The Tacoma Towing Bible
Discussion in 'Towing' started by maverick491, Nov 18, 2007.
  1. Sep 25, 2012 at 4:55 PM
    #641
    Coolerman
    Coolerman Well-Known Member
    Dan
    Rochester, NY
    2005 4x4 SR5 AC / 2007 4x4 FJC
    5100's @ 1.75", Firestone Ride-Rite Air Bags, Extang Solid Fold Tonneau cover, Weathertech digifit floor mats, Wet Okole seat covers, rcbs204 lighted 4x4 switch, Weathertech in channel window vents, Scanguage II, Hayden 678 Trans cooler, Western Suburbanite plow, Pop and Lock PL8521, ECGS clamshell bushing
    Nice, Ive been planning on installing my controller in the same spot when I do it.
  2. Sep 25, 2012 at 9:51 PM
    #642
    CtryBoyInMT
    CtryBoyInMT Lifetime Member
    United States of America
    2008 4WD V6 Access Manual TRD Off-Road
    Tinted windows, Rear locker anytime, Secondary filter delete, Parking light activated Fog lights, USA▪Spec Ipod adapter, Map light mod, Relocated 7-Blade, Warn Trans4mer Brushguard & winch, Tire chains, Homelink© installed in headliner, LED lighted 4x4 Switch, Defrost w/o A/C, Heated mirrors, Bilstein 5100's (1.75") & Rear TSB, 50w Reverse lights, Pratt & Whitney PT6A-68, Will this list ever end???
    There is not any best brand. I can't recall any MFG that are NOT made in China off the top of my head. And thats why brand is null. Some may disagree, but at the end of the day, trailer tires will blowout or need replacement from a foreign object (nail), under-inflation, or dry rot. Just choose an established name brand such as, but not limited to; Goodyear, Load Star, Carlisle, Etc. Just be wary of "house" brands.
    As far as radials, absolutely. Radials are very common these days and the numerous handing improvements are well worth it. All positives with radials (except cost!) that your tire guy says is true. Especially with a Travel Trailer where long drives are the norm.
    Price varies so much, I can't even give an estimate.
    This spring I paid $375 for (4) Loadstar ST215/75R-15" Radials, M & B out the door. After a quick google search I may have got a deal. But with 9 road trailer axles, 3 vehicles, a tri-axle truck, a tractor and all the misc farm equipment, I think [Correction: KNOW] my tire guy still makes money off me!
    Well I typed that quick, so hopefully the intent of question was answered.
  3. Sep 26, 2012 at 4:18 PM
    #643
    buckwild
    buckwild Active Member
    Bill
    Frankfort, KY
    '12 d/c sport, tow pkg
    X-tang hard top bed cover, Aries black tube steps, Aries hood & window gaurds
    Thanks for the info...I will be heading out west next year & want to have tires I can depend on. Another ?...do I need to have the T/T wheels balanced?
  4. Sep 28, 2012 at 10:37 PM
    #644
    CtryBoyInMT
    Yes, have it done. Most likely already included in the price of mounting. May be folklore, but apparently increases tire life.
  5. Oct 10, 2012 at 1:36 PM
    #645
    Bo Rocks
    Bo Rocks Well-Known Member
    Brian
    O.C.
    2006 trd sport 4x4
    Can my 2006 4x4 tacoma double cab be towed BEHIND AN RV with all 4 wheels on the ground?
  6. Oct 10, 2012 at 1:58 PM
    #646
    flashsplat
    flashsplat Well-Known Member
    Augusta, GA
    2012 SM 4X4 DC TRD Off Road
    I put gas in it...
    Per the owners manual I would say no. It must be trailerd.
  7. Oct 10, 2012 at 7:01 PM
    #647
    Bo Rocks
    Brian
    O.C.
    2006 trd sport 4x4
    all 4 wheels off the ground?
    can I have the back 2 on the ground? or the front 2?
  8. Oct 10, 2012 at 7:17 PM
    #648
    flashsplat
    Augusta, GA
    I put gas in it...
    When I looked at the manual I was driving a 2009 Prerunner and if I recall correctly it said it could not be towed from the front or the rear- I'll check the manual tomorrow on my 2012 and let you know what it says.
