the stock transmission cooler in 2020 sport
Discussion in 'Towing' started by TacoAdventures, May 3, 2024.
  1. May 3, 2024 at 3:46 PM
    TacoAdventures
    TacoAdventures [OP] Active Member
    Hi everyone! me again with more questions :)
    i see posts about the transmission cooler and i see that my truck has one stock. 2020 sport.
    trailer i am pulling for the next few years, wet, is max 3850lb.(for sake of the post)
    do i need to get an aftermarket transmission cooler or will the stock one be ok?
    Also, dumb questions. i usually am towing in 3 or 4th and i see posts saying not to have it in overdrive. is that a button somewhere or is that just the drive mode and not gear select?
    how do i ensure it is off?
    Thanks in advance!
  2. May 3, 2024 at 4:49 PM
    wiljayhi
    wiljayhi “..ain’t nobody’s business if I do…”
    Jim
    Murky Water, MB, eh?
    3G, Tuned
    The stock trans cooler doesn't come on line soon enough for my taste. I pin the t-stat open when towing so it’s always working. I get about a 10*f reduction in the overall trans temp that way. If you’re pulling a lot of hills and such, you might want to look into an aftermarket cooler. For me it’s primarily flatland, so the stock cooler, pinned, works very well. I also monitor my trans temps with a Scangauge so I know how it all fits together.
    No button for “overdrive”. OD in a towing scenario would be 5th and 6th gear. To ensure it’s “off”, use S4. It sounds like that’s what you’re doing, so all good.
    inwood customs likes this.
  3. May 4, 2024 at 12:09 PM
    TacoAdventures
    @wiljayhi Thank you for the suggestion and the feedback.
  4. May 4, 2024 at 12:42 PM
    wiljayhi
    Jim
    3G, Tuned
    :hattip:
