The Tacoma Towing Bible
Discussion in 'Towing' started by maverick491, Nov 18, 2007.
  1. Aug 28, 2012 at 7:18 AM
    #601
    psmcn
    psmcn Well-Known Member
    Paul
    Rockville Md
    Class IV designate the receiver on the truck and it weight limitations.
    The hitch is the ball mount that goes into the receiver and connects to the trailer. you can have either a single ball mount that is loaded with the tongue weight (TW) of the trailer or a weight distribution (WD) type that distributes the weight of the trailer and TW throughout the tow vehicle (TV) and trailer. Sway control is a part of the ball mount/ WD hitch system, you can have it on both and there are many set ups.
    Keep asking questions and review past post for a wealth of information on this site in regards to towing
  2. Aug 28, 2012 at 7:23 AM
    #602
    Mass Tacoma
    Mass Tacoma Member
    Boston
    2012 Tacoma 4WD
    The sway control in my 2012 Tacoma with trailer package is managed by electronic braking of the rear wheels on alternating sides left-right to counter trailer sway. Definitely not hitch-based sway control.
    CL
  3. Aug 29, 2012 at 7:27 AM
    #603
    psmcn
    Paul
    Rockville Md
    Okay. Not up on the 2012.
    Still may want some type mechanical sway control. Drive it to decide.
  4. Aug 29, 2012 at 10:55 AM
    #604
    tacomatime
    tacomatime Well-Known Member
    Florida
    2018 TRD Sport DCLB 4x4
    3" leveling front, and 2" rear Rough Country. BF Goodrich 305/65/17 KO2
    Thanks for your input guys. I think everyone is knowledgeable here. This forum is a wealth of information. I have not towed with my 2012 tacoma yet, but I will start in the fall since the weather will get a bit cooler in South Florida.
    Another note for those who have the Prerunner 4.0 2012: I know it takes a bit to get used to driving it. But I noticed that the truck slows down so much once I take my foot off the gas. Yes, I know its going to downshift to slow down, and that is normal with every vehicle. But if I am going 45 or 50 mph and I take my foot off the gas, the truck slows down that I don't even have to use my brakes, and I make sure my emergency brake is retracted as well. Is anyone else experiencing this, or just me?
  5. Aug 29, 2012 at 1:11 PM
    #605
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    I'm looking at a 2005 Doublecab TRD Sport tonight, I just noticed that according to the specs sheet from toyota the towing package for 2005 is a hitch and 7-pin..
    So no Class IV/Oil cooler/Trans Cooler/bigger battery/upgrade alternator?
    Is that right? because that would rule out this truck.
  6. Aug 30, 2012 at 9:44 AM
    #606
    psmcn
    Paul
    Rockville Md
    For a 2005 if it has the factory tow package with the 4.0 it is rated at 6500# towing max and 650 # TW.w/o the factory package it is rated at 3500#. Take a look and see if it has the engine oil cooler and trans cooler. A battery is marked for size and CCA. Can't tell you how to check an alternator. If they are the original owner they may have the sticker as well. If you still have questions, write the VIN down and ask a dealer to tell you exactly what factory options it has from the VIN.
  7. Sep 2, 2012 at 6:53 AM
    #607
    J Gibson
    J Gibson Well-Known Member
    J
    Knoxville, TN
    '12 DCSB,4wd,TRD Sport, tow pkg, MGM
    katzkin leather, toyota step bars, pro grill, advent overhead DVD player, cargo extender, bed mat, husky liners, impulse digital brake controller, avs bugflector, tinted windows, Firestone ride-rite air bags, ARE camper top with tool doors, ScangaugeII, ProEFX tow mirrors, ImMrYo rearview mirror lift bracket, Salex glove box and console organizers, 2020 Tacoma Pro styled wheels, 265/70 r17 Michelin MS2 tires, LED map lights, drivers seat extended and raised, ram ball tech deck installed, blacked out badges, tinted taillights, upgraded climate control knobs, ultimate headlight upgrade with Osram superbrights and wiring harness along wit OEM pro headlight housings.
