The Tacoma Towing Bible
Discussion in 'Towing' started by maverick491, Nov 18, 2007.
  1. Oct 4, 2016 at 2:58 PM
    #1261
    TheMuffinMan
    TheMuffinMan Banana Nut
    Coeur d'Alene, ID
    2023 Tundra Limited Crewmax 6.5' 4x4
    Toyko Joe and Wild Crow like this.
  2. Oct 4, 2016 at 3:09 PM
    #1262
    LeftCoastNerd
    LeftCoastNerd Old 'nuff to know betta
    Santa Cruz, California
    08 AC 4x4 OR 6sp
    yeah, that 10-15% tongue weight figure isn't arbitrary, its physics.
    blenderlady likes this.
  3. Oct 12, 2016 at 5:32 AM
    #1263
    blenderlady
    blenderlady Member
    Lea Ann Savage
    Satellite Beach, FL
    2007 Toyota Tacoma - Red, 2017 Toyota Tacoma - Blue
    2007: Stereo added, back up camera, XM radio antenna, trailer hitch 2017: Tonneau cover (when I figure out which one I want)!
    I wanted to thank the people who gave me advise about modifying my 2007 to pull my horse trailer. I solved the problem by buying a 2017 with a Tow package! (happy camper)! ;-)
  4. Oct 22, 2016 at 10:22 PM
    #1264
    Dadio
    Dadio New Member
    Larry
    2004 tacoma v6
    Transfer cooler
    The link is dead in the 6th paragraph of section #5. What are the devices that replace the bump stops? I do not know what this is referring to. Thanks.
  5. Oct 23, 2016 at 8:37 AM
    #1265
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
  6. Oct 31, 2016 at 8:00 AM
    #1266
    gnardoggie
    gnardoggie Well-Known Member
    Is there a way to tell from your VIN if you have a towing package from the factory? I'm presuming I do as I have factory hitch, 7 pin, and previous owner installed a brake controller.
  7. Oct 31, 2016 at 12:35 PM
    #1267
    Dadio
    Dadio New Member
    Larry
    2004 tacoma v6
    Transfer cooler
    One thing that is true on the 2004 Tacoma is that if you have the tow package, the neck of the radiator fan is green, mine is orange (no tow package).
    You may need to wipe it off first.
  8. Oct 31, 2016 at 12:36 PM
    #1268
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    That's an awesome demonstration!!
  9. Nov 1, 2016 at 5:41 PM
    #1269
    LeftCoastNerd
    08 AC 4x4 OR 6sp
    just looked. the shaft/neck holding my radiator fan is.... PINK ?? Mine definitely has factory tow. 2008 4x4 TRD OffRoad.
    Rattletrap66 likes this.
  10. Nov 1, 2016 at 6:16 PM
    #1270
    "OldManTan"
    "OldManTan" Bye bloody Taco... Hello MGM Burrito!
    Buffalo, NY
    '16 Tundra DC
    Holy chit, I've done a lot already!!
    I think mine is too. And also a 08 with tow package.
  11. Nov 1, 2016 at 7:48 PM
    #1271
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    Same
  12. Nov 3, 2016 at 1:23 PM
    #1272
    ThaGreenTaco
    ThaGreenTaco Well-Known Member
    Spencer
    Amarillo,TX
    Bilstein 5100s, TAG front bumper, body armor rear bumper with tire rack, smitty built winch, nfab nerfbars, magnaflow exaust, roll n' lock, 17in SC8s,33in Cooper MTPs, avital remote start, AFE dry pro air filter, 2 10 inch JL subs with polk mobile monitor mids and highs
  13. Nov 3, 2016 at 1:23 PM
    #1273
    ThaGreenTaco
    Spencer
    Amarillo,TX
  14. Nov 16, 2016 at 2:07 PM
    #1274
    sneakypete
    sneakypete Well-Known Member
    Cleveland
    what is that company that makes those crazy strong tow rope knots that replace a metal ring?
    they are green, i want to say gators or something
  15. Nov 16, 2016 at 2:17 PM
    #1275
    WATaco
    WATaco Well-Known Member
    Ed
    Seattle-ish, WA
    '14 Tacoma ORD
    Leer, AllPro sliders, Prinsu, OME, JBA UCA
    bubba rope gator jaws. http://bubbarope.com. Just used mine a couple of weekends ago - AWESOME!
    sneakypete[QUOTED] likes this.
  16. Nov 17, 2016 at 6:32 AM
    #1276
    sneakypete
    Cleveland
    thanks! i knew it was something gator.
  17. Nov 28, 2016 at 2:47 PM
    #1277
    rarbage
    rarbage Member
    2013 all about that base
    Any way to install the oem 7 pin on gen2 without factory tow package or is the 4 pin the only option we have
  18. Nov 28, 2016 at 6:19 PM
    #1278
    "OldManTan"
    Buffalo, NY
    '16 Tundra DC
    I don't know personally if your truck has the factory wiring, but you can definitely install a 7 pin. If the wiring isn't there, you just have to add it. Should just have to run the battery and brake wire. The 7th is a reverse wire, which you probably won't need. Hopefully someone else will have better/more knowledge to help also.
  19. Dec 1, 2016 at 9:29 PM
    #1279
    LeftCoastNerd
    08 AC 4x4 OR 6sp
    if the car doesn't have the factory wiring, to run a 7-blade, you'll need a isolation relay on the battery wire so it only comes on when your truck is running, you'll need the standard taillight/turnsignal/brake converter box (trailers have combined brake+turn lights like old american cars), and you'll need the wires for the trailer brake controller brought up to the drivers area (ground, battery +, stoplight from the switch on your brake pedal, and the brake wire back to the trailer connector).
    this kit, http://www.etrailer.com/p-etbc7.html plus a 4-pin taillight controller kit http://www.etrailer.com/Custom-Fit-...Tacoma/2005/118496.html?vehicleid=20051176462 (that one is plug and play on a tacoma).
  20. Dec 26, 2016 at 12:00 AM
    #1280
    Pinchet4co
    Pinchet4co Active Member
    Jesse
    Studio City, CA
    2001 Black Taco Prerunner 4 cyl
    Stock...for now!
    This bible comes in handy. Especially for new 4 banger Taco owners like myself that want to occasionally tow their boat to the lake.