  9. Oct 13, 2012 at 9:11 AM
    #649
    Coolerman
    Dan
    Rochester, NY
    This week I converted from a four pin trailer wiring harness to a seven pin. I used the ETBC7 kit from etrailer. The kit worked well and provided everything I needed to convert from four to seven. The only problem is the way its wired the brake controller is always on. Even when the truck is turned off, the power is coming directly off the battery. I would prefer it power off when I turn the ignition off. There must be a way to wire it to a power source that comes on when the truck does. Has anyone done this, or have any advice?
    Edit: It looks like the writeup here in the towing bible says to wire it this way too. Is there a reason?
  10. Oct 13, 2012 at 10:57 AM
    #650
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
    On Tacomas with the towing package, the brake controller wiring is not wired through the ignition. The controller will not turn off with the truck but it should turn itself off after a certain amount of time to avoid draining the battery.
  11. Oct 13, 2012 at 11:04 AM
    #651
    Coolerman
    Dan
    Rochester, NY
    Thanks for the info. I just checked and the controller I have (Tekonsha Prodigy P2) says it has a power saving mode for this reason.
    "Power-saving mode reduces drain on the battery when vehicle is not in use - draws only 3.6 milliamps"
  12. Oct 13, 2012 at 11:09 AM
    #652
    ajohnson
    Andy
    Charlotte, NC
    Yup, that is the one I am using :thumbsup:
  13. Oct 22, 2012 at 5:04 AM
    #653
    scotrinaf
    scotrinaf Well-Known Member
    Scott
    Blountville, TN
    04 PreRunner TRD SR5 4x2 2.7L
    Leer 100XQ, Yakima Roof Racks
    Great Write-up! :) I may have overlooked it, but I didn't see the "how to" wire up a 7-way on a 1st Generation 2.7L... Have you done a write-up for that, and if so, can you please post the link?
    Much appreciative of the time and effort you've put into this!!!
  14. Oct 25, 2012 at 8:39 AM
    #654
    this_is_nascar
    this_is_nascar Well-Known Member
    Gloucester City, NJ
    2007 TRD Off-Road
    This weekend, I'm planning on installing my E2 Trunnion style WDH onto my Tacoma/Jayco 26BH. Is there anything, specific to the Tacoma, that I should be aware of? Obviously, I have the OEM tow-package and break controller already installed. I just wanted to make sure there wasn't anything specific to the Tacoma that I need to be concerned with.
  15. Oct 25, 2012 at 11:27 AM
    #655
    tractng
    tractng Well-Known Member
    Not really. I am doing the same. Changing WDH from chain link to Equalizer WDH.
  16. Oct 25, 2012 at 1:50 PM
    #656
    this_is_nascar
    Gloucester City, NJ
    2007 TRD Off-Road
    OK, thanks. I didn't have the coin to spend on the full-blown Equalizer, so I got the E2 version, which only has 2-point sway control vs. the 4-point sway control of the Equalizer.
  17. Oct 26, 2012 at 10:50 AM
    #657
    tractng
    Always to remember to put the choke on the wheels of the trailer first before doing anything else. The guy who sold me the trailer forgot it. I bounced (hopped) backward. Luckily, he was parking the trailer on flat ground.
    I almost did the same one day and just remember at the last second. It would have been a nasty result since my driveway is on a slope.
  18. Oct 28, 2012 at 10:51 PM
    #658
    Scott SD
    Scott SD Member
    Another idea for the brake controller placement. I just finished the install of the factory tow wiring harness and added a wire for the brake controller. Installed the brake controller in the center console. I don't tow much, so I wanted it hidden. Since I had the console out I also put a power outlet in the back for the rear seats.
  19. Oct 29, 2012 at 5:30 AM
    #659
    this_is_nascar
    Gloucester City, NJ
    2007 TRD Off-Road
    Well, I got the trailer home safely and in one piece. I don't think I had the E2 adjusted to 100% the way it should have been, since I still had a good bit of sag in rear-end, but I did get it home. Now, I'll have time to properly get it setup and adjusted.
  20. Nov 8, 2012 at 7:51 PM
    #660
    Greensystemsgo
    Greensystemsgo She looked 18...
    Dirty Nickers
    Peoria, AZ
    99' extended cab
    Bone Stock
    Okay folks, at work, long day, frustrated searching.
    Need to pull a 1999 ranger long bed single cab 2wd, busted tranny cooler/radiator. If in neutral, with little tranny fluid, will it be ok on car Dolley? Or should i borrow a double axle flat bed?
    Pulling with my rig, 99 3.4 with expos out back, and elite offroad bumper with integrated hitch....