    I think we all experience that, there is a thread on here somewhere of people that don't like the feature. I am OK with it for the most part once I got accustomed to it. The only downside that I see is it might negatively impact fuel mileage since we are losing some momentum and coasting. However, I am sure the Toyota engineers have their reasons.
  8. Sep 3, 2012 at 6:47 AM
    #608
    Phillywill
    Phillywill Member
    Will
    Philadelphia, PA
    11 PreRunner 4X2 V6
    TRD Off-Road Extra Value Package
    I sometimes shift to neutral, because I feel it's wasting gas to slow down like that.
  9. Sep 3, 2012 at 4:40 PM
    #609
    Tango Bravo
    Tango Bravo Sailing the Seven Seas
    Thomas
    SoCal
    09 4x4, The Green Rubber Ducky
    Chaos 3.5" Race LT, RJ Fab Cantilever LT
    thanks for the awesome writeup!
  10. Sep 3, 2012 at 6:40 PM
    #610
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    Fuel virtually shuts down while coasting, people with scangauge or the like post pics of some insane mpg #'s while coasting. You actually waste more gas shifting into neutral.
  11. Sep 4, 2012 at 1:33 PM
    #611
    tacomatime
    Florida
    I am curious to see some numbers for those using Scangauge. I am going to do some search on that. My concern of dropping it from N to D might be harsh for the trany to lock into drive again in case you want to go into drive before you come to a full stop. Its just a thought. I am sure some of you guys are more knowledgeable than me on this stuff. Thanks for the info guy.
  12. Sep 5, 2012 at 4:33 PM
    #612
    mikedgw
    mikedgw Member
    Michael
    Citrus Heights
    06 Prerunner TRD Sport
    Undercover Tonneau Cover, PowerTech disk brakes w. stainless steel brake lines. ProEFX towing mirrors. K&N air filter. Billet radiator grill insert. Prodigy P2 brake controller.
    The only brake controller I could find on-line today is the Hayes Lemmerz Energize Xpc Brake Control with remote manual brake controller.
    Does anyone know if this controller is a good unit and works well?
    Wish they still made the Activator III.
  13. Sep 5, 2012 at 4:40 PM
    #613
    tacomatime
    Florida
    Hey Mike, check out this link. Prodigy brake controllers are excellent controllers. A lot of guys in this forum use them.
    http://www.carid.com/tekonsha/item-...cagpspn=pla"&gclid=COO74-zNn7ICFQs3nAodUj8AWg
  14. Sep 5, 2012 at 4:44 PM
    #614
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
    ^ thats the one I'm using. Its the first one I've used so I can't compare it to others, but it works great for me.
  15. Sep 5, 2012 at 4:45 PM
    #615
    tacomatime
    Florida
    I have not bought one yet, but will soon. I read about them quite a bit. I am not using my camper till winter time. Its still too hot down here in south west Florida. I will start camping in November.
  16. Sep 5, 2012 at 5:12 PM
    #616
    mikedgw
    mikedgw Member
    Michael
    Citrus Heights
    Thanks for the input everyone!
    tacomatime = where did you mount your controller?
  17. Sep 5, 2012 at 5:16 PM
    #617
    tacomatime
    Florida
    You welcome Mike.
  18. Sep 5, 2012 at 6:04 PM
    #618
    tacomatime
    Florida
    I have not bought one yet . But I saw some pictures around where they are installed on the left side attached to the small compartment. Next to your left knee.
  19. Sep 5, 2012 at 6:09 PM
    #619
    tacomatime
    Florida
    check this one out Mike.
  20. Sep 5, 2012 at 6:45 PM
    #620
    mikedgw
    mikedgw Member
    Michael
    Citrus Heights
    Thanks!
    That's where I was thinking (if there's no remote manual brake on a "coiled cable" possibility.)
