The stock Toyota Battery is hot garbage.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Woodrow F Call, Jun 2, 2020.
  1. Jun 2, 2020 at 11:15 AM
    #41
    Taco16LB
    Taco16LB Well-Known Member
    I wonder if the reason that some newer batteries do not last as long is because of using newer recycling lead processes to meet EPA standards ? I say this because NorthStar makes a big deal about using virgin lead in its batteries .
    TartanEagle[QUOTED] likes this.
  2. Jun 2, 2020 at 11:24 AM
    #42
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I recently found out that it is not pure lead in battery plates to start with. Both the cathodes and anodes are different alloys. I would imagine that as long as the crystals are skimmed off in the smelting process, there should be not great difference compared to virgin.
    Now, the quality of processing may come into play?
    Cvarnz46 likes this.
  3. Jun 2, 2020 at 11:25 AM
    #43
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I had a delco in my 01 tundra, it lasted 10 years...replaced it with a deka, it was still working perfect after 9 years. If i was to get a replacement battery deka would be it.
    VanGo3 likes this.
  4. Jun 2, 2020 at 11:51 AM
    #44
    ryan760
    ryan760 Well-Known Member
    No doubt Toyota went with cheaper batteries in these trucks. It's been happening for a number of years now across many car brands. It's an easy way for these companies to save a ton of money. Figure even if Toyota shaved $20 from each vehicle sold by going with batteries that last 1.5-2 years as opposed to 5-10 years, that's $214.8 million a year.
    VanGo3 likes this.
  5. Jun 2, 2020 at 12:14 PM
    #45
    Tacomike18
    Tacomike18 Well-Known Member
    J
    The factory Toyota battery started leaking acid six months after I got my truck. Went back to the dealer and showed them the top was wet and started going down the sides. Got a new one out of warranty.
  6. Jun 2, 2020 at 12:25 PM
    #46
    Amanelot
    Amanelot Member
    Texas
    2016 MGM TRD Sport DCSB
    Stock battery still going strong on my truck. Maybe just poor QC at the factory?
  7. Jun 2, 2020 at 12:30 PM
    #47
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Im on the original battery after 2 years, still going strong. My truck sits 5 days a week, i only drive it on the weekends, starts beautifully every time. When i do get to drive it, i make sure i go for a nice long drive on a hwy to make sure it gets charged.
    Had a bit of corrosion few months ago. Cleaned it and applied the red anti corrosion spray, so far so good. Lets see how long it lasts, i would think another year or two no problem.
    tonered likes this.
  8. Jun 2, 2020 at 12:45 PM
    #48
    JEEPNIK
    JEEPNIK Well-Known Member
    2020 Voodoo Blue TRD Sport
    If you are replacing your battery get an Optima. They are expensive but they live up to the hype. Being sealed corrosion is not an issue.
    I run them in all of my vehicles including a deep cycle winch battery in my Jeep.
    That said a bad unit can come from any manufacturing process. I just have seen a bad Optima yet.
    44-16 Taco likes this.
  9. Jun 2, 2020 at 12:49 PM
    #49
    Scott4032
    Scott4032 Well-Known Member
    Michael
    2020 SR5 4x2 V6
    coming soon!
    I headed all this stock battery failure off at the pass and installed a optima when I put a inverter in the truck.[​IMG] [​IMG]
    DAS Taco likes this.
  10. Jun 2, 2020 at 12:58 PM
    #50
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    I had mine replaced within 2 years of buying my truck. Now the replacement has started leaking too. I guess it's time for an AGM
  11. Jun 2, 2020 at 1:00 PM
    #51
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    There are multiple causes for different types of corrosion for a battery. It could be the battery getting to hot or cold, from rapid charging/discharging. Could be corrosion of the terminals due to the differences in the metals. Or corrosion die to the gases being vented or acid around the terminals. Or could be sulfation. You did say you haven’t been driving it much lately. This could be the issue. There are a lot of underlying issues that come into play. Not just a “garbage” battery. Every car is different and so is every battery. You could take that same battery that was in that Monte Carlo and put it in the taco and it could of lasted 10 years. Or put the battery from that monte into the Tacoma and it only last several months. Way too many variables
    Screaminpotato and tonered like this.
  12. Jun 2, 2020 at 1:37 PM
    #52
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I wondered that too when reading about Odyssey Batteries, got 11 years out of my last one.
    Taco16LB[QUOTED] likes this.
  13. Jun 2, 2020 at 4:11 PM
    #53
    Cvarnz46
    Cvarnz46 Well-Known Member
    Tennessee
    2020 magnetic grey trd off-road A/T V6 4X4
    I’d agree with you but basic AGM batteries “which are sealed as well” can stand up to the durability/length just as well as the spiral core agm optimas but are cheaper. Also don’t let an optima drop to low in voltage because it is a pita to get them back up and you also can get corrosion issues from AGM’s as well since every lead acid battery needs to vent. Let alone the corrosion caused by the hydrogen gas from sulfuric acid, the terminal connectors can produce corrosion from moisture getting onto the copper causing either white or green corrosion on the terminals depending on the type of material used “lead vs aluminum” as well.
  14. Jun 2, 2020 at 4:17 PM
    #54
    habanero_taco
    habanero_taco Well-Known Member
    Randy
    2016 Tacoma TRD Sport
    OVTuned
    Still on my original '16 battery. I keep thinking I should replace it because it's bound to fail this year right? LOL I've never had a battery last more than 5 years.
  15. Jun 2, 2020 at 4:20 PM
    #55
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Yep 4 years is about the time to empty the penny jar. There are only about 3 or 4 manufactures of batteries so no matter what brand you use it is traceable back to those 3 or 4.
    Screaminpotato likes this.
  16. Jun 2, 2020 at 4:21 PM
    #56
    Frankenstuff
    Frankenstuff Busy iracing
    Frankie
    16TRDORDCsb 4x4 & 2020 BMW M2 competition
    16 trd ORdcsb4x4 c4 swingout rear, cbi t3 front , arb lift,16"grabber x3 rtt, hilift,jerry cans,and sliders . 81 hilux trail donkey
    Hmm me too maybe it’s a inferno thing
    habanero_taco[QUOTED] likes this.
  17. Jun 2, 2020 at 5:06 PM
    #57
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Still on my original battery too...
    Purchased mine in 10/15; straight off the car carrier.
    Mine PDI'd at 91%.
    Every time I start it up, I feel like Kramer from Seinfeld on the 'test drive' episode.
  18. Jun 2, 2020 at 5:12 PM
    #58
    Frankenstuff
    Frankie
    Hmm dcsb should be a Baja Mexico build? Wonder if there is something to that . Everyone who had a failed battery check and see if it’s a Texas built truck .
    It also seems like there has been a lot of 16’s that are still chugging along . Although it is a silly thing to focus on.
  19. Jun 2, 2020 at 7:03 PM
    #59
    Amanelot
    Amanelot Member
    Texas
    Texas built 16 here...
  20. Jun 2, 2020 at 7:19 PM
    #60
    egb1776
    egb1776 Well-Known Member
    2017 Tacoma OR
    My factory battery (3/17) died almost 2 years to the day. About a week before it died I noticed it was leaking, then boom it was dead. Replaced it with a deka intimidator agm with a battery tender hard mounted so I can condition it 2-3 times a month. Oddly enough the Panasonic oem battery in my power wagon last 12 years until I sold it, which included a lot of winching.
