The Supercharged FRV!
Discussion in '2nd Gen. Builds (2005-2015)' started by Blackdawg, Dec 30, 2012.
  1. Feb 10, 2015 at 6:09 PM
    #701
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    Woop Woop! Those look so good!!! Eibach coils :cool: You go with 700 pound coils or something else?
  2. Feb 10, 2015 at 6:17 PM
    #702
    woodnick
    woodnick N7MQ
    Wyoming
    08 DCLB 4x4 Sport
    3" ADS lift , Opened Exhaust, 33" Hankook, TRD Supercharger, URD Stealth 2.8" Pulley, URD CAI, UCON, DTLT, URD Y-Pipe, Demello Front Bumper, Total Chaos UCA, Satoshi Grill, Console Safe, Cobra 29 CB, Demello Sliders, DYI Rack, CVT Mt. Hood Tent, Rigid Industries LED in hood scoop, Bruteforce HC rear swingate bumper, Icom 5100A, Icom 7000, Alpine INE 920HD, Warn 8000m, 4x Inovations Skids, NItto 4.56 Gears, Diehard 31M Battery, Dual Battery Solar charge controller.
    Yeah 700lb coils. I tried to heavier but I don't think you can get heavier.
  3. Feb 10, 2015 at 6:22 PM
    #703
    SconnieHailer
    Marc
    They should be fine. 700's work good for me. Pumped to see how you like em!
  4. Feb 10, 2015 at 11:02 PM
    #704
    Blackdawg
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Boo ya!!! :cool:
    Awesome sauce.
  5. Feb 10, 2015 at 11:33 PM
    #705
    Sefferston
    Sefferston I like Tacos.
    Seth
    Germany
    ZOMG B-RED!
    I've got that one thing, and that other one thing, oh yeah and that other other one thing.
    Hurry up and put them on!
  6. Feb 11, 2015 at 6:28 AM
    #706
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Sure you can. :) http://www.racingsprings.com/Custom-Designs
    Not sure which length you have, but i seriously doubt it is 16" length. I only say that because they list the 3"x16" with a selection over 700ppi.
  7. Feb 11, 2015 at 9:09 AM
    #707
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea he is on a 6" coil over so it's a 14" coil. Can't run 16" otherwise he could run high rate. But 700 should be fine.
  8. Feb 11, 2015 at 9:12 PM
    #708
    woodnick
    woodnick N7MQ
    Wyoming
    08 DCLB 4x4 Sport
    There on and they ride great!
    [​IMG]20150211_220927[/url] by woodnick1, on Flickr[/IMG]
  9. Feb 11, 2015 at 9:13 PM
    #709
    Blackdawg
    Monte
    Wyoming/St. Louis
    Bam!
    Awesome
  10. Feb 11, 2015 at 9:17 PM
    #710
    ndcmack
    ndcmack Well-Known Member
    NICK
    Washington
    BSP 4x4 TRD DCSB
    Not enough
    Very Nice! still hoping to see what had to be trimmed to clear those 305's...
  11. Feb 11, 2015 at 9:21 PM
    #711
    BradyT88
    BradyT88 Well-Known Member
    Is your tire rubbing on your UCA?
  12. Feb 11, 2015 at 9:24 PM
    #712
    Blackdawg
    Monte
    Wyoming/St. Louis
    Hmm I wonder if I still have those..
    Yes. Ha
  13. Feb 11, 2015 at 9:40 PM
    #713
    ndcmack
    NICK
    Washington
    BSP 4x4 TRD DCSB
    Not enough
    I'm hoping...I'm in need of tires and am considering the same tire & size. I've cleared for 295 Toyo MT's, but I'm sure the 305 MTR's open up a lot of new fit issues.
  14. Feb 12, 2015 at 9:34 PM
    #714
    woodnick
    woodnick N7MQ
    Wyoming
    08 DCLB 4x4 Sport
    I had to trim basically from where the wheel transistions from horizontal to vertical. pounded in the wheel well a bit with a BFH and trimmed the body mount. Leave several tabs on the metal you bend back to use for the wheel well liner.
    [​IMG][/url]20150212_223203 by woodnick1, on Flickr[/IMG]
  15. Feb 12, 2015 at 10:03 PM
    #715
    ndcmack
    NICK
    Washington
    BSP 4x4 TRD DCSB
    Not enough
    Thanks Steve! That isn't much more then I've already done. bring on 305's...Nice Build!
  16. Feb 13, 2015 at 11:01 AM
    #716
    woodnick
    woodnick N7MQ
    Wyoming
    08 DCLB 4x4 Sport
    You bet. Goodluck and thanks!
  17. Feb 15, 2015 at 10:14 PM
    #717
    woodnick
    woodnick N7MQ
    Wyoming
    08 DCLB 4x4 Sport
    Here are some more shots of when I cut the fenders.
    [​IMG]20140616_152856[/url] by woodnick1, on Flickr[/IMG]
    [​IMG]20140616_154734[/url] by woodnick1, on Flickr[/IMG]
    [​IMG]20140616_155126[/url] by woodnick1, on Flickr[/IMG]
    Leave some more tabs lower down it will allow you to attach the liner more securely.
  18. Apr 19, 2016 at 10:58 AM
    #718
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
  19. Apr 19, 2016 at 11:38 AM
    #719
    Blackdawg
    Monte
    Wyoming/St. Louis
  20. Apr 19, 2016 at 11:45 AM
    #720
    eon_blue
    Azusa, CA
    I know this post is 4 years old but I'm curious, what's to stop water from say a heavy rain from getting in the air intake with it right behind the grill like that? I had a CAI on my last car and when it rained really heavily, a couple times my car stalled out on me...I assumed it was from a bit of water getting through the filter.
