The Tacoma Towing Bible
Discussion in 'Towing' started by maverick491, Nov 18, 2007.
  1. Jul 2, 2015 at 9:08 AM
    #1061
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Speed limit in just about every state is the same whether you're towing or not.
  2. Jul 2, 2015 at 9:26 AM
    #1062
    BradyT88
    BradyT88 Well-Known Member
    80 mph on the interstate towing or not. Only big rigs have to go slower and their speed limit is 70 mph on the interstate. With a WD hitch and sway control kit it towed great at 80, though it raped my fuel mileage. My UG said I was getting about 5 mpg maintaining 80, though at 65 I only averaged 9 mpg for the all interstate 150 mile drive...
    When I towed the camper home the first time with just a regular hitch it towed fine at 65, but when a big rig passed me when I was doing 75 mph it got the whole thing swaying pretty bad... With the setup now, when big rigs passed me at 65 it never swayed it just tried to push me off the road (not as bad as that sounds).
    So on the topic of tires. Do you think LT tires would lose their max speed rating when used on a trailer?
  3. Jul 2, 2015 at 9:35 AM
    #1063
    95 taco
    95 taco Battle Born
    I'm no expert, but it would lose some but not all, if they're rated for 113 I'd say that they're good to 85-90 on a trailer.
    We have LT tires on all of our trailers and I've run 75-80 for ~30 hours (with fuel stops) straight without problem when we moved.
    That was on a tandem axle trailer (rated 14K) with about 9K of stuff on it.
  4. Jul 2, 2015 at 1:03 PM
    #1064
    BradyT88
    Well is what I meant, is take my KM2's for example, they have a speed rating of 88 mph. But in a trailer application; would they just end up back down to 65 mph? It would defeat the purpose. haha Not that I would choose an MT tire.
  5. Jul 2, 2015 at 1:16 PM
    #1065
    BradyT88
  6. Jul 4, 2015 at 3:17 AM
    #1066
    Flannel_Lover
    Flannel_Lover Your resident questionable advice giver
    Lucas
    Greenville, IN
    2011 sclb base 4x4
    Alpine component speakers Rockford Fosgate 10" sub Pioneer DEH-X6800BT Kicker CX 300W amp Extang Trifecta Big Country Brush Guard
    @maverick491 what do you mean by "overdrive"? I have a 4cyl 4spd. Is overdrive 4th (D) should I just put it in 3rd? Because at 55 mph in 3rd I'm cooking at 3000-3300 rpm.
    Thanks for the help
  7. Jul 6, 2015 at 9:22 AM
    #1067
    BradyT88
    Yes. Your 4th gear is an overdrive (higher than 1:1) and is something like 0.70:1. Your 3rd gear is 1:1. On the 5spd auto 5th gear is 0.72:1 and 4th gear is 1:1.
  8. Jul 6, 2015 at 2:46 PM
    #1068
    Flannel_Lover
    Lucas
    Greenville, IN
    2011 sclb base 4x4
    Thanks for the help!
  9. Jul 14, 2015 at 4:49 AM
    #1069
    802guy
    802guy New Member
    Hi, I'm new to the forum and have a few questions.
    I have a 2015 v6 Tacoma with the towing package and will need to tow a 5000lb boat 5 hrs, sometimes in hilly terrain a couple of times of year. I'd like to err on the side of caution with tranny cooling. I'm wondering if the stock transmission cooler is likely to be sufficient and if not, wether to replace it with something like the b&m 70264 or add another smaller cooler in addition to stock? As far as mods go, I figured in replacement situation the new one would use the same location and line setup as stock, if adding a second one, where to "plumb" in the additional cooler?
  10. Jul 14, 2015 at 6:30 AM
    #1070
    anarion55
    anarion55 Well-Known Member
    Tony
    S. Florida
    2013 PreRunner SR5
    ImMrYo's Mirror Mod, Stereo Upgrade - Power Pro 60x4 Amp/Kicker powered 8" sub/Pioneer component speakers, PassPort 8500 Radar Detector, Locking Bed Storage Cubbies, Onboard air system - Viair 450C compressor/16 gal. PVC tank/15 & 16" horns, quick-d/c air chuck in bed cubby 24" LED light Bar (mounted to skidplate)A Headlights, foglights interior lights and backup lights all converted to LED (HUGE difference)
    Check with the Mfgr to see if you can use the stock mounts (and how much extra cooling you can expect, while you're at it). My 2013 w/towing package is rated at 6500 lbs... if yours is the same, you should be ok, but a little closer to the upper limit than I like..
    Try some local tows to "feel out" how the truck is handling it... that will also give you some insight into how you'll have to adjust your driving style to the tow rig.
    Good luck.
