The stock Toyota Battery is hot garbage.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Woodrow F Call, Jun 2, 2020.
  1. Jun 2, 2020 at 7:43 AM
    Woodrow F Call
    Woodrow F Call [OP] Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    This is a vent thread for me.
    I've had the truck since April 2016. The original battery was replaced within two years. I replaced the "replacement" battery yesterday. With both, I had issues with corrosion and the battery hold down bracket was rusted up. Lately, the truck has had issues starting. If I didn't drive for 24 hours, it just barely cranked.
    I wire wheeled and degreased the parts, painted them, and installed an Autocraft AGM. It's the one made by Johnson Controls which looks to be relabeled for several companies: Duralast, Autocraft, Die Hard, Interstate.
    Hopefully, this one does better. I did get a 20% coupon by putting in a junk email address and buying online at Advance Auto.
    Edit:
    Charging at 13.81 VDC
    Parasitic Loss for Truck: 9 mA
    Parasitic Loss for Ham Radio: 10 mA
  2. Jun 2, 2020 at 7:45 AM
    24-7 Well-Known Member
    Phil
    Florida
    16 TRD OR 4Door 6MT
    Driver, KO2's, Open Y-Pipe
    My original '16 battery finally got replaced this year. 4 hot ass Florida summers.
  3. Jun 2, 2020 at 7:49 AM
    boynoyce
    boynoyce .
    16SR5AC4X4V6QS
    That’s unfortunate.
    With your luck you should probably invest in a power pack backup.
    I heard batteries don’t last long in warmer climates, but not sure since I live in an area with four seasons.
    My 10/15 manufactured truck is still cranking strong on the original battery.
  4. Jun 2, 2020 at 7:49 AM
    THE_KiRRAx
    THE_KiRRAx Well-Known Member
    Tampa, Florida
    2016 BBP Tacoma SR5 DCSB
    The original battery in my '16 just died like a month ago, and same as above, Florida heat liked to cook it. With that said yes it did show signs on corrosion on posts and the tie down is kinda ugly. But hey....I'll take 4 years.
    sparkyv and tonered like this.
  5. Jun 2, 2020 at 7:50 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    It is interesting about the many posts of the early failures on the OE batteries.
    Mine is still going strong, but I did just notice a bit of corrosion starting on the negative terminal that I will take care of. Our Subaru had the battery swapped, but it had several deep cycles as the interior lights have no timing on the relays. The kids would forget to shut them off. The second battery had a lot of corrosion on both terminals that I treated.
    The weird part is that this is the first time since I was a kid that I had seen anything happening on untreated terminals.
    I have a hardwired VM on my bike to monitor battery and R/R condition. I do keep forgetting to monitor the Taco, but even during the long COVID sits, the thing started strong.
    Hopefully the AGM fixes the issue for you.
    Junkhead and Taco16LB like this.
  6. Jun 2, 2020 at 7:58 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    I got 8 years on #1 original Toyota
    Same for #2 aftermarket
    6 months into #3 all is well
    Hope it makes it to 2028
    #2 battery was $102
    #3 battery was $174
    4 seasons here and I park in the shade in summer.
    StayinStock and tonered like this.
  7. Jun 2, 2020 at 7:59 AM
    Woodrow F Call
    Colorful Colorado
    I had a 1986 Monte Carlo for 7 years and I never replaced the battery. I even had to revive it after sitting dormant for a year. Duralast lead acid battery. Most batteries I've had were better than this one.
    tonered likes this.
  8. Jun 2, 2020 at 8:00 AM
    JEEPNIK
    JEEPNIK Well-Known Member
    2020 Voodoo Blue TRD Sport
    Oft times short battery life is traceable to three likely causes. Poor maintenance, including loose connections and corrosion. This leads to under charging.
    Poorly done electrical modifications. Or insufficient/inadequate charging from ether sitting too long or not running the vehicle long enough to fully charge the battery.
    Chew, VirusCage and robssol like this.
  9. Jun 2, 2020 at 8:00 AM
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    same here, just a few months short of 5 yrs and I use it daily and start/stop multiple times a day. no corrosion so far.
    Taco16LB likes this.
  10. Jun 2, 2020 at 8:04 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    I didn't even give mine a chance. I had it warrantied (reimbursed).
    TheAredub, Taco16LB and tonered like this.
