The Tacoma Towing Bible
Discussion in 'Towing' started by maverick491, Nov 18, 2007.
  1. Jan 9, 2012 at 2:06 PM
    #501
    desert guy
    desert guy Well-Known Member
    Bryan Blagg
    o.c.
    toyota offroad truck
    FiberWerx Tacoma front fiberglass clip, currie rear 9 inch, 35 Spline axles, sick nicks fab steering, Beard Seats, King Coilovers, Bypass, & Hydraulic Bumpstops, DEAVER Springs
    I agree!! Great thread for towing questions!!! It answered some basic tow questions we had
  2. Jan 9, 2012 at 3:22 PM
    #502
    Shikkapow
    Shikkapow Active Member
    Sunny Florida
    01 sr5 4x4
  3. Jan 10, 2012 at 7:19 PM
    #503
    TurnTheLead
    TurnTheLead Active Member
    Mississippi
    2012 PreRunner SR5 4x2 2.7
    Rubber bed mat, Tuff Tonno cover.
    would installation of an after-market transmission cooler (like the jegs one listed above) void any warrantee? I have a brand new truck.
  4. Jan 18, 2012 at 6:54 PM
    #504
    IndigoTac07
    IndigoTac07 Tortoise*
    AJ
    Houston
    '07 Tacoma
    Quick question from someone new.
    When towing a car, do you need the Gross vehicle wieght or the curb weight?
    I ask this as I may be towing a Range Rover Sport this Summer and the curb weight plus a trailer if I am extremely lucky should be under the 6500 weight. If we need the GVW, then imma be towing my Taco!!
    Thanks in advance.
    I did look through some pages, so if this is a repost, ignore it please.
  5. Jan 19, 2012 at 7:06 AM
    #505
    Goober
    Goober Earthlings are fun to watch!
    Utah - Why just have only one?
    '11 TRD Off-Planet AccessCab
    curb weight
  6. Jan 19, 2012 at 5:54 PM
    #506
    IndigoTac07
    AJ
    Houston
    '07 Tacoma
    Ok, thanks
  7. Feb 13, 2012 at 8:36 AM
    #507
    KenaiKingFisher
    KenaiKingFisher New Member
    Jim
    Tacoma SR5 4X4
    Folks,
    Got my 2012 Tacoma DC SR5 V6 4X4 (spruce mica!) with towing package and couldn't be happier with it so far. Just found this site; great wealth of experience and knowledge. Any comment/suggestions on my senario would be appreciated:
    Plan on getting travel trailer (looking at Lance 1985). 3670#DW, 375#HW. Getting a good hitch with sway control, additional brake for trailer. Possibly adding suspension support or air bags. I hope to get some good info from the dealer on the set-up, and will be taking some short trips around the San Antonio area to get familiarized with the set-up. I drove farm equipment, hay trailers, and medium size trucks (26') in my youth, but nothing like that in the last 30 years.
    However, in about 16 months I am heading back to Fairbanks, Alaska. I will travel in June, so weather is not a big issue. 4400 miles from here to there-no hurry to get there. Researching route for best trail now. I think I will be OK weight-wise and drive-wise. Understand low MPG, plan on gas cans.
    Doable? Any issues jump out that I am missing? Suggestions on the set-up? Learned a lot just scanning this forum, but want to get as prepared as possible for the retirement (Army/29 years) adventure.
    Any input greatly appreciated-sorry for the long first post! Thanks in advance for the help!
    Jim
  8. Feb 13, 2012 at 2:33 PM
    #508
    CtryBoyInMT
    CtryBoyInMT Lifetime Member
    United States of America
    2008 4WD V6 Access Manual TRD Off-Road
    Tinted windows, Rear locker anytime, Secondary filter delete, Parking light activated Fog lights, USA▪Spec Ipod adapter, Map light mod, Relocated 7-Blade, Warn Trans4mer Brushguard & winch, Tire chains, Homelink© installed in headliner, LED lighted 4x4 Switch, Defrost w/o A/C, Heated mirrors, Bilstein 5100's (1.75") & Rear TSB, 50w Reverse lights, Pratt & Whitney PT6A-68, Will this list ever end???
    Welcome to the Forum, Jim!
    You will still be pleased with the Tacoma after the trip. It will haul that load nicely with the LC/Sway setup.
  9. Feb 14, 2012 at 6:55 AM
    #509
    psmcn
    psmcn Well-Known Member
    Paul
    Rockville Md
    Welcome.
    Sounds like a good trip. Do your research on weight distribution hitches (WD) hitch and sway control. I use the equal-i-zer which has both WD and sway control and is easy to set up. One note: If you decide on air bags do not use them to adjust rear/front sag with the trailer connected with WD hitch. THe rear/front sag should be adjusted with the WD hitch only. The air bags are better for adjusting sag with a payload in the truck only, like a load of logs or dirt or if you have a non WD set up with a heavy tongue weight.
