The Supracharged King Ranch Bundle of Merriment Build
Discussion in '1st Gen. Builds (1995-2004)' started by TashcomerTexas, Nov 4, 2014.
  1. Nov 1, 2017 at 9:32 AM
    #501
    1997tacomav6
    Denver
    If you didn't already play this video, you should inform yourself a little more.
    But if you think adding a gallon of methanol is a hassle and you don't run the truck hard then you should definitely just go with the 7th injection system.
    I have run my truck hard from day one when it was new, the v6 can handle it!!
    The head gasket issues are there and has nothing to do with the supercharger.
    The methonal kit is for those that want that extra power and can be run with the 7th injection system. Or by it's self. It will help you get the extra power by having octane at 115, lowering the supercharger temps when spraying, which means more power, being able to get more advanced timing which means more power and denser air which means more power, more boost which means more power, more oxygen which means more power and will clean out your engine from carbon deposits. If I didn't want the extra power and a 2" pulley I would stay with the 2.1 pulley or the 2.2 pulley as they put less stress on the supercharger
    The 7th injection kit is 1000 plus another 1000 to have it installed =2000.00
    Methonal kit is 500 plus 300 to install = 800.00
    If you can't installl these your self
    The 7th injection comes in from the EGR port and is gasoline that sprays right on top of the rear rotor bearings which will degrade the bearing grease over time where as water does not degrade grease, just my thoughts.
    They do make a double lipped rear rotor bearing seals to help deal with this issue,
    Just means the bearing might not last as long before needing a rebuilt.
    https://m.youtube.com/watch?v=HkPFZWd8wj4
    ChadsPride likes this.
  2. Nov 1, 2017 at 6:44 PM
    #502
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    I watched that video, it's very informative. I think I sufficiently know the pros and cons of each system at this point and it's just going to boil down to how much money I want to throw at it and what type of performance I want. This is all provided that I still even want to boost it in a year or so.
  3. Feb 23, 2018 at 7:58 PM
    #503
    bdbrown
    bdbrown Well-Known Member
    Benjamin
    Canada
    '06 SWB DCSB MT
    lucky rocketship underpants
    Incredible truck!!!!
    Nicest 1st gen I've seen yet..... subbed
  4. Feb 23, 2018 at 8:09 PM
    #504
    SwampYota
    SwampYota Strange things are afoot at the Circle K
    Jon
    Concord, North Carolina
    '03 Tacoma SR5 TRD 5VZ-FE, 5 Speed
    Floor mats
    Agreed, you’re gonna wanna sit down for this though...
  5. Feb 25, 2018 at 9:42 AM
    #505
    ChadsPride
    Sponsored by TacomaWorld.com
  6. Mar 11, 2018 at 11:51 AM
    #506
    TashcomerTexas
    TashcomerTexas [OP] My truck is a whiner
    2003 TRD DC Supracharged
    @Cascadia Tents yall have some of these metal plates? Hate to admit I most likely over torqued 3 of them, moisture getting inside them didn't help either. Thanks.
  7. Mar 11, 2018 at 11:53 AM
    #507
    Iamraiderpower
    Iamraiderpower Well-Known Member
    is it back together?!
  8. Mar 11, 2018 at 11:53 AM
    #508
    TashcomerTexas
    She's ready.
  9. Mar 11, 2018 at 12:10 PM
    #509
    Iamraiderpower
    :yes:Any finished pics?
  10. Mar 11, 2018 at 12:16 PM
    #510
    TashcomerTexas
    Not at the moment but I will get to an eventual write up of the progression.
  11. Mar 11, 2018 at 12:18 PM
    #511
    Iamraiderpower
    ahh good deal, looking forward to seeing the ol girl back on the road. Made me freak when you posted she was hurt :(
  12. Mar 11, 2018 at 3:26 PM
    #512
    TashcomerTexas
    Did some testing and found the rubbing culprit.
  13. Mar 11, 2018 at 9:32 PM
    #513
    Cascadia Tents
    Cascadia Tents Well-Known Member Vendor
    Bobby
    Bend, Oregon
    Betty White
    Yes we do. Give me a call tomorrow on my cell at 541-419-2790.
    -Bobby
  14. Mar 11, 2018 at 9:44 PM
    #514
    TashcomerTexas
    Thanks Bobby!
  15. Mar 13, 2018 at 3:40 PM
    #515
    CowboyCaddy
    CowboyCaddy Active Member
    Dennis
    Everett, WA
    2000 Green 2Dr 4cylinder Manual
    Corrected over-sized tires
    The interior looks great: I am not one who can appreciate the rest of it:)
  16. Apr 16, 2018 at 12:55 AM
    #516
    TashcomerTexas
  17. Apr 16, 2018 at 12:57 AM
    #517
    TashcomerTexas
    Left a message over a month ago never heard back. Hope you didn't insinuate me asking them for free, cause I'll gladly pay for them.
  18. May 28, 2018 at 11:41 PM
    #518
    TashcomerTexas
    For some reason my video's views have jumped exponentially. Don't think I have shared it here on my build page so here we go:
    https://youtu.be/t6iYvwbhy9g
    BassAckwards, XPOTRPR and ChadsPride like this.
  19. Oct 8, 2018 at 12:18 PM
    #519
    TashcomerTexas
    Fuck yeah chicken tenders
    BassAckwards, tony2018 and ChadsPride like this.
  20. Oct 8, 2018 at 1:08 PM
    #520
    MatthewMay1
    Matthew
    Lone Star Republic
    What happened?
