The SR thread, let's see them!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jeepinoutwest, Jan 19, 2016.
  1. Oct 20, 2017 at 11:15 AM
    #1901
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    Well... YOU actually have an sr5, if we’re talking about “true” :)
  2. Oct 20, 2017 at 2:55 PM
    #1902
    cbrady21
    cbrady21 Member
    Conor
    2016 Tacoma
    Did you do a custom home-link rear view? My stock SR only has the non-compass rear view. Are cables stowed away above the cab ceiling?
  3. Oct 20, 2017 at 4:24 PM
    #1903
    7r41lbr34k3r
    7r41lbr34k3r Practitioner of the mechanical arts.
    Houston, TX
    '21 Tundra 1794 OR
    Yep, the wires run behind that vertical plastic piece .. above the headliner, down the driver's side a-pillar, through the speaker port in the dash and into the ignition(compass power)/ hazard (homelink) fuses via fuse taps. It's grounded to some random bolt near the ECU.
    The mirror is a Gentex 50-GENK45AM.
    Greenbean likes this.
  4. Oct 21, 2017 at 6:10 PM
    #1904
    RJ_Oh
    RJ_Oh Member
    RJ
    '17 Utility
    624AC852-111E-45C5-B05E-81367B90326B.jpg 2B72078A-E409-4AFC-A82F-62653B7301E5.jpg
    ‘17 Utility
    Bray, GreysonTHAO08, Skeou and 10 others like this.
  5. Oct 21, 2017 at 6:13 PM
    #1905
    Sil
    Sil Of the Earth
    Georgia
    2017 Tacoma SR MGM i4 5 speed 4x4 aka. Vulcan
    Pending..
    Is that a black "vortex generator" sticker behind your rear wheels?
    Edit: Eyes fooled me.. it is a cut out towards the top. I still like it. It gives it some pop.
  6. Oct 21, 2017 at 6:21 PM
    #1906
    RJ_Oh
    RJ_Oh Member
    RJ
    '17 Utility
    Just some simple graphics I had made to break things up a little
    Sil likes this.
  7. Oct 21, 2017 at 6:24 PM
    #1907
    Sil
    Sil Of the Earth
    Georgia
    Pending..
    Looks good. I have the exact truck. :thumbsup:
    RJ_Oh likes this.
  8. Oct 21, 2017 at 7:21 PM
    #1908
    RJ_Oh
    RJ_Oh Member
    RJ
    '17 Utility
    Haha thanks! yes the sombrero is color matched MGM
  9. Oct 21, 2017 at 7:57 PM
    #1909
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    Had me scratching my arse trying to figure out what it was. :D
  10. Oct 21, 2017 at 8:11 PM
    #1910
    09 Redneck
    09 Redneck Well-Known Member
    Ga
    Looks great. Any lift? Wheel and tire info please...
  11. Oct 21, 2017 at 8:12 PM
    #1911
    RJ_Oh
    RJ_Oh Member
    RJ
    '17 Utility
    something a little different than plastidip. Duplicolor did the trick
    Stock suspension.
    265/75/16 st maxx on 16x8 SCS F5s
    Weekend@Bernie's and 09 Redneck like this.
  12. Oct 22, 2017 at 9:35 AM
    #1912
    TACOROSSO
    TACOROSSO Well-Known Member
    2017 SR 4x4 5spd
    I love those wheels; got any shots looking straight down the side of the truck? I’m curious what the poke looks like without flares. Nice setup, looks great.
  13. Oct 22, 2017 at 12:56 PM
    #1913
    Thirty8special
    Thirty8special Well-Known Member
    Lucas
    AL
    2017 Tacoma SR
    Grill, lights, wheels & tires
    Are any other SR owners running a scangaugeII? I picked mine up the other day and averaged about 23mpg before I figured out I could go in and change the tank size, engine size, etc. Now I am averaging 29mpg according to the gauge! That seems crazy high for a Tacoma! I haven't filled up and calculated my average mpg off miles driven yet so it will be interesting to see if the scangaugeII is accurate
  14. Oct 22, 2017 at 2:04 PM
    #1914
    09 Redneck
    Ga
    @7r41lbr34k3r may have one.
    7r41lbr34k3r likes this.
  15. Oct 22, 2017 at 2:48 PM
    #1915
    7r41lbr34k3r
    Houston, TX
    '21 Tundra 1794 OR
    Yep, I have one.
    @Thirty8special , did you calibrate it to the instructions?
    Mine is adjusted about 8% from the default setting, it was not accurate straight off the shelf.
  16. Oct 22, 2017 at 5:46 PM
    #1916
    Thirty8special
    Lucas
    AL
    2017 Tacoma SR
    At first it was not adjusted but then i went through and thought I did the calibration but there was obviously user error :rofl:scangaugeII said I averaged 29.4 mpg on this tank. Topped off 11.151 gallons tonight with 251 miles on the trucks trip counter, so 22.5mpg. Looks like ill be redoing the settings tonight
  17. Oct 22, 2017 at 6:23 PM
    #1917
    fdb03taco
    fdb03taco Well-Known Member
    Danny
    SOMD!
    2014 Tundra SR5 CrewMax 5.7 4x4
    SR guys, add fog lights or a low profile light bar behind the lower grill? I have ditch lights already. Thoughts?
  18. Oct 22, 2017 at 9:11 PM
    #1918
    Big Dustin
    Big Dustin Well-Known Member
    Dustin
    Denver, Colorado
    '17 Tacoma DCSB SR 4x4
    5100's all around, OME 887 with 1/4" spacer, icon 3 leaf aal. 255/75/17 BFG KM's on 4runner pro's. Rigid led pods. Debadged and tinted.
    I kind of went in between the two options. I added some Cali raised led pod lights in the factory locations. Their brackets and wiring harness make it a good setup for us no fog guys.
    CaliRaisedLed likes this.
  19. Oct 22, 2017 at 11:10 PM
    #1919
    Adrawk
    Adrawk Active Member
    Adam
    Riverside, CA
    2014 Tacoma Prerunner SR
    do tires count?
    I was thinking of going with the Baja Design Squadron sports in the factory location of the fogs, Baja Designs also had a bracket/bezel/wiring kit to for the Taco. I don't use fogs but if your out in the middle of nowhere and need some light then I figured these will play God and let there be light!
  20. Oct 23, 2017 at 4:13 AM
    #1920
    RJ_Oh
    RJ_Oh Member
    RJ
    '17 Utility
    16x8 SCS F5 with 3.5” backspace