    I had the rear suspension updated through the Toyota TSB that added a leaf spring and it made the truck much better suited for towing. Here is a list of the TSB for a 2nd Gen
    Any questions just ask.
    Paul
  10. Feb 14, 2012 at 11:32 AM
    #510
    Utard
    Utard Well-Known Member
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    Firestone air bags
    Primus IQ trailer brake
  11. Feb 16, 2012 at 10:04 PM
    #511
    mountainman38
    mountainman38 Member
    Tim
    Wenatchee, WA
    1999 Tacoma TRD V6 w/Snugtop
    Bridgestone airbags, and a lot of miles.
    I agree whole heartedly on the value of the Firestone air bags -- best addition I've made to my truck, and had it almost 12 years now.
    This wood was HEAVY - I know, because I got to load it all:
  12. Feb 25, 2012 at 8:38 AM
    #512
    Pre runner2011
    Pre runner2011 Jekyll 2 Hyde
    Tucson Arizona
    2011 DCLB Prerunner
    K&N air filter, Banks Monster exhaust, steel screen grille, off road led lights, 3" Pro Comp suspension lift kit, 33x12.50-17 mud hogs, 17x9 Pro comp Stryker Wheels
    2011 Toy Tacoma double cab pre runner long bed. Whats the max I can tow, or does anyone know where the tow capacity is?
  13. Feb 25, 2012 at 10:33 AM
    #513
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
    Its in your owner's manual. It depends if you have the tow package or not.
  14. Mar 3, 2012 at 1:31 PM
    #514
    mickelr1
    mickelr1 New Member
    12 Prerunner
    Just traded in an o8 f150 4x4 for a new toyota tacoma prerunner double cab 2.7 liter four cyclinder. Scared to death that I made a stupid decision. I have a 60 mile round trip commute every day and the cost of gas was killing me. All I hear about it how the price is going to go to 5 or 6 dollars a gallon. I tow a 14 ft alulminum boat about 15 times a year and a 5x14 atv trailer loaded with two four wheelers that weigh about 600lbs each.I tow this about 4 times a year. I don't have the towing package and was wondering if I will be ok. I am feeling that I have made a bad mistake. Looks like I can't put my transmission in D when I haul the four wheelers. It looks like I will have to stay in 2nd ir 1st. Any advice would be greatly appeciated.
  15. Mar 3, 2012 at 2:56 PM
    #515
    afireman
    afireman Member
    Robbie
    Brooksville FL
    17 TRD OR
    Removed ashtray
    You won't have any problems with the load you're describing. You can keep it in D when accelerating and driving slow, but keep it in 4th on the highway and don't let it hunt. You won't be passing anyone doing 70 on a 2 lane, but you'll have no problems towing what you have. It was a smart choice.
  16. Mar 3, 2012 at 5:49 PM
    #516
    mickelr1
    mickelr1 New Member
    12 Prerunner
    Thanks for the response. I don't have a fourth gear though. My shifter just has P R N D 1 and 2. Do I need to keep it in second then?
  17. Mar 3, 2012 at 6:00 PM
    #517
    afireman
    afireman Member
    Robbie
    Brooksville FL
    17 TRD OR
    Removed ashtray
    You're right, sorry. The 2.7 is a 4 speed. The tow cap is 3400 so both of your toys fall below that. You definitely don't want to run the highway in 2nd. My best guess would be keep it in drive and keep it just below where it wants to start hunting. Hopefully you're not hauling the toys too far.
  18. Mar 4, 2012 at 1:35 PM
    #518
    mickelr1
    mickelr1 New Member
    12 Prerunner
    Thanks, I have a 3rd gear that is to the left of D. I guess I could use that if my tranny starts hunting for gears.
  19. Mar 13, 2012 at 6:59 PM
    #519
    HedgehogOutdoors
    HedgehogOutdoors Well-Known Member
    CT
    '98 4runner SR5
    You probably mentioned something about towing with a manual, but I can't seem to find it. I've been looking for a 4banger manual Taco, wouldn't be doing anything too heavy duty, but any advice?
  20. Mar 19, 2012 at 2:33 AM
    #520
    lmcc007
    lmcc007 Well-Known Member
    Charles
    Northern CA.
    2006 SR5 PreRunner Doublecab Longbed
    Tube steps & tonneau cover.
    Thanks for posting the "Tacoma Towing Bible". I used a lot of your suggestions when I towed a trailer about 1400 miles from Colorado to California. I was/still am a novice at towing so your tips really helped me out. Thanks!
