The Sticky Is Wrong!!
Discussion in 'Wheels & Tires' started by CaseyJones, Oct 20, 2013.
  1. Oct 20, 2013 at 2:26 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    also note OP, every truck is different. what'll fit on someone's truck might not fit on someone elses
    a friend of mine just put 265/75r16's on his stock truck and they slightly rub the frame at lock
    minute differences between trucks- suspension wear, slight imperfections/differences in steering angles, blah blah blah makes each truck unique.
  2. Oct 20, 2013 at 2:28 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Front spacer lifts ride harsh and can result in a broken lower shock eye.
    They increase travel by the thickness of the spacer, but they don't increase the travel of the shock.
    Your piston and valve body become the jounce snubber.
    Run a lift that replaces the shocks, or moves the lower mounting point for the spring, which extends the shock and maintains the same upper travel limit on the piston.
  3. Oct 20, 2013 at 2:29 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
  4. Oct 20, 2013 at 2:38 PM
    CaseyJones
    CaseyJones [OP] Active Member
    Toronto
    09 4x4 Dbl Cab TRD Sport
    I've run a front spacer lift on my old truck. A Nissan Frontier for over 10 years and no issues. Ill take my chances.
  5. Oct 20, 2013 at 3:11 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    This ^^^^^.....and....
    That ^^^^^
  6. Oct 20, 2013 at 3:19 PM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    The first set of wheels I ran right after I bought my truck new from the lot with 63 miles was Ultra type 164 with 4.25" back spacing and Wild Country TXR (Les Schwab brand) 265/75R16 on stock suspension and they rubbing only on the passenger side but at the top of the outer part of the mud flap at full lock. For some reason it didn't rub the driver side with my fat ass driving just the passenger side. It leads me to believe but I never really measured it that the tire size slightly differs from MFG to MFG even though the sizes are printed the same on the side walls.
  7. Oct 20, 2013 at 3:46 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Backspacing is wrong
    The sticky is for stock wheels
  8. Oct 20, 2013 at 3:53 PM
    sfcadams
    sfcadams Retired Senior NCO
    Dan
    Elizabeth, Indiana
    2011 TRD Off Road DCSB Prerunner Skeewped
    Wut?
  9. Oct 20, 2013 at 4:15 PM
    CaseyJones
    Toronto
    Great post. IMO the above post should be in the Sticky.
    I just hope this first lift doesn't lead to the dreaded Lift Obsession Disease. I ended up with 37"s on a Titan I owned and eventually sold it due to poor gas mileage.
  10. Oct 20, 2013 at 4:16 PM
    OZ-T
    Peter North
    British Columbia
    I can kinda see the OP's point , in the sticky it wouldn't hurt to say " Largest tires on stock suspension , stock wheels "
  11. Oct 20, 2013 at 4:49 PM
    whahahajr
    whahahajr Lone Star Club
    jimbob
    New Braunfels, Tx
    07 Tacoma TRD
    Camburg Uniball UCA, ARB Front Bumper, TAG rear bumper, OME rear shocks, All Pro 3" leaf springs
    This is the last time I read a 1 star thread. Good luck with your 2013 goals of proving everyone wrong on TW OP...
  12. Oct 20, 2013 at 4:54 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    You're welcome.
  13. Oct 20, 2013 at 4:57 PM
    OZ-T
    Peter North
    British Columbia
  14. Oct 20, 2013 at 5:24 PM
    CaseyJones
    Toronto
    Bumped up the Star Rating just for you.
    The Toytec Ironman lift looks pretty good for just $600
  15. Oct 20, 2013 at 5:39 PM
    #35
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    To be fair though, sticky does say 'depending on wheels'. :notsure:
    The Ironman lift is a good lift, check out Sierra Expeditions for that same lift, not sure who has the better pricing.
  16. Oct 20, 2013 at 5:41 PM
    #36
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    Which is more accurate, it's the dimensions that matter, not the wheels themselves.
  17. Oct 20, 2013 at 5:44 PM
    #37
    EFalco50
    EFalco50 Woah! How did that get here?
    Ethan
    Corpus Christi
    2012 Single Cab 4x4
    Weather Tech Floor liners, AFE drop in air filter, BFG All Terrain's, Fog lights, Reese Hitch, Undercoating/Rustproofing,
    Don't do a spacer lift, those are for posers.
  18. Oct 20, 2013 at 6:26 PM
    #38
    CaseyJones
    Toronto
    Wow, it's $200 more at Sierra.
    The Ironman looks like the way to go. 2" susp lift for $600 that should clear the rub. Would rather not trim in case I ever decide to sell.
    Thanks
  19. Oct 20, 2013 at 6:46 PM
    #39
    OZ-T
    Peter North
    British Columbia
    Yeah , 16 , 17 or 18
    " For 2005+ Tacomas: 265/70/17, 265/75/16 or 265/65/18, depending on what size wheels you have "
  20. Oct 21, 2013 at 5:30 AM
    #40
    teneighty
    teneighty I'd rather be skiing...
    Right behind you. NY
    18’ F150 SCREW LB 3.5 EcoBoost
    Bilstein 5100’s (x4), 275/65/20 Cooper XLT AT3’s
    If you're buying parts anyway why not go the better route and pay an extra $100 (maybe) and just get some 5100's for the front? Then we all won't have to say we told you so...
