The Tacoma Towing Bible
Discussion in 'Towing' started by maverick491, Nov 18, 2007.
  1. Nov 23, 2009 at 8:29 PM
    #281
    NumNutz
    NumNutz One of the original 7928
    Virginia Beach, VA
    07 Tacoma 4x4 - Kings, TC, Dakars, broken stuff
    Lots.
    I thought that it was bad if you pulled someone out or towed something in reverse. I might be wrong though.
  2. Nov 24, 2009 at 4:15 AM
    #282
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    I think you're referring to people talking about the reverse gear in the transmission being small and weak, and could break more easily than the other gears.
  3. Nov 24, 2009 at 4:20 AM
    #283
    snowgod06
    snowgod06 UG legend wannabe
    Rob
    A farm field, OREGON
    06 Access Cab
    crap bolted and welded together....
    that the BIG reason?
  4. Nov 24, 2009 at 4:29 AM
    #284
    piercedtiger
    Jon
    Southern Tier, NY
    I believe so. It's just a tiny gear that reverses the direction of first gear I think, so it could easily shatter if you put too much torque to it. Although, I personally have no idea how big or strong that gear is or if it's really an issue. Just something I've heard people mention. :notsure:
  5. Nov 27, 2009 at 8:07 PM
    #285
    Bangerman
    Bangerman Member
    Alabama
    08 Regular Cab 4 Cyl
    Just took my 2008 reg cab in for a check on some brake vibration. While there, I also asked if they would do the Leaf Spring TSB and they said "no" the TSB did not apply to regular cabs.
    I just noticed there is an update (new) to the TSB that clarifies this. SO unless there is a another way I will have to do the upgrades on my own nickle.
  6. Nov 28, 2009 at 8:02 AM
    #286
    petersharp
    petersharp Well-Known Member
    Do you need to ask?! It's up there ^
    Louisville, CO
    Ex DC LB Sport owner.
    Regarding reversing, I can't see there being an issue reversing with a trailer up to the vehicle's limit (6,500 for the V6 2nd gen). What people are talking about it when you try and recover a stuck vehicle (eg whilst 4 wheeling) by pulling him out in reverse.
  7. Dec 3, 2009 at 5:23 AM
    #287
    Gwest1967
    Gwest1967 Active Member
    Gregg
    S.E. Kansas
    SR5 V6 4x4 Ext Cab
    16 inch tires/wheels
    Okay.. So how can you tell?? I have a reciever on my tacoma, and the wiring harness?? Will the reciever be a toyota brand or what??
  8. Dec 3, 2009 at 5:35 AM
    #288
    OU812
    OU812 ban the term murdered out
    danusa
    Kilroy was here
    13 DblCab LB 4X4
    Nothing yet, brand new!
    Do you have the factory towing package? If so it's all Toyota, you add the brake controller.
  9. Dec 3, 2009 at 5:52 AM
    #289
    piercedtiger
    Jon
    Southern Tier, NY
    He has a 2001 so the tow capacities will not be the same as ours. Wiring won't be the same either, and it may not be pre-wired for a controller.
  10. Feb 1, 2010 at 4:29 AM
    #290
    mossyduck
    mossyduck New Member
    jc
    07 bone stock trd 4x4 acc.cab
    ziltch
    ive got a 07 tacoma v-6 4x4 with the tow package, automatic. i discovered this site looking for a suitable side mirror for towing the boat that i tow. my question is this, ive got the stock auto trans cooler thats mounted up front of the radiator, but would you recommend up grading to the beefier b&m tranny cooler? the boat that i tow weighs around 2900lbs (wet)
    also what other mods would you recommend as well, cause ill prob be doing some towing over passes an such but dont want to hurt my so called fuel econ? im debating bout upgrading the exhaust, cold air intake, power tower, chip?
  11. Feb 1, 2010 at 4:52 AM
    #291
    TacoMO
    TacoMO Well-Known Member
    Jeff
    fly over zone
    09 dbl cab 4x4 TRD Off Road
    Shell
    I just stayed with the factory tranny cooler. We pulled the 19' Airstream 2500 miles last summer. Over some good passes in CO. Across KS into a good headwind. I think I am going to get a temp guage for the transmission. I don't think I was cooking it, but have no way to know for sure.
    I am not sure you can do much to help the mpgs when your pulling a heavy load like that. Ours dropped from 20 to 12. It seemed to be at 12 no matter how easy I was on it..
    If you find a way to get a few more miles per gallon when towing, I'd like to know.
    Jeff
  12. Feb 1, 2010 at 4:58 AM
    #292
    maverick491
    maverick491 [OP] Towing Guru
    South Jersey
    07 4x4 Access Cab, TRD off road, 6 cyl, 6 spd
    Activator III brake controller, Extang Fulltilt toneau, Factory bed mat, Extra D-rings in the bed, 2ndary air filter removed, Garmin Ique GPS, Eco-2, AFE Pro Dry-s filter, USASPEC PA12-toy, Pioneer 3-way speakers, SG II on Blendmount, Gulf States Alarm added.
    At 2900 lbs wet I wouldn't bother with upgrading the cooler, the stock one should do fine for you.
