The Tacoma Towing Bible
Discussion in 'Towing' started by maverick491, Nov 18, 2007.
  1. Mar 29, 2012 at 12:50 PM
    #521
    gupster88
    gupster88 Well-Known Member
    Brett
    Almost Heaven, WV
    2021 Cement Grey Off Road
    Stock
    looking to get either a 2.7 or a 4.0 i tow about 22lbs (6x12 trailer and a 2012 Rzr S). i tow within a 50 mile radius from the house. living in wv it is not so flat. would the 2.7 be a good fit? i want to maxmize mpg since my daily driver is currently a 5.4L 13mpg f150.
  2. Mar 29, 2012 at 4:31 PM
    #522
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
    ^ IMO, depending on how often you tow, and through WV, you may want to go for the 4.0. With stock suspension and tire size, you should be able to do alot better than 13 mpg during regular driving.
  3. Mar 29, 2012 at 5:07 PM
    #523
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    Agreed. I've heard people complain about trying to tow with 4cyl. My 4.0 gets about 13-14mpg while towing, but I've only towed 5,000+lbs at a time (full sized ford pickups on U-Haul auto transports that weight 2k by themselves). Supposedly you can get better mileage with higher octane (I run 87) while towing, but I've never really tried it.
    Everyday driving I get around 18-20 crossing a couple mountain ranges on the way to work.
  4. Mar 29, 2012 at 6:36 PM
    #524
    gupster88
    Brett
    Almost Heaven, WV
    Stock
    i tow about once a week, if that. depending on how the weather is on my days off. it's about 2200 lbs loaded down full of gas and equipment. sadly, the best i get around here is 13.8 i have pussy footed it,stayed below 70 on the interstates and everything. my tires are stock and so is my suspension. these trucks just arent known for their fuel efficiency like the 5.3 silverados and what not.
  5. Mar 30, 2012 at 2:18 AM
    #525
    ajohnson
    Andy
    Charlotte, NC
    I meant if you get a 4.0 Tacoma, and leave the suspension and tire size stock you will do better than 13 mpg.
  6. Mar 30, 2012 at 3:09 AM
    #526
    fadippides
    fadippides Well-Known Member
    NEPA
    12 TRD Off Road
    with the mountains and high speed limits in WV I dont think the 4cyl would do so well towing, why cant you tow with the F150 and use the Tacoma when you aren't towing?
  7. Mar 30, 2012 at 4:13 AM
    #527
    gupster88
    Brett
    Almost Heaven, WV
    Stock
    oh ok gotcha :thumbsup:
    well if you want to make one of those truck payments i'll gladly own both lol
  8. Mar 30, 2012 at 5:51 AM
    #528
    fadippides
    NEPA
    12 TRD Off Road
    I took the daily driver as meaning you were keeping the ford. I've driven the highways in WV and between the mountains and 70mph speed limit I get about 17-18 when I am there (mostly highway and no towing) fwiw. Outside of WV my mileage goes up by 2-4 mpg
  9. Mar 30, 2012 at 11:17 AM
    #529
    gupster88
    Brett
    Almost Heaven, WV
    Stock
    Back when I had my 4.0 I gained about 1-2mpg once I got out of the state. We have some pretty good grades on the interstates. I live in a rural area so it's not too bad for me unless I travel
  10. Apr 10, 2012 at 11:41 PM
    #530
    03prerunner
    03prerunner New Member
    california
    03 tacoma prerunner TRD non factory tow
    I read and reviewed everything here and its all very helpfull information! I have my 03 tacoma double cab TRD with the rear diff lock. Im planning on putting a trany cooler and trailer brake module in. I am looking to buy a ski boat a 92 centurion 20ft weighing in at 2800 dry no trailer. The trailer is a tandum axle with surge breaks not sure the weight. you did cover this but just wanted your thoughts. (seems like no one tows older ski boats lol). I have some pretty agressive bridgestone 17 revo A/T tires also pretty awsome traction just woundering if im going to have problems pulling the boat out of the water. Some say yes, some say no, also i have a camper shell on it if that makes a difference. Let me know thank you
  11. Apr 10, 2012 at 11:44 PM
    #531
    03prerunner
    california
    I read and reviewed everything here and its all very helpfull information! I have my 03 tacoma double cab V6 TRD with the rear diff lock. Im planning on putting a trany cooler and trailer brake module in. I am looking to buy a ski boat a 92 centurion 20ft weighing in at 2800 dry no trailer. The trailer is a tandum axle with surge breaks not sure the weight. you did cover this but just wanted your thoughts. (seems like no one tows older ski boats lol). I have some pretty agressive bridgestone 17 revo A/T tires also pretty awsome traction just woundering if im going to have problems pulling the boat out of the water. Some say yes, some say no, also i have a camper shell on it if that makes a difference. Let me know thank you