  11. Jun 2, 2020 at 8:07 AM
    Taco16LB
    Taco16LB Well-Known Member
    Warm climate here in the south . Gm battery in Equinox from Jan 2015 still original with no problem . 2016 Tacoma battery died in just under 3 years . I do carry a NOCO jump pack in both vehicles . I like the idea that I can wait for a battery event in the GM by having the jump pack , and my 96 GM battery lasted until 2004 , maybe longer but we sold the car . ,Then my 2004 gm battery was changed out in 2010 just to be safe . I was working king out of state and did not want the wife to get stranded .
    I could go on but the Toyota battery was the earliest failure of a battery I have ever had unless it was in a boat or a bike .
    AGM NorthStar 27F in the Tacoma now , compliments of Toyota.
    G8R_Taco and tonered like this.
  12. Jun 2, 2020 at 8:08 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    The big difference between your Monte Carlo and the Taco is likely parasitic drain from all the ECUs? That might also be a factor for some batteries with small differences in or between batches? Just spitballing there, since even TW is a small sample of owners.
    It would be cool to get some real statics here but likely impossible.
    Bleep100, Lawfarin, Junkhead and 2 others like this.
  13. Jun 2, 2020 at 8:10 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    So true on the jump packs. They are an amazing bit of tech in today's world. I keep putting off getting one for the daughter's car. That is just dumb on my part because even getting a jump has the potential for big, costly screw ups.
    Junkhead and shakerhood like this.
  14. Jun 2, 2020 at 8:11 AM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    Replaced my OEM battery after three years with an Odyssey just because 3 was enough. It seemed to still be going OK, but was taking no chances. I should be good for a long time now.
    G.
    Junkhead and Modesto Tacoma like this.
  15. Jun 2, 2020 at 8:11 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Our '06 4Runner went 9 years on the original Panasonic battery, but it was garage-kept and averaged 6k miles per year. These newer vehicles have more things that stay "on" even when off -- there's a pump that turns on after the vehicle has been off for a while to check for fuel system air leaks, for one -- and all the keyless entry stuff, etc. I think they just wear batteries out faster.
    Running to the store to get a new battery for the '06 today, 5 years on a Duralast Gold isn't bad.
  16. Jun 2, 2020 at 8:16 AM
    STrooper
    STrooper For HIS glory!
    Jack
    NC
    2018 TRD Sport QuickSand / 2020 TRD Sport Cement!
    My oem battery still going strong. They have served me very well both my Tacoma and my wife GX470.
  17. Jun 2, 2020 at 8:21 AM
    Woodrow F Call
    Colorful Colorado
    Acid/Water levels were checked.
    I was constantly dealing with corrosion with this battery. I cleaned the terminals several times. They were always tight. I eventually put some of that terminal oil which stopped the corrosion at the terminals. Still got it on the battery hold down bracket.
    The truck does sit now as my I travel more for work than I used to. But it would get driven at least once a week. Still, I've not had to baby sit a battery so much. I've had a few cars and never needed to deal with a battery as often.
    I also have a ham radio lead attached to the positive post, but it's always off. I'm planning on checking for current draw to see if it's draining. Still, this is the first battery/vehicle that has given me this problem.
    tonered likes this.
  18. Jun 2, 2020 at 8:23 AM
    Woodrow F Call
    Colorful Colorado
    That is a good point. I don't know if that test runs enough to drain the battery like that. Maybe so.
    Still, all the corrosion that came with this battery is unacceptable. Both batteries were like this. I've really never had so much issue with a lead acid battery.
    SmoPo16, shakerhood and tonered like this.
  19. Jun 2, 2020 at 8:24 AM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Pretty sure Your 4runner has the same EVAP pump.
  20. Jun 2, 2020 at 8:29 AM
    Tacoma091919
    Tacoma091919 Well-Known Member
    Tim
    2019 OR DCLB
    I came from an 06 4Runner, I kid you not the battery finally stopped holding a charge 2 months before I traded it in. 13 years on the OEM is just mind blowing. Never garaged and cold winters / hot summers. Every winter I’d think well one if these cold mornings it’s not going to start but it cranked over every time. Finally it started to lose charge over the summer when the truck would sit and I’d commute on my motorcycle. I’ve always had good luck with the auto zone duralast batteries before that.
