The Start Of My HID Retrofit
Discussion in 'Lighting' started by WATacoRider, Dec 22, 2009.
  1. Dec 22, 2009 at 4:47 PM
    WATacoRider
    WATacoRider [OP] Well-Known Member
    TRD Sport 4x4
    I ordered a couple of temporary lights to use. A used driver side and aftermarket passenger side.
    Bought some TL projectors. Then bought some Philips 85122+. Mitsubishi ballasts and harness. Then Gatling shroud.
    I only started working on 1 side. I wanted to see how it would go. Well,I finally manage to test fit the 1 i've been working on today. But it sure wasnt simple. I live in an apartment, and there isnt a level wall I can shine my light at to see if the cutoff is level. So I have to leave the property to look for a location.
    When I first got to the location, about 5 mins away. I put my projector setup in and then try to connect the ballast... FFFUUUU. My projector sits too far inside. The ballast cap wont fit on the bulb. Hitting the outside of the housing. Needs about 1/4" or so more.
    Drive back home, did a little more cutting. Then head back out again. So I'm mounting the headlamps again and connect the ballast. Then connect the harness and FFFUUUU, forgot the adapter at home. [​IMG].
    So I start putting everything back away and I drop a screw/bolt that holds my headlights into the engine bay. Sound like it hit my skid plate. So I remove that, and find my screw. Then head back home again to get my adapter.
    Head back to location, and FINALLY get to turn on my projectors. Looks good. Looks pretty level. Might need an ever slightly clockwise rotation, but it should be fine as is.
    I'm still tryin to decide on how I want to cover it up. I would prefer a vacuum formed cover. But the investment is not worth it to me, for just 1 use. The gatling shroud, I did not like. I might just use a flat sheet of ABS.
  2. Dec 23, 2009 at 5:27 PM
    WATacoRider
    TRD Sport 4x4
    Well, I've decided that the driver side is currently too low. I didn't notice it the first time, but my height elevation is maxed out in this pic, and I still need it to be up a little higher.
    My passenger side, the height seems to be fine, but I need a little bit counter-clockwise adjustment. In the picture, I dont have all bolts on for my headlights. When I put on the last bolt, the cutoff is a little bit closer to level. I may leave it as.
  3. Dec 23, 2009 at 6:27 PM
    rossk35
    rossk35 Do Work Son!
    hawaii
    07 TRD Sport Supercharged
    TRD S/C/TRD Intake/TRD Boost Gauge/DT Headers/OEM TL/ZKW retro/Pioneer DVD w/Ipod/Magnaflow/20% Tint/BHLM/JL 10" sub, JL VR components, JL 450/4 amp/Helwig Sway bar/Viper 791/ 18" limited 4runner rims
    For the height adjustment park behind a normal height car ex, camry, accord, civic, etc and have the top of the cutoff be right on the bottom of the side view mirrors. Anything higher then that and you will blind them when your stopped at a light. Here's what my tls look like before I painted them. I used ABS plastic which is painted black and a completely round shroud.
    And complete on the truck
  4. Dec 23, 2009 at 9:47 PM
    WATacoRider
    TRD Sport 4x4
    what did you use for that shroud/benzel?
  5. Dec 24, 2009 at 7:57 AM
    bajamoon
    bajamoon Well-Known Member
    STEVE
    Whittier
    it says abs plastic. both look good and something i would like to do
  6. Dec 24, 2009 at 7:51 PM
    WATacoRider
    TRD Sport 4x4
    Well yeah, but I'm talking about the perfectly round peice around the lens.
    So I adjusted both sides and FFUUU, now the driver side is too high. Maxed out trying to lower it, but it wont go lower. :eek: At first, I thought they were right on, until I double checked my height. I'm using my halogens as a reference.
    The passenger side is good enough for me. It's not 100% level, but about 98-99% there. And I have plenty of adjustments to go up and down. Can probably shim the headlamps to get it even closer if i tried.
    Silverstar Ultra
    Driver side
    Passenger side
    Together
  7. Dec 27, 2009 at 7:27 PM
    WATacoRider
    TRD Sport 4x4
    Did more adjustments. I think i got it as close as it's going to get. Hard to tell for sure without securing that 4th bolt, but holding it in place seems to be very close.
  8. Feb 2, 2010 at 5:52 PM
    WATacoRider
    TRD Sport 4x4
    All done.
    [​IMG] [​IMG]
    Running the wires isnt as close as I would like it, going across the engine bay, but it works. Didnt have to drill a hole to mount the relay. There were a few factory holes. I used the one right next to the coolant pipe. You can make out the relay on the 1st pic on the bottom. It's black.
  9. Feb 2, 2010 at 5:53 PM
    WATacoRider
    TRD Sport 4x4
    I raised it slightly, after this pic was taken.
  10. Feb 2, 2010 at 5:57 PM
    AzogSS
    AzogSS Well-Known Member
    Andy
    Soda City, SC
    2008 Tacoma / 2011 FJC
    Looks good! I bought some temp lights off another TW member and will begin mine soon. Any pointers?
  11. Feb 2, 2010 at 6:11 PM
    i2andom81
    i2andom81 Well-Known Member
    Denver
    08 black prerunner
    Fox coilovers and resi rears, 20% tint, wet okole trd seat covers, LCE engineering headers, custom magnaflow exhaust, afe cai, satoshi grill, URD supercharger, retrofitted headlights, weather tech mats, standard duty leafs, allpro front bumper and uca
    you did good. did it a lot cleaner than my first attempt!
  12. Feb 2, 2010 at 8:23 PM
    ElectronMan
    ElectronMan Well-Known Member
    I was wondering what was going on with this pic, but I then remember what you told me. Glad you got it straightened out. The retro looks nice.
  13. Feb 2, 2010 at 9:34 PM
    G-Sak
    G-Sak Well-Known Member
    PNW
    2005 TRD Offroad SR5 DC 6 speed
    FX-R Projector Retrofit with Apollo Shrouds, Digital HID 55 watt ballasts, D2S Philips 85122+ bulbs in the Winter and Digital HID 55w 5k bulbs in the summer, Bakflip G2, Pop N Lock, Tint, Grillcraft with PIAAs behind it, ScanguageII and a few audio/video upgrades.
    Looks good! I like how the shrouds turned out :)
  14. Feb 2, 2010 at 10:57 PM
    supremetaco2
    supremetaco2 Well-Known Member
    concrete jungle, oahu
    04inacoma
    +hp, lifted, lights, dif breather mod, debadged, shorty antenna...
    turned out very nice after all the crap that you went through... lol
  15. Mar 10, 2010 at 1:19 PM
    RDAY
    RDAY Well-Known Member
    NY
    07 Tacoma SR5 4x4
    rosse how thick is that abs plastic like 1/8" where can u get it?
    also is it just a perfect circle sitting in there or did u trace it to cut it out somehow. I to am curious what u used for a shroud also? Is it possible to use the gatling shroud but just have the tip of it showing like u have?
    It just looks alot cleaner and u have no screws showing like u would if u didnt use the abs