  11. Jul 30, 2015 at 3:51 PM
    #1071
    ausfahrt
    ausfahrt Well-Known Member
    FL & VT
    2015 SR5 MT 4X4 V6
    Great thread. I haven't waded through the whole thing yet but thanks.:thumbsup:
  12. Jul 31, 2015 at 8:54 AM
    #1072
    dsune
    dsune Member
    Alberta Canada
    07 dcsb 6spd mt
    Bakflip HD
    Hey guys, new member here. I'm towing for the first time next week. A small 18' travel trailer. I have a 6 spd MT. No factory tow package, but have a class 3 hitch.
    Since I have a manual, do I need an oil cooler? I know I don't need the transmission fluid cooler.
    Also found the Toyota towing guide saying 5000# rating without the towing package (attached). I assume the 3500# is for bumper towing.
    Let me know if you have any other tips for towing.
  13. Aug 14, 2015 at 11:57 AM
    #1073
    Chopperness
    Chopperness Active Member
    Newbie tower here in need of advice. I have an access cab v6 with tow package and am looking into hauling my wife's Ford Flex from Florida to Washington state. After looking up the weights of the uhaul car hauler (2,200#) and adding the flex (4,400#) it comes out to about capacity (6,500#) Would this be to much of a haul? Are there better trailers? What are your opinions?
  14. Aug 14, 2015 at 1:57 PM
    #1074
    Chopperness
    The flex capacity is 4,500 and a plane ticket is about $500.
  15. Aug 14, 2015 at 4:18 PM
    #1075
    Mountaineerfan
    Mountaineerfan Well-Known Member
    Can't you just use a car dolly instead of a trailer?
  16. Aug 16, 2015 at 10:58 AM
    #1076
    Chopperness
    unfortunately no, the vehicle is AWD.
  17. Aug 16, 2015 at 12:42 PM
    #1077
    emilminasian
    emilminasian Well-Known Member
    Emil Minasian
    Glendale, CA
    2011 Trd sport double cab
    I full 2 jet skies each at 750 pounds and a single axle trailer that's about 17 feet long, considering I have not regeared with 34inch tires is there anything else I my want to do to stay on the safe side with my auto transmission? Do I leave it D the whole way?
  18. Aug 17, 2015 at 9:19 AM
    #1078
    ralfnjan
    ralfnjan Well-Known Member
    Hi all
    Just found the forum, great info here.
    I just completed an 11,000km (7000mile) trip to Newfoundland and back. Towed in 4 all the time (except for the odd long gentle downhill grade). I found that there would be a downshift in 4 on an uphill grade or increased headwind when I thought there wouldn't be. The rpm increase would be 150 or so. That usually signaled an iminent shift down to 3rd, so I'd disengage the cruise control if it was on, and cut backon the throttle. Sometimes the truck would shift down to 3, or I would shift it down.
    Now, I understand the D/overdrive hunting and why that's bad, but is the slight downshift and hold when in 4 a problem? It doesn't flip in and out, just drops as the load increases and the gears progress downwards.
    Equipment is 2013 Tacoma, 4x4, double cab, SR5 with full towing package. House trailer dry 2600lbs, usually under 3500lbs fully loaded. Sweet spot for towing is 90km/hr - 95km/hr (55 - 60mph). I get passed, but everyting is juusst right at that speed.
    ralph
  19. Aug 29, 2015 at 7:38 PM
    #1079
    life as ben
    life as ben Well-Known Member
    New Taco owner here. Recently completed a 500 mile tow of a 3,500lb travel trailer with no issues, but the trip left me with a lot of questions that I haven't seen the answer to in this thread.
    2002 / V6 / SR5 / Manual / xtra cab / 185k / on 17" FJ wheels
    Question 1: Should I replace my clutch? I don't know if it's ever been replaced, but performs fine. Is there a better clutch for towing than the stock?
    Question 2: My first tow included multiple climbs to 2,100ft in the hills of Chattanooga TN. My question concerns engine braking, the owner manual suggests using engine braking and I can't imagine navigating hills without the truck in gear. But my confusion is those that would say "brakes are cheaper than transmissions". The trailer I was pulling didn't have trailer brakes, when I purchase one trailer brakes will be a certainty.
    Question 3: Will towing 3,500lbs "wear out" my engine sooner? Obviously the manufacturer built it with an expectation that it would be used for towing, so why do some people suggest that towing with "our little v6's" will just tire them out. This question arose as at times on my first pull I had to put my foot in the floor requesting everything that little v6 had to offer.
    Question 4: I found it most beneficial to run the truck at 3,200 rpm in 4th at about 65-70 mph. And I averaged 11-12mpg. Is this rpm "normal" for towing? The alternative would obviously be to slow down I guess but I like to get where I'm going and it's hard to imagine that the manufacturer didn't consider my speedy driving habits as I'm sure they're common.
    Question 5: I assume the manual trans oil most loved by all is Redline MTF?
    Thanks for this forum!! So helpful!!
  20. Sep 7, 2015 at 10:00 PM
    #1080
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    alphabravo likes this.
