want to get out of 4th gear, and if it does it's not for very long. I really haven't had the V6 in any elevation, so I can't say how that does, but I would assume much better.
    I dont tow much, but I would say that I'd have to get a V6 if I was doing any type of regular towing ..my son has a bass boat he tows with his truck.
    I feel like my i4 really doesn't have any low end power ... In other words.... Say I'm cruzin along in 2nd or 3rd at 20-30mph..... And I punch it to get up and go quickly... There just isn't enough ass..... It's not like that at all in the V6.
    All things being equal... Access cab vs access cab... I would still buy the i4 again due to ease of maintenance and proven reliability. I suppose if I wanted more pep in my step I could get an LCE header, a higher flow exhaust, the tdr air accelerator, and drive with ECT on all the time.
    I wouldn't trade mine for a V6 unless I towed or lived in the mountains... I could see the i4 just being a PITA to drive in either of those situations
  17. Feb 14, 2024 at 5:27 PM
    #7897
    Scotfree
    Scotfree I drive slow
    2021 sr 4x4 2.7
    Do you think the accelerator helps? I’ve been pondering this upgrade, I run an afe high flow dry drop in with your mentioned parts combo, but not the accelerator, I was kind of thinking the air just gets all jumbled up in the box Anyway once it hits the filter and then the charcoal filter. Maybe smoother air into the box helps in some way ?
  18. Feb 14, 2024 at 5:38 PM
    #7898
    3rd gen AC SR5 4x4
    Totally...can't lie the V6 is more low end get-up-and-go..the v6 in an access cab must be fun
  19. Feb 14, 2024 at 6:55 PM
    #7899
    Nyrob
    Nyrob Well-Known Member
    Robert
    2021 SX 2.7 AT 4WD
    5100 1.1 Front, 5125 Icon Stage 2 Rear, 5.29's, LCE Header
    I know its not apples to apples but after some mods being re geared tuned and a header i will say my 4 banger is a night and day difference over stock i also just switched from 265/75/16's to 235/85/16 same height but thinner and even with my mods the thinner tire made a noticeable difference. If i was stock all over again first thing i would do is OTT tune it and then 235's, keep the weight down and the tire size within reason.
    Tlaloc1916, JHP, Jim727386 and 8 others like this.
  20. Feb 14, 2024 at 7:26 PM
    #7900
    Scotfree
    2021 sr 4x4 2.7
    Your truck is looking good man. I like the skinnies too. I don’t drive it enough to need the tune,YET.