  12. Apr 16, 2012 at 5:05 PM
    #532
    kimo
    kimo Well-Known Member
    Knuckle Head
    Kauai
    09 Super White TRD Sport DCLB 4X4! 2017 Silver 4Runner!
    In another thread someone stated the tow rating for v6 manual 6sp trans at #3500lb, could you confirm the correct #lb, I thought the auto and manual trans were both #6500lbs ???
  13. Apr 16, 2012 at 10:54 PM
    #533
    mac424205
    mac424205 Well-Known Member
    Mathew
    Chelsea
    2005 4Runner Limited V8 4X4
    Billies on all four corners with daystar spacer lift. Bought it like this. Replacing done with toytec ultimate 3" lift
    You won't have any problem pulling it out. If you are 4wd and you have problem throw it in high and pull, if not, lock the rear and go.
  14. Apr 17, 2012 at 3:48 AM
    #534
    piercedtiger
    Jon
    Southern Tier, NY
    Based on his screen name I would say he doesn't have 4wd.... ;)
  15. Apr 17, 2012 at 11:20 AM
    #535
    mac424205
    Mathew
    Chelsea
    I wasn't paying attention!!!! PLUS it was like 2 in the morning when I posted that...:smack:
  16. Apr 25, 2012 at 10:48 AM
    #536
    seanandcoty
    seanandcoty Member
    Sean
    Tuttle, OK
    2012 TRD Sport Double Cab 4x4
    Safety 1st car seat on the back seat.
  17. May 8, 2012 at 9:08 PM
    #537
    Justin
    Justin Well-Known Member
    Justin
    Colorado Springs
    2018 4Runner TRD-OR
    285/75/17 on SCS 6's. ADS front & rear w/ adjusters. Relentless front bumper & roof rack. BAMF sliders
    So I have an 09 V6 TRD Sport with the tow package. I'm getting a 7'x12' Wells Cargo to take from Colorado to Maryland. I know I need to install the brake controller, but what exactly does my truck have besides the hitch on the back, 7 pin wiring, and wiring set up for brake controller? I heard that on some trucks the gear ratio (or first gear) will be lower with the tow package. Does the Tacoma have that? Also, does it have the special transmission cooler (I have an automatic)?
    Any help would be much appreciated. Thanks.
  18. May 9, 2012 at 8:38 PM
    #538
    mac424205
    Mathew
    Chelsea
    If there is a smaller radiator on the front on your radiator, then you have a trans cooler... if not, you NEED one for that size trailer
  19. May 21, 2012 at 1:49 PM
    #539
    badmutha6
    badmutha6 Member
    Texas
    08 Tacoma
    If you have the factory tow package, not just the hitch but the package, it comes with a tranny and engine oil cooler. My question is that I am nearly maxing out, towing a KEystone Hideout 23rb that weighs 4800 dry and I am about 6000 ready to go. I read the bible and the only thing I'm confused on is he advising to install an additional cooler in with the factory? Replace the cooler there with a larger trans cooler? I just got the trailer and don't want to burn out the transmission.
  20. May 28, 2012 at 9:01 PM
    #540
    tacomadre
    tacomadre Well-Known Member
    Jose
    SoTex
    06 PreRunner SR5 Speedway Blue
    I have to read on this thread. I need to get better gas mileage and up my tow capacity.
