The Tacoma Lean
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jimmywestco, Oct 10, 2022.
  1. Oct 10, 2022 at 10:11 AM
    Jimmywestco
    Jimmywestco [OP] Well-Known Member
    James
    2019 SR AC
    Intermittant wipers, fog lamps wired like factory, remote entry via SE Toyota Dealers kit installed.
    So with a full tank of petro the truck leans to the driver's side. Even worse with a driver inside.
    What is the solution to correct this for a person that wants to keep their truck in basically stock form?
    SoonToBeOn39s likes this.
  2. Oct 10, 2022 at 10:15 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    A puck above the left coilover. Same as a spacer lift, but only to correct the lean.
    You'll likely need an alignment when done.
  3. Oct 10, 2022 at 10:15 AM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    A diet for the driver and the truck. Less fuel for both!
  4. Oct 10, 2022 at 10:15 AM
    Bishop84
    Bishop84 Well-Known Member
    New springs, or the taco lean spacer.
    https://motofablifts.com/i-30558289...for-toyota-tacoma-05-22-uneven-taco-lean.html
    1/4 spacer makes a 1/2" lift on the front.
    For the rear, just leave it and change out the leaf springs with a better than oem set in the future. Usually 60k or 5 years is when the tacoma springs start getting soft.
    One last alternative is the famous Bilstien 5100's. You can change the perch and raise the front up slightly to match the right side.
  5. Oct 10, 2022 at 10:16 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    A collection of plus sized friends of varying weights. Which one that is riding shotgun depends on how much gas is in your tank.
  6. Oct 10, 2022 at 10:18 AM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    The fact that your title is "Tacoma lean" leads me to believe you are aware of this in these trucks as a common thing. Also leads me to believe that being on this site, you know that thousands of people have seen this 'issue' and have made threads to 'correct' it. You have extra weight on one side. If you start adding spacers and such, you start messing with the trucks geometry. Basically stock form would mean do nothing and let it be.
    It's caused by a variable amount of a consumed liquid. You fix it when you have all of the weight with a spacer, now you're too high on that side when your fuel is low.
    tstack22 likes this.
  7. Oct 10, 2022 at 10:20 AM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Taco lean is cool, just leave it alone.
    Taco lean!!!!!!
    TacoPacific likes this.
  8. Oct 10, 2022 at 10:24 AM
    Jimmywestco
    James
    2019 SR AC
    LMAO but my friends are leprechauns.. good luck comes in light..
  9. Oct 10, 2022 at 10:26 AM
    grizz_wi
    grizz_wi Well-Known Member
    Green Bay, WI
    2022 Lunar Rock AC 6MT
    I wouldn't worry about it
    Haha
  10. Oct 10, 2022 at 10:28 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Only fill the tank half way and add spacers under the left side of the driver seat.
  11. Oct 10, 2022 at 10:31 AM
    Jimmywestco
    James
    2019 SR AC
    That is an assumption sir that and is inaccurate, no search for the answer to my question has been performed by this Taco Pilot.
    Your recommendation, if it can be called that, is to leave the truck alone. Which is the easiest thing to do. Especially since I just dropped the LCAs to replace the shocks and had I known about the spacer trick I would have better prepared for that mod.
  12. Oct 10, 2022 at 10:34 AM
    Jimmywestco
    James
    2019 SR AC
    So I should just never fill up past half a tank, get a chubby friend to ride along everywhere or fill up two 5 gallon gas cans and locate them on the passenger side and keep them full.
    AxisCab and TheFang like this.
  13. Oct 10, 2022 at 10:37 AM
    Speedfreak
    Dave
    Canada Eh!
    Manual Mall Crawler
    Knowledge is power my friend... and now you have the knowledge...
    As @tonered mentioned... the easiest way is a ¼ spacer above the left strut. You mentioned replacing struts... by chance are they adjustable aftermarket struts? If they are then make an adjustment to compensate for the lean. If not then get a spacer.
    tonered likes this.
  14. Oct 10, 2022 at 11:29 AM
    Jimmywestco
    James
    2019 SR AC
    Since I just installed new stock OR Bilstein struts I have reservations about adding a spacer and then being able to get the top nut back onto the strut shaft afterwards. There wasn't much thread showing above the hat washer as it was. The lean is definitely less now with new shocks. One of the OEM front shocks was leaking too.
  15. Oct 10, 2022 at 11:35 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You don't pull the top nut on the coilover. Just the three nuts that attach the coilover to the support. The puck / shim goes in there.
  16. Oct 10, 2022 at 11:49 AM
    Jimmywestco
    James
    2019 SR AC
    So it's not doable dropping the LCAs?
  17. Oct 10, 2022 at 11:49 AM
    Speedfreak
    Dave
    Canada Eh!
    Manual Mall Crawler
    Just an example...
    https://www.offroadwarehouse.com/product/14-lean-plate-spacer-2005-2020-tacoma-4runner
    tonered likes this.
  18. Oct 10, 2022 at 12:04 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I didn't drop my LCAs to install 5100s that I had on the 4th slot (left) and 3rd slot (right).
    Like I said though, a spacer will through off the alignment angles. Not much, but folks play in the 0.50deg realm for good road manners.
    Speedfreak likes this.
  19. Oct 10, 2022 at 12:42 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    Got a stockish solution: A bicycle pump will cost you around $30USD. When you have a full tank, inflate driver side tires to 45psi, and deflate the passenger side down to around 15-20psi. Then it is just a simple task of deflating and inflating either side to maintain a level truck as you slowly consume the amber nectar that is throwing the truck to one side.
  20. Oct 10, 2022 at 6:11 PM
    AxisCab
    AxisCab Well-Known Member
    Dave
    Bumville, or some dam place
    2018 2.7L 2WD Auto6, utility Axis Cab
    firewood scratches, Labrador hair/slobber, American flag sticker, Total Chaos bed stiffener, Scepter H20 can, onboard air