    As for fuel economy.... A boat is more aerodynamic that what I normally tow as I only move the boat twice a year, but realistically just don't watch your fuel economy while towing. I stopped watching myself get 10-11 mpg and I am less pissy that way.
    Do an exhaust if you like the sound, change your airfilter if you want to go with an afe dryflow or something for cost savings over the life of the replacements, but don't bother with either if you are seeking to alter your fuel economy.
    You'll do fine through the passes. If the boat trailer has brakes make sure they work, otherwise you should be good to go.
    Regards,
    Adam
  13. Feb 2, 2010 at 1:19 PM
    #293
    CtryBoyInMT
    CtryBoyInMT Lifetime Member
    United States of America
    2008 4WD V6 Access Manual TRD Off-Road
    Tinted windows, Rear locker anytime, Secondary filter delete, Parking light activated Fog lights, USA▪Spec Ipod adapter, Map light mod, Relocated 7-Blade, Warn Trans4mer Brushguard & winch, Tire chains, Homelink© installed in headliner, LED lighted 4x4 Switch, Defrost w/o A/C, Heated mirrors, Bilstein 5100's (1.75") & Rear TSB, 50w Reverse lights, Pratt & Whitney PT6A-68, Will this list ever end???
    2900# is nothing really (even with extra gear and pax on top of that). Through the mountains, you will have no problems. All the OEM goodie are GTG. If the tranny keeps shifting down two gears or more on the inclines, reduce speed a bit and get runs downhill to assist going up.
    Overall, your GTG.
    The lowest measured fuel economy I've ever seen is 11 MPG. Even with the heaviest loads I've pulled. That seems to be the bar and what I base my fuel stops at.
  14. Feb 3, 2010 at 5:31 PM
    #294
    j4x4ar3
    j4x4ar3 Well-Known Member
    Jay
    Austin, TX
    05 DC 4x4 - TRD Off Road - White
    Round Step Bars, Bed Mat, Cargo Bars, Rocky Mounts bike mount, JVC MP3 Head Unit, TRD Cat Back Exhaust, Rigid Industries front and rear light pods, dual HAM radio with remote mount heads.
    No.. the tranny cooler that comes with the tow package is enough. I tow a 5000# travel trailer sometimes in heat over 90 and never had a problem.
  15. Feb 6, 2010 at 10:25 PM
    #295
    JKD
    JKD Well-Known Member
    I have a question on what would be a good drop for a draw bar on a Prerunner.
    Now, before you say it, I know that it depends on what I'm towing. Right now I'm going to tow a utility trailer--but only ONCE, on the highway, 110 miles one way, to deliver it to my father in law. I did the measurements to calculate the appropriate drop, and it came out to 9.5 inches. I can hardly even FIND an 8"+ drop draw bar, and I have severe doubts about its utility after this one towing job. I figure I could be using just about any U-haul rental (tow dolly, car hauler, trailer) after this.
    Would it be OK to buy something a little more common, like a 3" to 4" drop--would I still be able to tow the almost unloaded utility trailer up to my father in law's house?
    Or are prerunners and 4x4s just so tall that a 9.5" drop is normal?
  16. Feb 7, 2010 at 4:27 AM
    #296
    maverick491
    South Jersey
    Assuming that your truck is still at stock ride height and you have not lifted it. I think the issue may be with the size of the utility trailer in question rather than the height of the truck.
    On my 07 4x4 at stock ride height I use a straight bar mounted in the drop position for my enclosed motorcycle trailer, and I use a 3" drop for my 20' Sea Ray. I use the WD hitch for the travel trailer, and the way that is set up is roughly a 2" drop.
    Hope that helps.
  17. Feb 7, 2010 at 1:21 PM
    #297
    CtryBoyInMT
    I agree with Maverick, if your not lifted, the 2" drop is the way to go. Remember that the rear of the truck will settle a bit with the trailer attached. (Stock height) it would be an extremely small (Ex: 3'x5') utility trailer to require any more than 2" of drop.
    If it were me and I would only tow once, I'd borrow the receiver from a buddy. They're all the same as long as it's a 2" square receiver. May need a longer receiver pin since the Tacoma utilizes a Class IV hitch, but their cheap.
  18. Feb 7, 2010 at 1:31 PM
    #298
    4x4jeep
    4x4jeep Well-Known Member
    Kyle
    Destin FL.
    If you are talking about snatching or pulling somebody out while you " puller " are trying to pull in reverse. It can mess up ring and pinion gears. I know of several people who have done this.
    So yea bad Idea to snatch somebody in reverse;)
  19. Feb 15, 2010 at 3:36 PM
    #299
    StarGazer
    StarGazer Well-Known Member
    MegaMan!
    Wherever, Tx.
    2007.5 Dodge Ram 2500 Mega Cab 4x4
    I've done so many mods to this truck it turned out to be a Dodge Ram 2500! WOW was that expensive!!
    How do I find out how much more my truck can tow if I get a "weight distribution hitch" added to my truck? BTW, I'm very thankful that you have setup this site for noobs like me who want to know more about towing w/ a Tacoma.
  20. Feb 16, 2010 at 4:58 AM
    #300
    piercedtiger
    Jon
    Southern Tier, NY
    Max load doesn't change with a WD hitch. It just balances things out for better control. It doesn't magically upgrade your engine's HP, braking power, tires, or traction.
